I'm doing procss improvement work in an organisation that has previouisly created procedures for everything that can be thought of. So there are over 350 documented procedures which is far too much! And a lot of associated auditing which tends to take a compliance approach both in internal and external (BSI) forms
I think that defining process capability and performance indicators would mean that if the metrics showed that the process was under control, the need for documented procedures (other than the six mandatory ones) and audits would be significantly reduced.
In other words, if the right outputs are being achieved, then the proces is under control.
Is anyone else taking this approach and what learning points can they share?
