Solder thermal profiles for PPAP - Automotive
E
Ed_Porter
Hello all:
Looking for advice.
I work for a Tier 1 automotive supplier that manufactures shifter assemblies and electronic transmission pump controls.
Our OEM customer is now requiring solder thermal profiles from out process and from our suppliers that supplier PCBAs. This used to be proprietary information. Has anyone here ran into this, and how did you handle it?
Thank you in advance.
outdoorsNW
Most PCB assembly shops consider profiles to be proprietary. I would push back. If the customer insists, make the information something that can only be viewed at your company.
Viewing at the supplier’s site only is something other cove posts have recommended for proprietary information.
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 8
C Solder Pot Standards - Solder Pot Adherence Various Other Specifications, Standards, and related Requirements 9
L Replacement of SAC305 Solder for SN100C Lead Free Solder? Manufacturing and Related Processes 1
B RoHS Directive 2014/5/EU Leaded Solder Exemption RoHS, REACH, ELV, IMDS and Restricted Substances 2
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
D Will A Few Failed Solder Joints Make Me RoHS Non Compliant? RoHS, REACH, ELV, IMDS and Restricted Substances 9
P Does lead free solder rust? Manufacturing and Related Processes 1
alonFAI SMI (Solder Paste Inspection ) Inline Work Instruction (Procedure) Manufacturing and Related Processes 3
somashekar Am I good to claim RoHS for my product? Solder Content RoHS, REACH, ELV, IMDS and Restricted Substances 8
A How are Storage Requirements Determined for Epoxy, Paste, Solder, etc. ISO 13485:2016 - Medical Device Quality Management Systems 6
J MSA For Solder Paste Inspection Machines Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
G How to confirm if the Solder used contains Silver? Manufacturing and Related Processes 7
R Spacing between the solder eyes of the fuse input/output leads IEC 60601 - Medical Electrical Equipment Safety Standards Series 17
K Calibration Vendor for Wave Solder Optimizer/Profiler General Measurement Device and Calibration Topics 4
U Validation of Wave Solder Process - PCBA for Medical Products Qualification and Validation (including 21 CFR Part 11) 12
C Can SEM or other methods tell if reballed Solder spheres are Leaded or RoHS Manufacturing and Related Processes 3
L Sample of Solder supplied with PCB by supplier - What is this sample for? Manufacturing and Related Processes 9
B How to Determine the Proper Solder Class Manufacturing and Related Processes 5
S Which type of study would be better for Solder Paste Height Measurement system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
P Design an experiment to optimize the PCB solder reflow profile Design and Development of Products and Processes 4
D Need help on correct material composition of solder resist or solder mask in PCB for APQP and PPAP 1
C Plating process not covering solder, any ideas? Manufacturing and Related Processes 4
B Mix of leaded & leadfree components - Affected Solder Joints Quality - Vibration Manufacturing and Related Processes 3
Q Qualifying Persons to Reflow Solder by hand - Circuit boards Various Other Specifications, Standards, and related Requirements 3
1 IPC/EIA J-STD 001 to 004 for Solder Specification Various Other Specifications, Standards, and related Requirements 9
S Hand Solder Board/Component Temperature Requirements for Repair Various Other Specifications, Standards, and related Requirements 7
J Gage R&R - Operators scanning in defect codes - PCB w/various solder joint defects Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Shelf life control - Examples: solder paste, moisture sensitive device, epoxy Nonconformance and Corrective Action 3
A Solder Technician / Inspector - How to get Certified to NASA-STD-8739.3(.7) Professional Certifications and Degrees 12
R IMDS (Automotive MSDS) for Lead Free Components and Solder RoHS, REACH, ELV, IMDS and Restricted Substances 10
C Flow Solder Control Chart - I believe I need an Xm-R chart Statistical Analysis Tools, Techniques and SPC 3
C PCB (Printed Circuit Board) Assembly - Wave Solder Capability Statistical Analysis Tools, Techniques and SPC 6
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
V Regrinding Material - Thermal properties Manufacturing and Related Processes 4
x-files [Thermal Power plant KOSTOLAC, SERBIA] Sucessfully certified to ISO 50001 Sustainability, Green Initiatives and Ecology 1
x-files [Thermal powerplant] Why "Generation of electricity" is a special process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
x-files Thermal Powerplant - 7.5.3 Identification and Traceability ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Thermal Sensitivity Testing - Heat Lamp - ILY - Increased blood circulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
x-files [Exclusions] 7.3 Design and development vs. Thermal Powerplant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
x-files Global Timeline Plan of IMS/QMS Activities for a Thermal Power Plant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc Acronym CTE - Coefficient of Thermal Expansion Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O AECQ 200 Revision D vs. Revision C - Thermal Shock & Thermal Cycling Other ISO and International Standards and European Regulations 2
U Is there such a thing as 1-part thermal cure epoxy? Manufacturing and Related Processes 11
J IPC-A-610 E Thermal Plane Acceptance Criteria for D-Pak Component Other ISO and International Standards and European Regulations 2
M Transport Vehicle Thermal Regulation - How would you interpret this requirement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Transformers and Thermal Cutouts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R If two thermal cutouts required for water cooling system? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
O Thermal Shock Test with conditions specified in AEC-Q200 Various Other Specifications, Standards, and related Requirements 3
M Diebond adhesive blowholes seen after thermal curing on chip to plastic bottle mount Manufacturing and Related Processes 4
