Soldering Training (specific to Rework and Repair of PCBs) - Long Island
Bunny
Can anyone recommend a good source to contact regarding soldering training (specific to rework/reapir of PCBs) on Long Island?
Raffy
Re: Solder Training
Hi Bunny,
If I am not mistaken, what you need is an authorized trainer for the Soldering, I think there are so many trainers here you can find with regard to IPC. There's one thing I know is IPC Specialist, certifying somebody for the Acceptability of Electronic Assemblies.
Hope this helps.
Best regards,
Raffy :cool:
While they are not (to my knowledge) based in the Long Island area, when I was still in Production a couple years ago we had a really good consultant come out and train some of us, explain the principles, and really help us finalize our process parameters for soldering operations. The gentleman was fom a company called Blackfox; I just took a look at their website and it seems like a strong lead you might want to check out. Hope this helps. :2cents:
soldertraining
:agree: There are so many certified Companies and Institutes that can provide a wide variety of PCB rework and services. Whether it is a BGA, QFN, LGA or other surface mount or throughhole component. Here is the BEST certified Institute that can provide the expertise in soldering and the proper acceptance criteria associated with each device.
JamesBarnhart
:agree: There are so many certified Companies and Institutes that can provide a wide variety of PCB rework and services. Whether it is a BGA, QFN, LGA or other surface mount or through-hole component. Here is the BEST certified Institute that can provide the expertise in soldering and the proper acceptance criteria associated with each device.
Yes, I also like to suggest BEST Inc for Solder Training and IPC Certification because at BEST, training is provided according to the IPC specified standards. Technicians at BEST are IPC certified as well.
J ESD and Soldering Training Supplier Recommendations Needed Training - Internal, External, Online and Distance Learning 7
Manix Soldering Charts and Training - Recommendations Please Manufacturing and Related Processes 1
M Looking for Electronics Hands on Training Material - ESD, Comp ID, Soldering, etc Training - Internal, External, Online and Distance Learning 8
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
S How do I do a Process Validation for soldering process Manufacturing and Related Processes 5
shimonv Soldering Station Accuracy out of specification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Connector Tin Plating Peel-off during Soldering Manufacturing and Related Processes 7
D Nadcap Certification for Soldering Iron? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A RoHS Compliant Component = Re-Qualified for Lead-Free Soldering? RoHS, REACH, ELV, IMDS and Restricted Substances 3
M Process Validation for Manual Soldering for a Medical Devices Qualification and Validation (including 21 CFR Part 11) 4
B Safe Disposal of No Clean Soldering Flux in NY State Manufacturing and Related Processes 6
B Effect of Soldering on Tin Plating Manufacturing and Related Processes 5
C How do you Validate Solderability of Components Prior to Soldering Operations Manufacturing and Related Processes 5
S ESD Flooring Requirements - Seperate room for soldering process and assembly Manufacturing and Related Processes 5
B Looking for Photos of Surface Mount Device (SMD) Soldering Manufacturing and Related Processes 14
B IPC810 Class II vs Class III Requirements for Reflow and Wave Soldering Manufacturing and Related Processes 3
A Medical Device Regulations - FDA Soldering 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Soldering Iron Temperature Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
Q Soldering and AS9100 - Are soldering irons "monitoring and measuring equipment"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T How to define the measurement technique and control method for manual soldering FMEA and Control Plans 10
R CQI-15 Welding System Assess. & CQI-17 Special Process: Soldering Various Other Specifications, Standards, and related Requirements 6
N Control of Special Processes - Welding & Soldering - The Great Debate - 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
M Soldering Process Validation Qualification and Validation (including 21 CFR Part 11) 3
P Using Mil-STD-2000A as soldering specification Various Other Specifications, Standards, and related Requirements 14
A Control of Soldering Irons and Soldering Stations Manufacturing and Related Processes 18
J Soldering Standard which shows good and bad soldering Document Control Systems, Procedures, Forms and Templates 5
W Soldering Standard - What is the soldering standard used for medical devices? ISO 13485:2016 - Medical Device Quality Management Systems 12
J Maintenance Schedule - Flow Soldering Statistical Analysis Tools, Techniques and SPC 2
Antonio Vieira PFMEA for Resistance Welding, Winding and Soldering processes FMEA and Control Plans 3
T Possibility of off-setting the temperature on a digital Soldering Iron General Measurement Device and Calibration Topics 8
S Soldering in stainless steel machined part Manufacturing and Related Processes 7
S Soldering - Operator Qualification Manufacturing and Related Processes 5
I Validation of Special Process - Soldering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Soldering specification - Seeking example of a soldering procedure Various Other Specifications, Standards, and related Requirements 4
J IPC/EIA J-STD-004 - Requirements for Soldering Fluxes Various Other Specifications, Standards, and related Requirements 3
Q Calibration of Temperature Controllers - Soldering Irons General Measurement Device and Calibration Topics 8
K Process Validation - Hand soldering of components & wires on PCB - Special Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Validation of Soldering Process - Clause 7.5.2 - my conundrum! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L SPC on Wave soldering machine - Cp and Cpk analysis - Soldering pot temperature Capability, Accuracy and Stability - Processes, Machines, etc. 11
L IPC/EIA J-STD-001 (soldering) revisions (Want to replace IPC-A-610) Various Other Specifications, Standards, and related Requirements 5
A Lead Free Soldering: Seeking Requirements for Use Information Various Other Specifications, Standards, and related Requirements 10
F Is Soldering a Special Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
J Soldering Irons - Calibration Requirements Various Other Specifications, Standards, and related Requirements 6
A Self-training or Self-studying ISO 13485:2016 - Medical Device Quality Management Systems 8
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Employees training database Document Control Systems, Procedures, Forms and Templates 4
optomist1 Rates Daily or Hourly Process Improvement Training Consultants and Consulting 2
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
S IEC60601-1 Training recommendations Training - Internal, External, Online and Distance Learning 1
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
