Software Validation for Equipment - Question
PeterLe
Our Quality group has identified a few pieces of equipment within our company that requires software validation. These pieces of equipment do have custom software. We also have an SME that is responsible for completion of these software validations.
I gave the SME the list of equipment that needs software validation and the SME comes back with the following responses for the equipment:
These equipment all have successful process validations on file, which means their operating software has been shown capable of meeting functional requirements. If current operating software is already in Doc Control, that addresses this item. If not in Doc Control, DCO current operating software now.
Equipment Qualification should demonstrate that the operating software is capable of meeting functional requirements. That should suffice to cover the software validation gap.
Basically he’s claiming since the equipment has gone through equipment qualification and/or process validation, that the equipment has met functional requirements thus not needing software validation.
I’ve looked at a couple of the equipment qualification protocols and nothing in the protocol explicitly states that software will be tested.
How should I approach this and especially what are your thoughts regarding his response? Thank you so much!
Marcelo
Re: Question Regarding Software Validation for Equipment
The response makes no sense regarding the requirement of software validation.
ISO 80002-2 Medical device software -- Part 2: Validation of software for medical device quality systems will be published in a while. It was created to help manufacturer fulfill the ISO 13485 software validation requirements.
It uses a risk-based approach to software validation.
PeterLe
Thank you for your responses!
Just to be clear on my understanding, if none of the process validation protocols or the equipment qualification protocols/reports explicitly tests the software, then my colleagues response doesn't hold correct?
On the other side, if the protocols/reports does state it will test the software then my colleague's response holds.
Again, many thanks for your responses!
Ajit Basrur
I would suggest you to go through the FDA Guidance Document to get a better understanding on the software validation. You mention that there is a custom software and thus the complexity increases.
There is GAMP 5 document that categorizes software into 4 categories - Category 1 for Infrastructure, Category 3 for Commercially Off the Shelf (COTS), Category 4 for Modified off the Shelf (MOTS), and category 5 for custom or bespoke systems.
The requirements for the custom software is intense and typically shall follow different stages namely,
User Requirements
Functional Requirements
Design
Construction or Coding
Testing by the Software Developer
User Site Testing
The Process Validation may be done as part of the user site testing. In addition, ensure procedures related to change control, or any other maintenance are in place.
yodon
Ajit (as he always does) hits the nail on the head. Software validation is more than just testing. It should consider the entire life cycle, including consideration of how to keep the software in a validated state when things are changing (the software itself, support software packages the SW uses, the OS on which it runs, the hardware on which it runs, ...)
V PQ parameters for computer system validation of configurable software of laboratory equipment Qualification and Validation (including 21 CFR Part 11) 0
D Software validation in Medical Equipment Other Medical Device and Orthopedic Related Topics 20
S Validation of COTS Equipment plus Software Qualification and Validation (including 21 CFR Part 11) 12
R FDA Requirements - Printing Equipment Software Validation Qualification and Validation (including 21 CFR Part 11) 1
R CLIA Equipment or Software Validation Requirements Qualification and Validation (including 21 CFR Part 11) 5
F Aged Inspection Equipment Software has no Audit Trail - Validation of Software Qualification and Validation (including 21 CFR Part 11) 5
C Equipment, Software and Processes Validation for Medical Devices - 21CFR 820.75 (a) ISO 13485:2016 - Medical Device Quality Management Systems 35
S Need guidance for Software validation Qualification and Validation (including 21 CFR Part 11) 5
Ed Panek Validation of Signature Software (Off the shelf) US Medical Device Regulations 6
M Software Validation SAP B1 for ERP ISO 13485:2016 - Medical Device Quality Management Systems 2
P Software validation for FPGA Software Quality Assurance 1
M 3D Scanner Software validation ISO 13485:2016 - Medical Device Quality Management Systems 7
D Software Validation Question ISO 13485:2016 - Medical Device Quality Management Systems 10
C. Tejeda Computer system validation approach for Minitab Statistical software Software Quality Assurance 11
John C. Abnet ...validation of computer software ISO 13485:2016 - Medical Device Quality Management Systems 17
B ERP software validation - risk assessment vs validation scope ISO 13485:2016 - Medical Device Quality Management Systems 11
R Validation of Software used in Verification Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
Watchcat Software validation vs design V&V? Other US Medical Device Regulations 27
M Initial Importer/Distributor and Software Validation IEC 62304 - Medical Device Software Life Cycle Processes 1
E ISO 13485 software validation ISO 13485:2016 - Medical Device Quality Management Systems 7
Y ISO 13485:2015 Software Validation IQ/OQ/PQ ISO 13485:2016 - Medical Device Quality Management Systems 13
R Debug mode in software/device validation IEC 62304 - Medical Device Software Life Cycle Processes 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P Software verification and validation procedure IEC 62304 - Medical Device Software Life Cycle Processes 6
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
D Software validation team Misc. Quality Assurance and Business Systems Related Topics 3
silentmonkey Rationalising the level of effort and depth of software validation based on risk ISO 13485:2016 - Medical Device Quality Management Systems 10
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 16
K ERP System Software Validation - ISO13485 2016 4.1.6 Design and Development of Products and Processes 11
C Looking for simple Software Validation IQ templates. Qualification and Validation (including 21 CFR Part 11) 4
C Software validation - Off The Shelf Software - Web hosted ISO 13485:2016 - Medical Device Quality Management Systems 6
R Validation of Medical Device Hardware containing Software - How many to Validate ISO 13485:2016 - Medical Device Quality Management Systems 1
F 21 CFR Part 11 - Implicit requirements - Validation plan for a Software as a Service Other US Medical Device Regulations 1
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
D Software Validation - Contract manufacturer of Components (PCBA's) Qualification and Validation (including 21 CFR Part 11) 7
Pmarszal Software Validation Training Course - Recommendations Training - Internal, External, Online and Distance Learning 3
T Software Validation Certificate (ISO 13485:2016) ISO 13485:2016 - Medical Device Quality Management Systems 19
G Windows 10 OS build Software Validation US Food and Drug Administration (FDA) 1
S Where to keep Enterprise Resource Planning software (ERP) Validation Records ISO 13485:2016 - Medical Device Quality Management Systems 1
C Software validation (4.1.6 ISO 13485:2016) ISO 13485:2016 - Medical Device Quality Management Systems 20
M Software Validation Guidance Suggestions Various Other Specifications, Standards, and related Requirements 6
S QMS software validation - Documentation ISO 13485:2016 - Medical Device Quality Management Systems 5
A SOP for software validation of software in medical device IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 5
R CNC Software Validation requirements as per ISO 13485:2016 Other ISO and International Standards and European Regulations 8
R Software validation - off the shelf X-Ray Software Quality Assurance 3
S What is the clause in ISO 13485 for SAP Software Validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
