Simulate Tolerance Range with Real Parts
I am performing a gage R&R test for hydraulic hose fittings after being crimped on hoses. I have chosen 10 fittings and marked a location with a blue dot on each one. The upper spec is 21.459 and the lower spec is 20.959 but all of the measurements are coming in between 21.27 to 21.3. According to an article titled "Gage R&R (Repeatability and Reproducibility)" on qualitymag.com (not enough posts to insert a link), you should find parts that represent the full range of tolerance. We are producing these so consistently that I cannot find anything near the top or bottom end of the tolerance.
Should I simulate the upper end of the variation by applying a thin layer of some kind of durable and/or hard tape to the fitting? For the lower end I could maybe hammer a fitting down a bit .
This is a deep and complex subject. If you can post your data we can give further advice. I also strongly recommend MIner’s blogs and my paper on measurement error in the resources section. I will let you poke around as there is a wealth of knowledge there and I’ve almost always accidentally found really useful things when I wander around looking for something else. :cool:
The article is here, and the author contradicts himself by saying,
[You will need] Five to 10 parts (number each part) that span the distance between the upper and lower spec limits. The parts should represent the actual or expected range of process variation.
What you want is the full range of the process, not the tolerance.
So in my Gage R&R spreadsheet which performs all the calculations, should I use the part tolerance for the upper spec and lower spec, or should I use the upper and lower measurements from our samples (which would represent the range of the process)?
Well it is quality magazine and most articles in recent history have been puff pieces, usually by people trying to sell you something from their company. Caveat emptor
If you use the measurement device for inspection, you would use the % Tolerance metric to assess whether it is adequate. Part selection has NO impact on the results of % Tolerance. There is no benefit to making special parts at the extremes of the tolerance. Your calibration program probably checks the calibration throughout the measuring range of the device anyway.
If you use the measurement device for SPC, you would use %Study Variation (OR ndc). In this case the part selection is extremely important and MUST reflect the actual process variation (not the tolerance range).
N Heavy tare to simulate high load in a routine sensitivity test of a floor scale? General Measurement Device and Calibration Topics 3
A Does Least-squares (LSQ) simulate perfect roundness? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Looking for Animal Model to Simulate the Anatomy of the Human Cervix 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
D Will just Heat and Humidity be Adequate to Simulate EtO Sterilization? Design and Development of Products and Processes 2
F Gage R&R Destructive Test With Breakaway Fixture To Simulate A Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Tolerance and MPEs for Re-calibration Manufacturing and Related Processes 0
S GD&T Bonus Tolerance OOS Capability, Accuracy and Stability - Processes, Machines, etc. 2
WEAVER Can you determine exact date an instrument went out of tolerance? General Measurement Device and Calibration Topics 10
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
I Profile tolerance with a positional tolerance to a hole ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A % STUDY VARIATION VS. % TOLERANCE Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 31
A +0/-.001 Tolerance question - Feature size is 1.249 +0/-.001 - Actually measures 1.2493 (.0003 OHL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
L Validation without Tolerance Qualification and Validation (including 21 CFR Part 11) 0
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
Q Acceptable Tolerance - how to derive? Measurement Uncertainty (MU) 16
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
