SIP/SOP - Mains Power and Medical Device Ethernet Ports
Roland chung
#11
With respect to the patient, if the medical equipment has Type F insulation (BF, CF) or if the SIP/SOPs are earthed or there is an earthed intermediate circuit, then there is really no potential harm from SIP/SOPs.
Hi Peter,
The "earthed" you mentioned is not for "protectively earthed" only, right?
The intermediate circuit including the SIP/SOPs is normally earthed but will definitely fail the impedance and current-carrying test which based on earth fault of mains side (cl. 8.6.4).
In practice, SIP/SOPs should not be subject to high current testing unless the fault source is unlimited (but that is not true). Unfortunately, the standard seems to apply an unlimited mains source on the SIP/SOPs (the resistance in Figure 14 is optional and is just to protect the person performing the test).
Peter Selvey
Moderator
#12
Yes, the earthed only needs to be sufficient to divert leakage currents (mA) to ground, not fault currents (Amps). Normal "functional" earthing is enough for this.
If the test is performed according to Clause 16, it means testing the actual system, not the "mains on SIP/SOP" test.
If you have two earthed devices A and B, both separately plugged into the wall, which are then connected together via an earthed signal connection, and the earth in device B is broken, the leakage current will flow via the signal cable through the earth of device A and back to the wall, not to the operator or patient. There may be double leakage, exceeding 0.5mA, but the leakage is not able to get to the operator/patient without a second fault which is not considered by the standard.
The test can be considered hypothetically if the actual system is not known.
antonoia
#13
Hello everybody,
I see there are different opinions regarding this point, so I will give mine too and see if you agree. Definition of SIP/SOP states that is applicable for connections intended to other electrical equipments. A lan port connected to a third device will not ensure any kind of insulation, and so the test will be still applicable. If the device is provided with more than one port , you can apply the main voltage on all of them temporarily or once at a time, is always under the single fault condition philosophy, depend from the fault extension. I appreciate Peter's opinions I think in some cases standards requires more than what is the real world. But I am not still sure if the test will be still applicable to a device (in a ME system or not) of which specifications are defined. Waiting for yours , Regards!
J Application of mains voltage on SIP/SOP connectors of medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B How to apply external voltage to SIP/SOP IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Appearance of an External Voltage on SIP/SOP (Medical Devices) IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
S High Voltage inside Ultrasonic Probes - Do SIP/SOP ports require isolation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
O EMC - EFT (Electrical Fast Transients) on SIP couples erroneously with other cable CE Marking (Conformité Européene) / CB Scheme 1
G Metal Scale (SIP-Societe Genevoise) change in size over time? General Measurement Device and Calibration Topics 8
P How to add Voip features (ring group, virtual receptionist) into Cisco SIP PBX in C#? Medical Information Technology, Medical Software and Health Informatics 1
G SIP MU-214 Measuring Machine - Anyone modernize one? Capability, Accuracy and Stability - Processes, Machines, etc. 1
A IEC 60601-1 SIP/SIO Isolation and Touch current requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
N Agile SOP for SaMD IEC 62304 - Medical Device Software Life Cycle Processes 3
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 8
R Is it required to have an SOP for external audits? Medical Device and FDA Regulations and Standards News 7
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 0
D Sample Calibration SOP for ISO 13485 General Measurement Device and Calibration Topics 4
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 4
M What to do in SOP Phase of Head unit testing? IATF 16949 - Automotive Quality Systems Standard 0
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
W SOP examples wanted - Soil, Concrete and Asphalt testing ISO 17025 related Discussions 3
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
pashah Looking for Clinical Evaluation SOP acc. MEDDEV and EU MDR Other Medical Device Related Standards 0
M SOP Sample for BC/ISO22301 (Business Continuity) wanted Business Continuity & Resiliency Planning (BCRP) 4
M Risk/Benefit vs. benefit-risk - Revising an SOP covering Risk Management with the MDR in mind EU Medical Device Regulations 10
A How to manage the QMS system and SOP during the transition from MDD to MDR EU Medical Device Regulations 4
V Protocol, report or SOP for threshold analysis? Human Factors and Ergonomics in Engineering 0
V Nature of references allowed to be cited in the SOP US Food and Drug Administration (FDA) 2
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 3
M Charging consulting fees for SOP development and guidance Document Control Systems, Procedures, Forms and Templates 13
J Just Venting - Do you refer directly to MDR or you just refer to SOP's? CE Marking (Conformité Européene) / CB Scheme 3
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
S Should there be a SOP on Cybersecurity? ISO 14971 - Medical Device Risk Management 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
J Nonconforming product procedures SOP help :) Nonconformance and Corrective Action 2
G NIST SOP 29 - Assignment of Uncertainty - Question General Measurement Device and Calibration Topics 0
A SOP for software validation of software in medical device IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 5
S SOP Training/Competence in 24/7 Operation contractor company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K EU MDR - PMS (Post Market Surveillance) SOP - definition of "register(s)" EU Medical Device Regulations 2
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
J Business Impact Analysis SOP Business Continuity & Resiliency Planning (BCRP) 2
Jane's Do you have an SOP for communicating with regulatory authorities ISO 13485:2016 - Medical Device Quality Management Systems 8
D 21 CFR Part 11 - Electronic Signature Management SOP Other US Medical Device Regulations 0
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S Authorized (EC) Representative Contract and SOP EU Medical Device Regulations 12
M SOP or template for a study to Define Storage Conditions of Orthopaedic Implants EU Medical Device Regulations 3
J Does anyone have an example Authority Listing SOP example? Misc. Quality Assurance and Business Systems Related Topics 3
S Clinical evaluation standard operating procedure / SOP for medical devices Document Control Systems, Procedures, Forms and Templates 1
S Medical Device Clinical Evaluation Standard Operating Procedure / SOP Document Control Systems, Procedures, Forms and Templates 11
