SIPOC (Suppliers Inputs Process Outputs Customers) Feedback & Example to share
E
EEJen
I was working on my Internal Audit Work Process SIPOC. Since I don't have a lot of internal resources to check if anything is missing. I thought I would put it out here for review. This is still a work in progress. I need to add the ATEX, EN13890, requirements for Quality Assurance & Management requirements.
qusys
I have seen the mapping that you have posted according to SIPOC diagram.
I was a bit confusing .
I think that the intent should be the mapping of the Internal audit (process).
Based upon the above method ( SIPOC stands for Supplier, Input, Process, Output, Customer), you shall indicate who are the Suppliers and what inputs give to the process that you want to map ( in this case Internal audit, in centre ) and who will be provided ( Customers) of the output of the mapped process.
In the mapping I think that "triggering point" ( what initiates the process) and "concluding event" ( what finishes the process) are missing as well as the intent of the process .
:bigwave:
tekno9000
:bigwave:
The triggering point is the Management request {in form of audit plan as defined in the quality manual} or it can be customer request {agreement/contract}) and the concluding event is the audit report (with findings and OFI).
Please correct me if I am wrong.
qusys
Yes, but it also depends on the boundaries and the intent of the process to be mapped, that is usually described in a section called "Process description".
In a mapping for internal audit process, I would suggest "delegation of the audit authority" as a triggering event and "results of the planned internal audits communicated to management" as a concluding event .
These ones probably are wider than the ones you said but we are aligned.:bigwave:
E
EEJen
Yes, I consider the main triggers from Top Management from the Quality Manual and the customer would be from a contract review. I will change that from customer request to reflect output from Contract review and a link to that process.
I was going to add the process intent just had not decided where on the form.
Thanks for all the input.
qusys
Other suggestion if you want.
In Input consider to insert the pre-process immediately before the process you are mapping and the related supplier. For example one could be: Management review and supplier could be Top Management. The processes that give the imput should be the ones you have put in the general QMS mapping as per 4.1 clause ( or related sub processes/activities). The same for the output whre you shall indicate the post process ( to the internal audit) and the customer as well as the output description.
As to metrics, consider to have at least one of efficiency and one for effectiveness.
Indicate clearly process owner, stewards as well as performes roles as well.
I appreciated your thanks.:bigwave:
E
EEJen
Are suppliers and customers the same?
Yes the supplier and customer are the usually the same for this process. The customer supplies the requested audit scope for the audit and the report goes to the customer.
Thanks for the question. I need to add the Audit Scope as the input.
Ajit Basrur
Can a customer, external to the company, be in the C column for a CAPA SIPOC?
Thank you
I would not as the "Customer" is the recipient of the "Process"
The way the SIPOC is built is that is -
Suppliers to the process : Contributors or who provide input to the process
Inputs provided by the supplier : What are the inputs provided to the process ?
Process : Where does it start and where does it end ?
Output of the process : What are the services or products offered to customers ?
Customers of the process : They are the consumders of this Process and often specifying their requirement.
A SIPOC (Suppliers Inputs Process Outputs Customers) examples wanted Quality Manager and Management Related Issues 1
Q How to read and interpret an SIPOC (Suppliers Inputs Process Outputs Customers) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M SIPOC (Suppliers Inputs Process Outputs Customers) Process Mapping Tool example Process Maps, Process Mapping and Turtle Diagrams 11
Z SIPOC (Suppliers Inputs Process Outputs Customers) Chart Training Material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D SIPOC (Suppliers, Inputs, Process, Output, and Customers) for Documentation Policy Quality Management System (QMS) Manuals 3
C TS 16949 Internal Audits - SIPOC (Suppliers*Inputs*Process*Outputs*Customers) Internal Auditing 15
D Should "Waste" be included as Output in SIPOC Chart? Process Maps, Process Mapping and Turtle Diagrams 8
Q Where to include the SIPOC results in QMS (Quality Management System)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Confusion in writing a SIPOC (Supplier, Input, Process, Output, Customer) Six Sigma 5
I Six sigma project in a BPO - Calculating DPO and Creating SIPOC Six Sigma 3
I Six Sigma - Confusion while creating SIPOC diagram Six Sigma 6
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
O How to give a score/yield more correctly to my suppliers Supplier Quality Assurance and other Supplier Issues 12
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
S Conflict Minerals - Tin Suppliers CMRT Miscellaneous Environmental Standards and EMS Related Discussions 2
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 6
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
C Critical Suppliers for EU medical device approvals May 2020 EU Medical Device Regulations 1
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
P Qualifying commercial off the shelf (COTS) external suppliers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Nicole Desouza Are Shipping Companies Suppliers? Manufacturing and Related Processes 4
J Painted cut threads - ASME Pipe Suppliers Manufacturing and Related Processes 6
G ISO 9001 8.4 applied to 7.1.3 - Suppliers of infrastructure requirements - IT and Print solutions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
J Requirements for customer directed suppliers Customer and Company Specific Requirements 5
R Supplier Controls we can place on Single-Source Suppliers ISO 13485:2016 - Medical Device Quality Management Systems 2
L Audit boundaries - Is a Registrar permitted to audit a company's QMS by visiting their suppliers? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
R ISO 9001 versus ISO 13485 for Suppliers to Medical Device Companies ISO 13485:2016 - Medical Device Quality Management Systems 2
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 15
P IATF 16949 - Monitoring Suppliers for Premium Freight IATF 16949 - Automotive Quality Systems Standard 12
DuncanGibbons Documentation aerospace OEMs require with purchase of parts from manufacturers/suppliers Manufacturing and Related Processes 0
K Supplier Controls for Animal Tissue Suppliers for Medical Devices Other Medical Device Regulations World-Wide 0
optomist1 Survey of Tier 1 & Tier 2 suppliers APQP and PPAP 6
P Non-Active Suppliers on CE Certificate EU Medical Device Regulations 2
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
D Training for AS13000 - Problem Solving Requirements for Suppliers Training - Internal, External, Online and Distance Learning 14
eule del ayre List of Level 3 PPAP requirements for automotive suppliers APQP and PPAP 20
Q Does our material suppliers’ supplier have to be at least ISO 9001 certified? IATF 16949 - Automotive Quality Systems Standard 3
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
S Outsourcing manufacturing - Who controls the suppliers of parts to the CMO? ISO 13485:2016 - Medical Device Quality Management Systems 2
Ed Panek Supplier Auditing - No purchases from our key suppliers in the last 24 months ISO 13485:2016 - Medical Device Quality Management Systems 5
I IATF 16949 - 8.4.2.3 - Applicability to Shipping Suppliers IATF 16949 - Automotive Quality Systems Standard 11
A MedAccred being flowed down to Suppliers (2018) MedAccred Industry Group Program 0
T What's the quality standard adopted by BMW for its suppliers Customer and Company Specific Requirements 5
S Do suppliers of prototyping components need to undergo supplier qualification? ISO 13485:2016 - Medical Device Quality Management Systems 3
O ISO 13485 for software company - Selecting suppliers ISO 13485:2016 - Medical Device Quality Management Systems 3
