Some ISO 9001:2015 Forms and Templates
marjt711
Re: ISO 9001:2000 - Templates for procedures and forms
Wow, I am glad I found this forum!! it has helped me sooo much!
marjt711
Documented Information Matrix
Hello to all,
It is time for me to start giving back to elsmar forum because there was a time where I got all the resources I needed from this forum and made me succeed and get the company where I work certified to ISO 9001:2008 now we are transitioning to ISO 9001:2015. Thank you Elsmar!
:agree:
This guidance document highlights changes in the requirements for documented information, and includes tables of documented information that should be retained and maintained.
The extent of the documented information will differ from your organization to another because of to the size of organization and its activities, processes, products and services; the complexity of processes and their interactions, and the competence of personnel.
In ISO 9001:2008, the quality manual helped to establish and document the framework of your organization's quality management system while articulating those aspects of the QMS to any interested parties.
While there is no requirement for a quality manual or documented procedures in ISO 9001:2015, it is suggested that if they add value, then they should not simply be binned. You will be expected to maintain the integrity of the QMS during the transition process.
You do not need to renumber your existing documentation to correspond to the new clauses. It is down to each organization to determine whether the benefits gained from renumbering will exceed the effort involved. Neither do you need to restructure your management system to follow the sequence of and titles of the requirements. Providing all of the requirements contained in ISO 9001:2015 are met, your organization’s quality management system will be compliant.
Please comment if this benefited you in some way, I have more material to share with you.
Thank you,
marjt711
ISO 9001:2015 Correlation Matrix & Change Summary
The correlation matrix compares the new requirements of ISO 9001:2015 to the requirements of ISO 9001:2008, and provides a summary of the changes.
This document provides a matrix that correlates the requirements of ISO 9001:2015 to the new requirements of ISO 9001:2008 and should be used to determine where the new and amended clauses are located. Many of the requirements from ISO 9001:2008 are present with ISO 9001:2015.
:agree1::agree1::agree1::agree1::agree1::agree1::agree1::agree1:
Please comment, Sharing is Caring...
:agree:
marjt711
ISO 9001:2015 Gap Analysis Checklist
The self-assessment questions will help you to identify gaps between your existing Quality Management System and the requirements of ISO 9001:2015.
This gap analysis checklist highlights the new requirements contained in ISO 9001:2015, and is not intended to cover all of the requirements from ISO 9001:2015 comprehensively. The unique knowledge obtained about the status your existing quality management system will be a key driver of the subsequent implementation approach. Armed with this knowledge, it allows you to establish accurate budgets, timelines and expectations which are proportional to the state of your current management system when directly compared to the requirements of the standards.
Your organization may already have in place an ISO 9001:2008 compliant quality management system or you might be running an uncertified system. If this is the case, you will want to determine how closely your system conforms to the requirements ISO 9001:2015. The results of a gap analysis exercise will help to determine the differences, or gaps, between your existing management system and the new requirements. Not only will this analysis template help you to identify the gaps, it will also allow you to recommend how those gaps should be filled.
The gap analysis output provides a valuable baseline for the implementation process as a whole and for measuring progress.
Try to understand each business process in the context of each of the requirements by comparing different activities and processes with what the standard requires. At the end of this activity you will have a list of activities and processes that comply and ones that do not comply.
The latter list now becomes the target of your implementation plan.
:applause::agree:
Please comment if you Care, because sharing is Caring and I am giving back to Elsmar Forum. These are great tools that will benefit all of us for sure, in my case they have!
Thank you!
M Preservation of Raw Materials in ISO 9001:2015 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D ISO 9001:2015 Internal Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
S ISO 9001:2015 Project Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001:2015 Recertification Audit Timing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Is a Project Evaluation form necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna ISO 9001 News ISO/TC 176/SC 2 Listing of Approved Interpretations against ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Process capability analysis in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
