Smallest Gage block - What is the smallest gage block for calibrating micrometers?
L
lebronfeldt
I have a 0.010 block but would like something smaller.
bobdoering
Stop X-bar/R Madness!!
Re: Smallest Gage block
You can go to smaller gage pins (Deltronic) or gage balls. You may want to use gage balls as an approach to detect wear on micrometer anvil faces.
L
lebronfeldt
to make a 2.00 reading is actually 2.00 on the display.
I've tried feeler gages but they keep giving different readings.
Re: Smallest Gage block - What is the smallest gage block for calibrating micrometers
Hello everyone
If you used a 2.000mm block and a 2.001mm block you could get a 0.001mm difference. This should be visible on an electronic micrometer.
Hope this helps.
Paul
K
kgriff
What is the nominal thickness of the paper?
You might try something like this. Using an example of a nominal paper thickness of 0.12mm, with a tolerance of +/- 0.010mm
-Purchase a 10mm Class Y plug gage. Purchased as a "master", this will have specification of +/-0.000445mm.
-Use the plug gage, in conjunction with the micrometer, to measure the paper. (In other words, for every measurement, you will be measuring the plug and the paper at the same time. This makes the nominal measurement 10.12mm +/- 0.010mm)
This method gets you within a range where you do not require any special sized gage blocks to calibrate your mic. At my company, we have and use many odd-sized gage blocks. There are available from most any gage block manufacturer. However, they are expensive to purchase, and expensive to have them calibrated. You are better off to sitck with normal sized gage blocks, where possible.
Jen Kirley
Quality and Auditing Expert
Since a gage is said to most accurately measure in approximately the center of its range and its resolution should be about 10 times that of the tolerance increment, I would not choose a micrometer for this task. So, as Stijloor suggests I would start with an instrument that has an appropriate range and resolution. I would get this gage externally calibrated before trying in-house calibration to .001mm.
apestate Estimating between a gage's smallest increments - What is the true story? General Measurement Device and Calibration Topics 4
J Precision of REPRORUBBER - What is the 'smallest' that reprorubber can discriminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A What is the smallest slice of time? Coffee Break and Water Cooler Discussions 46
V Analog Pressure Gauge Calibration - smallest resolution practice General Measurement Device and Calibration Topics 12
A Identification and Traceability down to the smallest detail of the component AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C What is the smallest measurable tolerance? Measurement Uncertainty (MU) 4
S What is the smallest component (team/person) of an organization can get certified? Registrars and Notified Bodies 10
E What is the smallest graduation (resolution) available for a Dial Test Indicator? General Measurement Device and Calibration Topics 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
