Small Sterilized Battery Operated Light - Is this a medical Device?
K
Ktrna
A small sterilized battery operated light (like a reading light) intended for use in minimum invasive surgery or low light surgery to provide light while preparing, reading syringe labels, loading/unloading needle drivers, scalpel blades and preparing specimens.
somashekar
From ISO13485 definition:
medical device:
any instrument, apparatus, implement, machine, appliance, implant, in vitro reagent or calibrator, software, material or other similar or related article, intended by the manufacturer to be used, alone or in combination, for human beings for one or more of the specific purpose(s) of
 diagnosis, prevention, monitoring, treatment or alleviation of disease, (NO, for the light)
 diagnosis, monitoring, treatment, alleviation of or compensation for an injury, (NO, for the light)
 investigation, replacement, modification, or support of the anatomy or of a physiological process, (NO, for the light)
 supporting or sustaining life, (NO, no for the light ... or perhaps ...?)
 control of conception, (NO, for the light)
 disinfection of medical devices, (NO, for the light)
 providing information for medical purposes by means of in vitro examination of specimens derived from the human body, (NO, for the light)
and which does not achieve its primary intended action in or on the human body by pharmacological, immunological or metabolic means, but which may be assisted in its function by such means.
I feel its a NO for all the points of the above definition. Hence Small Sterilized Battery Operated Light is not a medical device ...
The key point is "intended by the manufacturer to be used, alone or in combination, for human beings for one or more of the specific purpose(s) of "
So if the manufacturer of the light wants to term it as a medical device saying that it is supporting or sustaining life in its own right, then he can, and based on his further risk assessment, he can be also sterilize it as you have mentioned.
In which case it will become a single use light and must be disposed after one use ?
K
Ktrna
Thanks for the reply. What had me wondering is what I read on the FDA website. Would this small light would fall under this category?
Subpart E--Surgical Devices
Sec. 878.4580 Surgical lamp. (a)Identification. A surgical lamp (including a fixture) is a device intended to be used to provide visible illumination of the surgical field or the patient.
(b)Classification. Class II.
MIREGMGR
If I understand the product's function correctly, it is to be physically operated by one of the sterile personnel within the sterile field, in proximity to the patient, likely during a sterile invasive procedure. Given that, it's obviously a medical device per FDA. Its use qualifies as diagnostic or therapeutic. It doesn't create the diagnostic or therapeutic effect by itself, any more than the surgical table does; but it has to be there for the overall procedure to work.
It's very difficult to convince the FDA that any product that's used directly by sterile personnel within a sterile field during a procedure is not a medical device, and I wouldn't recommend trying...especially if you want to be able to get the product through US Customs.
In my view, it's obviously a medical device per MDD definition, using a similar analysis. Ditto for the Canadian, Australian and New Zealand rules. I don't know about Japan.
MIREGMGR
As to FDA classification, as you may know most devices under 878.4580 are large overhead mounted lights. Your need is to identify a predicate device first, then determine what classification and regulation were applied to that predicate device.
If your device in fact is novel, you'll have to discuss with FDA whether they'll allow you to use an overhead surgical light as a predicate, or instead require you to follow some other regulatory path.
Ronen E
Problem Solver
Moderator
I very much agree. With regards to EC, Australia etc. regulation, I would say this light would fall under the definition of an accessory to a medical device (or devices), because it's probably intended to enable those other devices to achieve their intended purpose. Under the MDD etc. accessories are regulated similarly to medical devices.
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
J Defining staff competence - Small mechanical workshop Occupational Health & Safety Management Standards 20
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
shimonv Worthwhileness for a small startups to apply for EUA (Emergency Use Authorization) for COVID-19 US Food and Drug Administration (FDA) 17
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T ISO 13485 - 5.5.1 Responsibility and authority - Small Company Independence ISO 13485:2016 - Medical Device Quality Management Systems 13
M Customers Request AS9100 certification - Small Company (less than 20 employees) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
T EQMS for small medical device company ISO 13485:2016 - Medical Device Quality Management Systems 18
E Sharepoint for ISO 13485 QMS for small IVD company ISO 13485:2016 - Medical Device Quality Management Systems 11
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Gauge Study for Small Lots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
E In need of a new TGA sponsor - Small software company Other Medical Device Regulations World-Wide 4
Nicole Desouza ISO / AS Certification - Small business with less than 100 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
R Inventory management for a small startup device company Other Medical Device Related Standards 1
R ISO 13485 and QMS related concepts Training - Small medical device startup company ISO 13485:2016 - Medical Device Quality Management Systems 9
E Question on GD&T added to print - Positional callout for the small holes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Is CE Mark needed for a small DAC audio board on top of a Rasberry PI? CE Marking (Conformité Européene) / CB Scheme 1
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
Ed Panek Small Medical Device company - Bring production in-house ISO 13485:2016 - Medical Device Quality Management Systems 1
K Small Sample - Lower Limit Probability Statistical Analysis Tools, Techniques and SPC 0
Z Best Practices - small volume medical device tube cutting (0.020" to 0.080" OD)? Manufacturing and Related Processes 3
L REACH Compliance - Small, family-owned contract manufacturer REACH and RoHS Conversations 16
Tagin Measuring supplier quality with small quantities Statistical Analysis Tools, Techniques and SPC 10
apestate Inexpensive Gage Blocks for small aerospace startup shop General Measurement Device and Calibration Topics 1
I DOE: High variance and small effects in Minitab Using Minitab Software 1
E Small one man shop with QMS (shoptech e2) | AS9100 cert help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 46
M AS9100 - Where to start - Small company (10 employees) and I am the Quality Dept. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
B ISO 9001:2015 for a Small Machine Shop need Resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H AS9100D Cert question - Small machine shop - Where can I buy a certificate? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Le Chiffre Is ISO/IEC 27001 appropriate for most small businesses? IEC 27001 - Information Security Management Systems (ISMS) 2
P Is it possible to make an educated decision using a very very small sample size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Medical device manufacturer - Product certification (Small businesses) EU Medical Device Regulations 2
J Requirements for Work Transfer of Small Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P QMS software recommendations for a small ISO 13485 company Quality Manager and Management Related Issues 5
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
S Quality Plan at a small Medical Device Company - Is the quality plan a DMR document ISO 13485:2016 - Medical Device Quality Management Systems 6
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
E Defined Roles in Small Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Number of Audit Days - AS9100D Transition for a Small Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9100D excluding Design and Development - Small Job Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
R ISO 9001:2015 for Small Enterprises - Book from ISO ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Performing PQ on a Small (tabletop) Air Heat Treating Oven ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H How to Establish and Document Competence of Employees in a Small Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Suggestions on Inadequate Resources in a Small Machine Shop Nonconformance and Corrective Action 2
M API Monogram License for a Small Machine Shop Oil and Gas Industry Standards and Regulations 1
