Simplified Attribute MSA Gauge (Gage) R&R for Plug Gages
Atul Khandekar
#11
Unfortunately there don't seem to be any definitive guidelines about this. Here is my take:
1. Since specs are different, you should not club the gages as one family of 'plug gages'
2. For one gage used on 5 parts, I think you can perform r&r on any one part.
-Atul.
Mike S.
Happy to be Alive
#12
Garry,
I have some experience using plug gages but I'm not an expert, but here's my opinion FWIW: I believe the toughest test for the gage R&R would be for the 15mm +/- 0.1 mm part -- the largest hole size with the tightest tolerance. If the gage is suitable in this application I believe it would only be as good or better for the smaller holes with the same tolerance. I mainly use plug gages for go/no go testing which is easier than using them for quantitiative purposes.
Hope this helps some.
Mike S.
K
Kathealcantara
#14
Gauge R&R
Hi
can anyone tell me what is the percentage of fake rejects than an attribute Gauge R&R can have and still be accetable?
After doing one i got 16 fake rejects aout of 1000 products, is this ok?
Tulman
#15
Gauge R&R
I have a question regarding a customers demand. They would like for me to cut the tolerance on the part by the amount of error that I see from my Gauge R&R. This is the first that I have heard of this. My understanding of the gauge R&R is to determine if it is the appropiate gauge for the specification to be measured with the tolerances allowed. The customer is suggesting that we do this even if we have less than 10% error. Has anone else ran across this demand or can anyone give an explaination for the reasoning of this?
Caster
An Early Cover
#16
Yikes!
Tulman
I agree with your understanding. Never heard this one before.
Perhaps you could politely ask them to point out where the MSA manual contains this idea. Or any other authoritative text?
If so, I'd like to read, study and learn from it...you never know!
Sadly you may lose this battle, the customer always wins, even when they are wrong.
#17
This is a fairly common practice called guard-banding. In the normal situation, the producer has a risk of rejecting good product and the customer has a risk of accepting bad product. The extent of this risk is determined by the measurement variation. See MSA for gage performance curves.
Guard-banding places 100% of the risk on the manufacturer and 0% on the customer. Your reject rate may increase, but the customer is protected. I have seen this used frequently when the process capability is much tighter than the tolerances, so the cost of rejects is minimal.
copperman
#18
Re: Simplified Attribute MSA Gauge R&R for Plug Gages
I have some questions about attribute MSA.
currently I use Minitab to calculate attribute MSA,
1. use hypothesis test ( p value < 0.05 ) it means the measurement system is accepted
2.also judged by Kappa value( if kappa >0.75, it shows good measurement system)
but if p value < 0.05 and kappa value < 0.75 , what comment should I make ? I can't find the answer in AIAG MSA 3rd.
3. any question is : if currently the result is only go/no-go ,for instances, in visual standard,there are many distinct categories, what method should I use ?
thanks for your reply !!
copperman.
chanti777
#19
I can send by e-mail a Word 6.0 Document that explains R&R for attribute data. Can you read this type of file?
Regards,
Don
Don,
I am also facing same problem in dealing with attribute data. Can you pls send me the Word 6.0 Document that explains R&R for attribute data to my e-mail: (Edited by Miner. Please contact the poster through Cove PM). I can read this file.
M Medical Devices and ASD-STE100 (Simplified Technical English) Other Medical Device Related Standards 0
N Redoing the QMS to be Simplified Quality Manager and Management Related Issues 10
D "Simplified" AS9100 and ISO 9001 Internal Audit Checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
J Simplified Uncertainty Equation for Pipette Calibration Measurement Uncertainty (MU) 7
R GAMP (Good Automated Manufacturing Practice) simplified please. Quality Manager and Management Related Issues 3
P Simplified Statistical Sampling Plan - Printing Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Simplified Explanation of the 8 Quality Management Systems Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Configuration Management Simplified - Complying with AS9100 Clause 4.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
GStough Looking for a Simplified Internal Audit Checklist (ISO 9001 / ISO 13485) form General Auditing Discussions 14
C Simplified version of QFD (Quality Function Deployment) - Ford Quality Tools, Improvement and Analysis 1
Marc Simplified Job Application Form Funny Stuff - Jokes and Humour 0
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
K IATF & Attribute Study requirements IATF 16949 - Automotive Quality Systems Standard 9
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P RQL/AQL from Attribute Data Six Sigma 1
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Attribute G&R for all Visual Controls in Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Attribute Test Method Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Attribute Sampling Plans with Switching Rules - Software Recommendations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
A Attribute Inspection P Chart Statistical Analysis Tools, Techniques and SPC 9
Chennaiite Do Attribute Control Charts really help? Statistical Analysis Tools, Techniques and SPC 9
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Cross Tab Attribute Gauge Study form Excel .xls Spreadsheet Templates and Tools 3
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
