Solder Pot Standards - Solder Pot Adherence
CFHill
I'm trying to find a standard or 2 to use for our solder pot adherence. We are ISO9000 but have AS9100 requirements from some customers. I'm looking for the tighter of the standards that I can implement to keep us audit safe.
howste
Thaumaturge
Re: Solder Pot Standards
I don't claim to be an expert on solder pots, but our solder pot work instruction references J-STD-001. Our QMS is certified to ISO 9001 and AS9100.
CFHill
Thank you, I'll pull it up. I'm new at this company and the pots are at various stages as noted on tags. I'm trying to get some consistency.
smonsalve
Neither standard will tell you what to do regarding pots. Read J-STD-001 for more information. We are ISO/AS and work with J-STD-001. We control our pots with a form that controls the time between solder changes and usage it also says if the pot is leaded solder or lead free solder.
CFHill
You are correct. I read through both specifications and solder pots are not specifically noted. I did inquire about setting controls as you mentioned and it was accepted. Now I just need to set them up.
Thank you for your response. Learning the electronic industry is an upward hill climb!
howste
Thaumaturge
Solder pots are mentioned once in J-STD-001 Rev F in Appendix A, which is labeled Guidelines for Soldering Tools and Equipment:
A-6 SOLDER POTS
Solder pots should maintain the solder temperature within ± 5°C [± 9°F] of the selected temperature. Solder pots are to be grounded.
As it's labeled as "guidelines" and uses the word "should," I can't say they're requirements, but I would comply anyway.
smonsalve
Don't forget to include your solder pot in the calibration schedule.
Thanks for mentioning calibration! You may get the question asked about the temperature from an auditor... How do you know that the temperature is correct? Perhaps it is a new digital type - it may still need to be "Verified" (Temperature on display is temperature in pot) at prescribed intervals with probes appropriate for the temperature.
The other issue and it may also fall under calibration / verification is the solder mixture. Most all solders are not 100% lead they are a mixture of lead (Pb) and Tin (Sn) typical would be a blend such as 63/37. 63% Tin and 37% Lead or 60/40 same principal. So, where this is going is when you first put solder in the pot most likely it is in balance (63/37) then as you use the pot and/or it is left heated up all day, certain metals burn off or get used up and the pot will end up out of balance. What this does is take us down another slippery slope... Now, how can you assure that what ever you are soldering is still acceptably soldered?
This now falls into the dreaded "Process Validation" definition. :bonk:
I would suggest doing a full fledged IQ/OQ/PQ on the solder pot soldering process, including trials at different times like after pot is used for 1 week - will you still be soldering with the solder mixture you started with?
Just by looking you will not be able to tell unfortunately the solder is in balance. Based on risk and who the end customer is you may have to send out solder samples from the pot at various times to determine when it will go bad on you. Also this would be your process for calibration - seeing what the mixture is then making adjustments by adding Lead (Pb) or Tin (Sn) then testing until in balance. Other people find out how many hours/days/weeks before solder balance begins to drift then they just routinely just dump the whole pot and start all over with new solder.
*I used the example of leaded solder because of the simplicity, if you are using lead free solder like a SAC 305 you do not have (Pb) but you have 3 metals Sn, Ag, Cu. (More to keep in balance) :nope:
If you are lucky enough to have an XRF gun in house checking solder is quick and painless... You can send out solder samples to the solder manufacturer or if you are on the cheap go to a jewelry store or other place that buys gold, they often have an XRF gun and can shoot your solder sample maybe for free maybe for a few bucks.
So, between the temperature and the solder balance - Thinking that you can just plug in the solder pot add solder and you are all set is a huge misconception. :popcorn:sorry for the epic book, perhaps it will help someone.
CFHill
This is great. Thank you for the book. Being 85% Mechanical this electronic stuff is filling my every waking moment. Very interesting I'll say.
The solder pots is one of many items I was concerned with regarding calibration and controls. Your response has certainly assisted in my push to get them reviewed.
Thank you,
Carol
JamesBarnhart
Solder pot is portable and primarily used for melting solder, dip soldering small circuit boards and re-tinning soldering iron tips. It is very useful for smaller jobs where reliable control of soldering temperature is essential. Solder pots includes dross skimmers.
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 8
E Solder thermal profiles for PPAP - Automotive IATF 16949 - Automotive Quality Systems Standard 1
L Replacement of SAC305 Solder for SN100C Lead Free Solder? Manufacturing and Related Processes 1
B RoHS Directive 2014/5/EU Leaded Solder Exemption RoHS, REACH, ELV, IMDS and Restricted Substances 2
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
D Will A Few Failed Solder Joints Make Me RoHS Non Compliant? RoHS, REACH, ELV, IMDS and Restricted Substances 9
P Does lead free solder rust? Manufacturing and Related Processes 1
alonFAI SMI (Solder Paste Inspection ) Inline Work Instruction (Procedure) Manufacturing and Related Processes 3
somashekar Am I good to claim RoHS for my product? Solder Content RoHS, REACH, ELV, IMDS and Restricted Substances 8
A How are Storage Requirements Determined for Epoxy, Paste, Solder, etc. ISO 13485:2016 - Medical Device Quality Management Systems 6
J MSA For Solder Paste Inspection Machines Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
G How to confirm if the Solder used contains Silver? Manufacturing and Related Processes 7
R Spacing between the solder eyes of the fuse input/output leads IEC 60601 - Medical Electrical Equipment Safety Standards Series 17
K Calibration Vendor for Wave Solder Optimizer/Profiler General Measurement Device and Calibration Topics 4
U Validation of Wave Solder Process - PCBA for Medical Products Qualification and Validation (including 21 CFR Part 11) 7
C Can SEM or other methods tell if reballed Solder spheres are Leaded or RoHS Manufacturing and Related Processes 3
L Sample of Solder supplied with PCB by supplier - What is this sample for? Manufacturing and Related Processes 9
B How to Determine the Proper Solder Class Manufacturing and Related Processes 5
S Which type of study would be better for Solder Paste Height Measurement system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
P Design an experiment to optimize the PCB solder reflow profile Design and Development of Products and Processes 4
D Need help on correct material composition of solder resist or solder mask in PCB for APQP and PPAP 1
C Plating process not covering solder, any ideas? Manufacturing and Related Processes 4
B Mix of leaded & leadfree components - Affected Solder Joints Quality - Vibration Manufacturing and Related Processes 3
Q Qualifying Persons to Reflow Solder by hand - Circuit boards Various Other Specifications, Standards, and related Requirements 3
1 IPC/EIA J-STD 001 to 004 for Solder Specification Various Other Specifications, Standards, and related Requirements 9
S Hand Solder Board/Component Temperature Requirements for Repair Various Other Specifications, Standards, and related Requirements 7
J Gage R&R - Operators scanning in defect codes - PCB w/various solder joint defects Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Shelf life control - Examples: solder paste, moisture sensitive device, epoxy Nonconformance and Corrective Action 3
A Solder Technician / Inspector - How to get Certified to NASA-STD-8739.3(.7) Professional Certifications and Degrees 12
R IMDS (Automotive MSDS) for Lead Free Components and Solder RoHS, REACH, ELV, IMDS and Restricted Substances 10
C Flow Solder Control Chart - I believe I need an Xm-R chart Statistical Analysis Tools, Techniques and SPC 3
C PCB (Printed Circuit Board) Assembly - Wave Solder Capability Statistical Analysis Tools, Techniques and SPC 6
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
P POT of standard/catalogue parts supplier VDA Standards - Germany's Automotive Standards 0
R Will multi-time flashovers constitute a failure of Hi-Pot test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
rob73 A "sieve" inside a pot for seperating Tissues from Fluids - IVD or not? EU Medical Device Regulations 6
J Does section 19 of IPC/WHMA-A-620A require Hi-pot testing of all cables? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D MSA for Attribute data - Automatic Hy-pot test machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
L SPC on Wave soldering machine - Cp and Cpk analysis - Soldering pot temperature Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
M Why are EU harmonized particular standards so old & out-of-date? IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
M MDR harmonized standards EU Medical Device Regulations 3
C Appendix Z in Harmonised Standards? EU Medical Device Regulations 13
Ajit Basrur Corporate management standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
