SMT (Surface Mount Technology) and PCBA Process Validation
pseudoazurin
Hi, Would anyone by chance have a sample/template for validation protocol/validation master file for SMT process and/or PCBA that can be shared.
Thanks.
Ronen E
Problem Solver
Moderator
Thanks.
Are the processes you're looking to validate Special Processes, i.e. their results* can't be practically consequently verified (tested, inspected etc.)?
*) Fulfilment of predetermined requirements.
S Calibration of SMT (Surface Mount) Assembly Machines Calibration Frequency (Interval) 13
J PFMEA example for SMT (Surface Mount Technology) FMEA and Control Plans 9
Marc SMT (Surface Mount Technology) Sampling Plan in a SMT & COB Assembly Company Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S 100% Inspection Control Chart By Dr. Feigenbaum - SMT (Surface Mounting Technology) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Silver Plating corroding possible during SMT Manufacturing and Related Processes 10
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
alonFAI SMT machine specifications and performance meet the requirements for our production Manufacturing and Related Processes 2
M Spreadsheet on How to Calculate SMT Capacity wanted Manufacturing and Related Processes 2
M Failure Analysis on Cracking SMT Capacitors Problem Solving, Root Cause Fault and Failure Analysis 7
J "Testing procedure: TMP", "WMT", "SMT" and "RMT" - IEC 60601-1 TRF nomenclature IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J International Standard for SMT and Electronic Assembly for Luminaire Product Other ISO and International Standards and European Regulations 3
K Use of Vacuum Pens to hold SMT Components in Electronics Industry Manufacturing and Related Processes 3
Q SMT Final Inspection Sampling Plan for boards off an SMT line Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
W SMT resistor not wetting - Have you seen this before? Reliability Analysis - Predictions, Testing and Standards 6
M Incoming (Receiving) Inspection of SMT components Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Q SMT Related Issues - Baking Moisture Sensitive Components Manufacturing and Related Processes 13
Z SMT and Sheet Metal Supplier Process Audit Checklist Supplier Quality Assurance and other Supplier Issues 5
V SMT Mounter: 2 general questions (air release pressure & machine history) Manufacturing and Related Processes 5
S What Capability Index should I use? SMT Application Capability, Accuracy and Stability - Processes, Machines, etc. 13
K How to control SMT pad/trace damage and how to determine root cause? Problem Solving, Root Cause Fault and Failure Analysis 1
R Cp, Cpk calculation for np chart - No USL or LSL - SMT Production Capability, Accuracy and Stability - Processes, Machines, etc. 16
S Surface roughness Rz Manufacturing and Related Processes 1
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
P Surface scratch measurement General Measurement Device and Calibration Topics 1
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 9
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
S ARP 1820 Surface Contamination Testing Various Other Specifications, Standards, and related Requirements 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Component Failure (Relay) during ICT Testing after Surface Mount Assembly Manufacturing and Related Processes 5
