Simple Probability Statistics - Assembly Failure - Binomial Equations
M Greenaway
Simple Probability Stats
OK Guys
If I have six components on an assembly, and the components come from a source that is 14% defective, how many of my assemblies will fail if one defective component causes the assembly to fail ?
Is it simply 0.14 + 0.14 + 0.14 + 0.14 + 0.14 + 0.14 = 0.84 or 84%
Rob Nix
Will the jury please disregard my last comment. :eek:
This is a binomial equation. n=6 trials, r=1 failure, from lot of 14% bad = 80% chance of at least 1 failure.
This is provided the source is large enough not to be affected much by 6 parts being removed.
Sorry I first reacted without brain in gear.
Mike S.
Happy to be Alive
Tis been awhile since my statistics classes. Please explain your answer (formula). Thanks!
Tim Folkerts
It this case, think of how likely it is to work.
If there was just 1 component, then the odds of working are 1-0.14 = 0.86
With two components, the first has to work and the second has to work. The odds of both working are (0.86)*(0.86) = 0.740.
With 6 components, it becomes (0.86)^6 = 0.405.
So, 40.5% would work, and 49.5% would fail.
Tim
M Greenaway
If 40.5% work then 59.5% must fail.
But what is the probability that an assembly will have one or more defective components from a pool of 14% defective components ? Is it the same ??
Rob Nix
My original reply (which I deleted) was based on what Tim said (only in reverse - that was my error). But then I realized that the equation Tim is using is for system (un)reliability, where 86% is a unit's reliability. But Greenaway's question (and the second question) is about a discrete population of parts, which lend credence to the binomial distribution, which is "if the probability of occurrence p is constant on each of n independent trials, then the probability of r occurrences in n trials is: n!/(r!(n-r)!)pq^-r". To simplify matters I just used Excel's "binomdist" formula.
If I am way off base here, please explain.
M Greenaway
I am now thinking that it is of one or more components is defective then the assembly fails, hence we need to OR all the possible combinations of ANDs.
So the assembly fails if we have one defective component, or two, or three, or four, or five, or six (all).
Which would be 0.14 + 0.14^2 + 0.14^3 + 0.14^4 + 0.14^5 + 0.14^6
Which is about 16%.
This questioning relates to the fact that in reality I have 52% defective assemblies from a pool which appears to be 14% defective components (6 components per assembly).
Hence I want to know is it random throughout the batch, or do I have mixed batches, one all good, and one (or more) with random defects.
Any ideas ??
Rob Nix
The probability of zero or one defect is 80% ( :bonk: arghh - this is what I get when I try to do three jobs at once). The probability of no defects is 40.5% (like the others said, only using a different method), therefore the probability of one or more is 59.5%. You had 52%. Using control limits for a p-chart, and if your sample size (for the number of assemblies you checked to arrive at 52%) was less than about 350, then you may assume that it is random. NOTE: Do you have p-chart data on these assemblies? The patterns in the chart may give an indication of your other possible root causes.
Tim Folkerts
Right idea, but not quite complete.
The odds of all six being bad are indeed
0.14^6
The odds of one being good and five bad are
(0.86) * (0.14^5) * 6.
(The 0.86 is the odds that the first is good; the 0.14^5 are the odds that the next five are all bad; the 6 is for 6 choices for which one is bad.)
The odds of two good and four bad are
(0.86)^2 * (0.14)^4 * (6*5/2)
The odds of three good and three bad are
(0.86)^3 * (0.14)^3 * (6*5*4/2/3)
The odds of four good and two bad are
(0.86)^4 * (0.14)^2 * (6*5*4*3/2/3/4)
The odds of five good and one bad are
(0.86)^5 * (0.14)^1 * (6*5*4*3*2/2/3/4/5)
Then, as you say, we need to add up the five terms. Plug it into excel and you get a total of 59.5% bad, which is what I got before .
NOTE: using the same formula, the odds of all sixe being good are
(0.86)^6 * (0.14)^0 * (6*5*4*3*2*1/2/3/4/5/6)
= (0.86)^6 *1 * 1
(again in agreement with my previous calculations).
Tim
J Outsourced Purchasing for Contract Manufacturing vs more typical/simple Supplier Management ISO 13485:2016 - Medical Device Quality Management Systems 5
N Simple statistics questions on labor data Statistical Analysis Tools, Techniques and SPC 2
B Can someone help me explain P-Value with a simple word please? Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Nice and simple invitation email to an audit kickoff meeting Internal Auditing 1
G Rework, Reprocess, or Correction - A simple blurred letter on the legible etching ISO 13485:2016 - Medical Device Quality Management Systems 4
C Looking for simple Software Validation IQ templates. Qualification and Validation (including 21 CFR Part 11) 4
Cats Clause Micrometer and Vernier Caliper simple calibration process General Measurement Device and Calibration Topics 8
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Simple and effective way to maintain Training Matrix ISO 13485:2016 - Medical Device Quality Management Systems 16
J Simple supplier evaluation qualification process form that includes Risk Assessment Document Control Systems, Procedures, Forms and Templates 2
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
K Simple ISO 9001:2015 Overview Presentation wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
V Acceptance Criteria Gage R&R - Simple vs Complex Techniques Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Making a choice of Simple vs Comprehensiveness of Procedure/System of any Process Document Control Systems, Procedures, Forms and Templates 4
K Simple ISO 9001 Compliant Document Control Quality Manager and Management Related Issues 24
R Determining the feasibility/scope for FDA IQ/OQ against a very simple application US Food and Drug Administration (FDA) 2
R Root Cause for "Simple" External Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Marc What Airlines Really Charge (In 1 Simple Table) Travel - Hotels, Motels, Planes and Trains 6
E Simple Calibration Procedures for Surftest SJ-400 General Measurement Device and Calibration Topics 6
K Too Simple an Internal Audit Check Sheet? Internal Auditing 10
S Can you help with a simple SPC sheet to judge if inspection is Good / No Good ? Capability, Accuracy and Stability - Processes, Machines, etc. 8
T Microsoft Access Database to create a Simple Calibration Certificate General Measurement Device and Calibration Topics 6
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V Best CAPA for slip in simple-yet-persistent oversight-review mechanism Nonconformance and Corrective Action 7
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R A simple electronic (software) document control question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A QSM documents for Simple Designs Quality Manager and Management Related Issues 12
M Looking for a simple procedure on section 7.5.2 for Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Proud Liberal Making a simple Sampling Plan by Variables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Simple SPC Software recommendations Quality Assurance and Compliance Software Tools and Solutions 8
Z IEC 60601-1-2 for very simple Medical Device Accessory IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Monitoring Production Defects - Three simple questions Six Sigma 3
C Simple explanation of Uncertainty in Calibration Measurement Uncertainty (MU) 2
V External power supply with reinforced insulation as a simple secondary circuit? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Conducting Limited Internal Audits of QMS Elements - Simple question I hope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to set up a simple Complaint and CAPA workflow Nonconformance and Corrective Action 9
V Simple Representation for Scope of DFMEA and PFMEA FMEA and Control Plans 4
Stijloor Simple Navigation Guide for the MSA 4th Edition Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S Simple Cartoons needed Coffee Break and Water Cooler Discussions 4
X FDA Approval Process - Simple Explanation requested US Food and Drug Administration (FDA) 4
K Definition Box Plot - Simple Explaination of what a Box Plot is Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
M Simple Field Pipeline Demagnetization Procedure needed Document Control Systems, Procedures, Forms and Templates 5
6 Simple Flow Diagram with CCPs for Processing of Raw Fish Food Safety - ISO 22000, HACCP (21 CFR 120) 1
V Can Anyone Give a Simple Explanation on ndc (number of distinct categories)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T Export "Simple Notification" required by the FDA under Section 802 of the Act Other US Medical Device Regulations 3
Ajit Basrur EAC, Simple Code and NACE Code ISO 13485:2016 - Medical Device Quality Management Systems 5
1 Simple Dock Audit Form Document Control Systems, Procedures, Forms and Templates 1
Colin Simple Home Remedies Funny Stuff - Jokes and Humour 6
J Simple Corrective Action Flow Chart example needed Problem Solving, Root Cause Fault and Failure Analysis 4
B Overall Process Capability - Simple question if you know how to answer it! Statistical Analysis Tools, Techniques and SPC 3
