"Simplified" AS9100 and ISO 9001 Internal Audit Checklists
Coury Ferguson
Moderator here to help
#21
Sorry .... CB:notme: = ???
Yes a few .....
CB= Certification Body or Registrar. The third party that reviews the organization.
As for the checklist...avoid it. If you want to look at a checklist, buy and review AS9101. This is what the Certification/Registrar Body will use for compliance to AS9100.
Everyone that has mentioned about the "checklist" is right on. Use the process approach, a Turtle Diagram would be useful.
Just my opinion
#22
Our QMS was design around the ISO9001 standard, section by section, paragraph by paragraph from start to finish. The QPs and QWIs follow the exact same pattern, we have 23 QPs and 14 QWIs.
The checklist that we currently have is 25 pages and follows the standard section by section. IMO it's just TMI ..... So far everyone has been happy with it, we just completed and passed our audit and have been certified
to AS9100 RevC / ISO 9001:2008 with zero findings for the last 3 years.
I think I may be the problem here ....
Indeed, Scott, there's a problem which Houston needs to know about!
I'd be very worried about zero findings! Apart from anything else, it's just very unlikely that could happen. While the CB isn't paid to find fault, you have to ask, are you really THAT good?
On the checklist side, what you have done is OK to get you going, but at some point, you need to shift gears to move your whole QMS and audits along. Sadly your CB auditor doesn't have a clue, or they would have made some comment, I'm sure...
If you are auditing to the standards, you aren't auditing to processes. Take a look at this here for some help.
Also, how many times do you do an audit? Have a look here too for some more guidance.
Also, dump the checklist. Audit to your processes, their objectives and also the results you get (internal or with customers). You'll help management see the error of their current ways.
BTW did you have any auditor training? If yes, and the trainer didn't help you to understand this, you may wish to get someone in to coach you with your audit program. (and avoid that trainer...)
dsh205
#23
I mis-spoke when I said "ZERO" findings, I should have included "major" in there ....
In three years we have had a total for two minor findings and a few observations.
Sorry for the confusion .....
Marc
#25
Checklists
I<snip> dump the checklist. <snip>
Tell that to the pilot of the airplane next time you fly.
Checklists are valuable when used correctly. They are one tool in a box of tools.
dsh205
#26
Just my opinion
Thanks ... I've reviewed AS9101RevD
I'll approach this just I did when I was mapping the processes for my SixSigma projects.
I'm still confused a bit, if everyone is leaning towards process based auditing why then is there still a "checklist" and instructions on how to use it??
Sounds to me like the "bigger & better" mouse trap ....
Thanks to everyone that helped push me in the right direction.
Scott
Coury Ferguson
#27
Scott
Scott,
Aerospace is a different animal and has more requirements than ISO9001. The AIG which is mainly the Original Equipment Manufacturer (OEM) like the Boeings, Airbus, and the aircraft builders and major suppliers of main parts (engines and so forth) have determined that these extra requirements are needed, based upon the criticality of the Aircraft and risks.
Just my opinion.
#28
Scott
Well, in part it's because AS9104 is for 3rd party auditors. We can't forget, that at the most basic level, the CB auditor has to demonstrate compliance has been covered during the audit. It's a complex task and given the minimal time available, this approach helps to keep that compliance requirement in place - at least, that's the theory.
For internal audits, such an approach as a pre-printed, comprehensive set of questions, based on the standard is only appropriate in a few instances. Each audit is likely to have a different focus and criterion being used for that specific audit. The audit should go where the audit program has determined is the need, based on status and importance. The auditor should produce their own 'shopping list' - the task isn't quite like the pre-flights checks each and every time. Sure there are common things which can be verified each and every time, (document controls, product id. etc.) but in the main, using a standards based, format checklist isn't going to work!
dsh205
#29
Thanks for explanation.
I will "follow the process" and see what happens.
Scott
dsh205
#30
Ok guys, I decided to use a SIPOC diagram to indentify what I should be auditing for the given process.
I decided to look at the PRODUCT REALIZATION PROCESS.
Attached is what I've come up with so far ....
What do you think ???? FIRE AWAY !!!
Thanks for your input !!!!
Scott
S Configuration Management Simplified - Complying with AS9100 Clause 4.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M Medical Devices and ASD-STE100 (Simplified Technical English) Other Medical Device Related Standards 0
N Redoing the QMS to be Simplified Quality Manager and Management Related Issues 10
J Simplified Uncertainty Equation for Pipette Calibration Measurement Uncertainty (MU) 7
R GAMP (Good Automated Manufacturing Practice) simplified please. Quality Manager and Management Related Issues 3
P Simplified Statistical Sampling Plan - Printing Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Simplified Explanation of the 8 Quality Management Systems Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
GStough Looking for a Simplified Internal Audit Checklist (ISO 9001 / ISO 13485) form General Auditing Discussions 14
C Simplified version of QFD (Quality Function Deployment) - Ford Quality Tools, Improvement and Analysis 1
Marc Simplified Job Application Form Funny Stuff - Jokes and Humour 0
D Simplified Attribute MSA Gauge (Gage) R&R for Plug Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
Crusader AS9100 7.5.2 NOTE Approval methods identified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a organization use a disclaimer "pending AS9100 Certification" in Marketing Information? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K AS9100 and ISO9001 together AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 18
L Heading dies as "tooling" and AS9100 Manufacturing and Related Processes 2
L Heading dies as "tooling" and AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 - Product and Service Provision 8.5.1q AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
SocalSurfer Can you recommend an enterprise QMS for new AS9100 startup AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Open Positions During AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
C AS9120 or AS9100 Cert pertaining to inventory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H AS9100 Checklist for Internal Audit needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
hockeyhead Existing process never included in AS9100 scope of certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
W Major NCRs within AS9100 - What is the most frequent reason for Major NCRs? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
was named killer AS9100 Supplier Approval Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
S Effective nonconforming process for AS9100 8.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
O Adding ISO 13485 to an AS9100 QMS ISO 13485:2016 - Medical Device Quality Management Systems 13
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
NDesouza AS9100 - D Capacity Planning Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D ISO 9001 & AS9100 Certificate issued by a consultant for a Distributor Registrars and Notified Bodies 11
B FAR/Prime Contractor Flow-down Tool - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M When is FAI required? AS9100 8.5.1.3 and 8.4.3 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Ethics and Legality AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
classical_quality AS9100 Surveillance Audit - advice on drafting strong responses AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
