SOP or Work Instruction for PFMEA?
G
gjkoenig
We were recently audited by a new customer and were cited for not having a procedure for PFMEAs. We are a TS16949 company and generate PFMEAs during the Contract Review and include them in our PPAPs per AIAG. There is no separate procedure (SOP/WI) on PFMEA but the PFMEA Form is referenced in some of our existing SOPs. How is the PFMEA Process normally invoked/controlled in an organization? Do we need to create a separate SOP or Work Instruction in order to spell out the details from inception to monitoring or is it enough to just reference our PFMEA Form in the existing SOPs? I really do not want to create another "Procedure" if we are already covered somewhere else.
The SQE auditor also mentioned that because of having no procedure, we do not have clearly identified RPN numbers for each process that would trigger an action (corrective action). As a newbie to PFMEA, I was under the impression that it is not advisable to use threshold numbers but rather evaluate the process risks individually.
I would appreciate any comments.
gjkoenig
Stijloor
gjkoenig
This auditor is totally off-base! There is no requirement for an FMEA procedure. In addition, RPN's should not be used to trigger (or prioritize) the need for action.
Golfman25
The auditor is out of his mind. Like you, we handle it in contract review - where we basically indicate what documents we create. I suppose our "procedure" is that blue FMEA book. Cause that is what we refer to when we do them. IMO, the whole RPN thing has become a joke perpetuated by simpletons.
However, since it is a customer audit, I guess you are in trouble. Unless you can talk some sense to the guy, you'll have to come up with a "fix." Good luck.
G
gjkoenig
Thanks for the response. I don't know if it matters, but the customer audit was VDA 6.3 Process Audit. The auditor was reviewing a PFMEA included in a PPAP for one of their parts and asked for the PFMEA Plan that controls the RPN numbers. As a newbie, I was tongue-tied as we have no procedure but our PFMEA Form and risk numbers model the AIAG format.
I am becoming a little more comfortable defending our current PFMEA process in that I do not want to create a separate "procedure" but rather take note of where PFMEA is referenced in our other established SOPs.
gjkoenig
Ron Rompen
VDA 6.3 is different than TS 16949, so that may explain some (not all) of his comments. In my past experience, I have always referenced the PFMEA in my APQP procedure/process map as one of the outputs. If you state clearly in your procedure that the AIAG manual is used as the guideline for PFMEA development and maintenance, that should cover it.
As far as using RPN's to trigger actions, there are still many out there who look for a threshold number - this goes against the intent of risk analysis; you need to analyze your HIGHEST risk(s) and take appropriate action, whether they exceed an arbitrary number or not. Again, if you clearly note this in your procedure, you should be covered.
F
flagman
IMHO, a procedure, aka documented information ;), should be used to define the responsibilities (who completes the PFMEA), Authorities (who authorizes/approves the PFMEA), to define use of symbols (e.g. do you use customer symbols for critical characteristics, or your own, do your symbols "equate" to the customer's symbols via a translation table), to clarify you do not take action on the highest RPN - but rather on the highest ___, frequency of review, and so forth.
As there are other considerations for inclusion in a Procedure, you may want to write a Procedure for APQP and cover all the requirements in one document... You "might" include the sequence of work (Contract Review > PFD > FMEA > MSA > Ctrl Pln > ...), how Change Management flows back into the FMEA, and the flow of subcontractor assessment and PPAP into your own flow.
-wizuurd
:magic:
C SOP Work Instruction (Job Card) Template Revisions question Document Control Systems, Procedures, Forms and Templates 6
A Definition SOP (Standard Operating Procedure) vs. Work Instruction vs. Procedures Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 16
E SOP or system Work Instruction? Controlled Document - Where does one draw the line? Document Control Systems, Procedures, Forms and Templates 5
D Procedure Pack SOP EU Medical Device Regulations 1
M Medical Device AE Reporting SOP Medical Device and FDA Regulations and Standards News 0
LabCat Internal SOP for a validated (ISO) method? ISO 17025 related Discussions 2
L Looking for SOP Template for UDI under MDR EU Medical Device Regulations 4
Dazzur Creation of SOP for completion of forms Document Control Systems, Procedures, Forms and Templates 5
Casana Mentioning Special Characteristics in SOP FMEA and Control Plans 4
K ISO 17025 Facilities and environmental conditions SOP ISO 17025 related Discussions 6
R Good Documentation practices SOP US Food and Drug Administration (FDA) 2
D Warehouse Static Security Guard SOP Supply Chain Security Management Systems 4
M How to manage Sop's & other quality documents after business transfer Document Control Systems, Procedures, Forms and Templates 3
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S SOP Identification of Special Characteristics IATF 16949 - Automotive Quality Systems Standard 9
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 8
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
M WI vs SOP - Shipping/Receiving Document Control Systems, Procedures, Forms and Templates 3
C Language of SOPs and SOP IDs Document Control Systems, Procedures, Forms and Templates 7
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
S Converting SOP MDD to MDR Noob ISO 13485:2016 - Medical Device Quality Management Systems 5
K What to include in SOP Definitions section Document Control Systems, Procedures, Forms and Templates 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Naming of SOP doc's - Specific to Calibrations ISO 13485:2016 - Medical Device Quality Management Systems 2
E SIP/SOP requirements for USB port used for charging IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
C SOP Template needed for ISO 13485 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 9
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
N Agile SOP for SaMD IEC 62304 - Medical Device Software Life Cycle Processes 3
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 16
R Is it required to have an SOP for external audits? Medical Device and FDA Regulations and Standards News 7
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 2
B How to apply external voltage to SIP/SOP IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Sample Calibration SOP for ISO 13485 General Measurement Device and Calibration Topics 4
J Application of mains voltage on SIP/SOP connectors of medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
M What to do in SOP Phase of Head unit testing? IATF 16949 - Automotive Quality Systems Standard 0
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
W SOP examples wanted - Soil, Concrete and Asphalt testing ISO 17025 related Discussions 3
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
pashah Looking for Clinical Evaluation SOP acc. MEDDEV and EU MDR Other Medical Device Related Standards 1
M SOP Sample for BC/ISO22301 (Business Continuity) wanted Business Continuity & Resiliency Planning (BCRP) 4
M Risk/Benefit vs. benefit-risk - Revising an SOP covering Risk Management with the MDR in mind EU Medical Device Regulations 10
A How to manage the QMS system and SOP during the transition from MDD to MDR EU Medical Device Regulations 9
V Protocol, report or SOP for threshold analysis? Human Factors and Ergonomics in Engineering 0
V Nature of references allowed to be cited in the SOP US Food and Drug Administration (FDA) 2
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 7
