SMED - Single Minute Exchange of Dies template (tabular column) wanted
P
pressanna - 2010
Dear All,
If anyone has SMED - Single Minute Exchange of Dies template (tabular column), do attach it and send across. I need it for a project.
Pls note: Pls dont as such google and send the google link.:nope: I need a reliable chart.:rolleyes:
Thanks in advance
Prasanna
Stijloor
Dear All,
Thanks in advance
Prasanna
What have you been able to find so far?
Stijloor.
Aguas
Attached you will find a real samples, from my prospective the 3rd tab is the most important because you can use pareto to attack you improvement, the spread sheet is self expained but if you have a question about this spread sheet do not hesitate to ask
sigmasundar
Dear All,
Thanks in advance
Prasanna
Dear Prasanna,
you can get concept info through google by typing SMED filetype:ppt.
but i you need real solution, why not share your project with us. As such SMED can be applied for any change over process, please be more specific with following details.
Process : (Ex: pressing, machining etc.,)
Machine:
Current change over time.
what you have studied so far...?
Then we will definitely assist you...
Bye,
Sigmasundar
______________________________________________________________________
IN GOD WE TRUST ALL OTHERS BRING DATA
P
pressanna - 2010
Hi Sundar,
I did ma proj in soap industry...i took size changeover process....formed the element table and identified the internal and external activities... i gave suggestions to convert some internal to external activities....
Nw de changeover process time can be reduced by 1.2 hrs!!
To support ths i ve calculated VAR values for de same.
Guess i ve done SMED proply...Still then i need feedbk on ma wrk...is it ok??
sigmasundar
Hi Sundar,
Hi prasanna,
I can understand from your statement that you have studied process and u know some thing about SMED.
Before starting, i would like to recommend you an imporant book "SMED by Shigeo Shingo". Please read this book completely so that you know the importance of changeover time reduction.
Just ask these questions to your project work?
1.Have you given SMED awareness to concerned persons?... not a classroom session just a shop meeting is enough...Operators must know this because this study may cause resistance among operators...You have to tell them before conducting the initial changeover study about this study and ask them to work as normally they do everyday....otherwise you will not see the true picture....
2.Have you asked them for any problems they face during changeover and improvement suggestions ? I am telling you this because any improvement methodology must start from shopfloor (Gemba)
3.Have you done any improvment in material handling system?
4.Have you made any design changes in your tool or in the machine?
5.Have you made any improvement in passing information about changeover to concerned persons?
6.Have you studied possibility of horizontal deployment in other products
Finally dont try to implement everything in one go... give some breathing time and implement it gradually.. and make sure that the new system gets standardized...
Standardization means in production, supervisor will book losses in his report... changeover time should be noted and to booked as per the new improvement, that is if you manage to make changeover within 15minutes... every time it should be 15 minutes.
Wish you all the best your career...
Bye...
sigmasundar
Hi Sundar,
Hi prasanna,
Bye...
mayur_rastogi
Hey Prasanna,
I am working on the same project "Applying SMED on the Variant Changeover in the soap industry". I would really like to get in touch with you and know what you had done.
Pls help :)
P SMED (Single Minute Exchange of Dies) - Project guidelines/ example required Lean in Manufacturing and Service Industries 2
J Pronunciation of SMED (Single Minute Exchange of Dies) Lean in Manufacturing and Service Industries 10
S Single Minute Exchange of Dies (SMED) Information Manufacturing and Related Processes 17
A Can SMED (Single Minute Exchange of Dies) be applied to office environment? Lean in Manufacturing and Service Industries 18
D Toyota SMED (Single Minute Exchange of Dies) Clarification Lean in Manufacturing and Service Industries 12
P Single Minute Exchange of Dies and Rollfeeds - SMED in press shops Manufacturing and Related Processes 1
D Single Minute Exchange of Die - Preparing to launch a SMED project Manufacturing and Related Processes 14
M SMED - 2750 Ton Injection Molding Machine Benchmark Benchmarking 3
S SMED on Punching Machine - Reducing Set-Up Time Lean in Manufacturing and Service Industries 4
J Methodology to Improve Productivity using SMED & TPM - Experts opinion about it. Manufacturing and Related Processes 4
C Assembly Line Organization 17% Startup Loss - SMED (LCD TVs) Lean in Manufacturing and Service Industries 3
B SMED in a vertical CNC Lathe Workstation consisting of 3 similar machines Lean in Manufacturing and Service Industries 2
8 SMED Classroom Exercise to show operators the importance of SMED Lean in Manufacturing and Service Industries 10
I MOPP required for SIP when considering Single Fault Condition (SFC) in 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 16
J Critical Supplier Initial evaluation for single purchases Oil and Gas Industry Standards and Regulations 16
B Labeling question about different manufacturers on a single label Manufacturing and Related Processes 4
J Single Fault Testing for Secondary Circuits (60601-1 section 13.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K ISO 2859-5 (single run production) control plan issues FMEA and Control Plans 2
J Can you assign two EMDN codes to a single device for EUDAMED? EU Medical Device Regulations 3
A Single-Use accessory disinfected prior to use Other Medical Device Related Standards 6
L Single-cell lithium ion battery regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Labeling requirements for single use devices Manufacturing and Related Processes 4
renenatasha Single Registration Number (SRN) EU Medical Device Regulations 2
E Sources of every single paragraph of the ISO 9001 standards? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Lithium Ion - Single Fault Safe - Deep Discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S DHF/DMR/MDF for a software-only, cloud-based, single-instance device Medical Information Technology, Medical Software and Health Informatics 2
N Is this a single integral drug device combination product EU MDR CE Marking (Conformité Européene) / CB Scheme 1
R CND nomenclature for single use instruments CE Marking (Conformité Européene) / CB Scheme 1
P Violation of CE mark - Re-use of single-use Products CE Marking (Conformité Européene) / CB Scheme 2
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
shimonv Single lot release for sterile packaging 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
T Single Fault Condition IEC 60601 Clause 8.7.1 shorting Cr/Cl in Patient Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Sidney Vianna Informational IAF and ILAC Seek Contractor for Establishment of a Single International Organization for Accreditation ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
F UDI - Unit of Use and Class I, single-use devices EU Medical Device Regulations 5
A Single use non-sterile syringe used in the oral cavity - Laboratory test advice US Food and Drug Administration (FDA) 7
D How to get EUDAMED Single Registration Number (SRN) EU Medical Device Regulations 19
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K Does company who manufacture but does not design or carry out clinical trials is responsible for CE marking for single use medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 4
F 2017/745 Article 31 Single Registration Number Medical Device and FDA Regulations and Standards News 5
M Informational EU draft act – Single-use medical devices – safety and performance requirements for reprocessing Medical Device and FDA Regulations and Standards News 0
Q IATF rule for single site - Ingots from scrap metal recycling company IATF 16949 - Automotive Quality Systems Standard 0
R Supplier Controls we can place on Single-Source Suppliers ISO 13485:2016 - Medical Device Quality Management Systems 2
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 22
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
Ed Panek Can a single supplier fit two or more categories for risk? ISO 13485:2016 - Medical Device Quality Management Systems 2
T No Defined Shelf Life/Expiration Date - Disposable single-use, non-invasive, non-sterile Other Medical Device Regulations World-Wide 2
F Reprocessing or refurbishing? Single Use Medical Device CE Marking (Conformité Européene) / CB Scheme 0
