SOP Template needed for ISO 13485 6.3 Infrastructure
Dear,
one of he nonconformities in our latest audit was the fact that we don't have a SOP on infrastructure, so I now have to write one and need your help.
We have lots of IT-Guidelines, production instructions and machine maintenance instruction, but the Auditor wanted to see the "General, above all" document.
This is what he wrote: "According to section 6.3 of EN ISO 13485:2016, the organization shall document the requirements for the infrastructure needed to achieve conformity to product requirements, prevent product mix-up and ensure orderly handling of products. During the internal Audit such documentation which outlines
the requirements was not available."
So, as I have all the Information but struggle to put the SOP together - could you please provide a template/a copy of your SOP/whatever helps.
Thanks in advance!
yodon
The standard doesn't require an SOP; only that the requirements be documented.
What are your requirements to achieve all those things? Just document them! (Personally, I have a 'Management' SOP which contains the requirements and covers things like management review and such.)
levatorsuperioris
You should be careful to separate which items need validation, PM, calibration etc and which do not. For example, water for washing implants needs utilities qualification. Clean rooms need IQ, OQ, PQ and have periodic maintenance on hepa systems. Alot of gages and alarms need calibration and PM as well.
Calibrations are described in another SOP. What I have to cover is IT, buildings & storage, transort & logistics, machines and supply of needed media in production. We manufacture class II devices.
ThatSinc
I include these requirements in the various other procedures of the company.
The procedures for receipt of incoming goods, and the procedures for production control state that items must be placed on separate shelves and in different bins relating to their stages of processing and inspection - this is part of the infrastructure requirements for preventing mix-ups.
Enternationalist
The #1 cause of headaches where I have worked is using canned, templated or otherwise derivative SOPs. They don't fit what is intuitively best practice, and therefore quickly become nonsense in practice, and get ignored or despised - not only is this ineffective, but it also decreases confidence and commitment to the system as a whole. There is a reason a lot of 13485 requirements are generally so vague and nonprescriptive - take that as a license to tailor it to your needs as much as you are able.
Read carefully, understand the spirit, and decide where the information makes the most sense for your company practically. As others have noticed, strictly speaking, you are only required to document the requirements for these things. That does not imply an SOP or any other particular format, it just means you need figure out what you need in terms of infrastructure to achieve those minimum items (which you should already be doing in order to run a competent business) and then simply record those requirements in some way.
Logically, then, you will need to meet these requirements - so maybe follow up with a report or otherwise showing that the infrastructure exists.
One relatively proactive way to do this could be, for example, to make it part of your annual review or an internal audit to identify what infrastructure requirements have changed and need resourcing.
If you've got a massive warehouse handling tons of different products then it might be worth having some instructions and procedures around to facilitate this; but do spend some time actually considering the words of the requirement and what they entail.
Enternationalist
...and study closely what your colleagues are already doing.
This is critical. Your process should match what you're actually doing. If you're already doing a good job of infrastructure, there's no reason to alter things - just improve the documentation of what you already do. An "ideally compliant" process that's completely divorced from reality does nothing to actually improve quality.
Tagin
You might want to consider PDCA format for the high-level overview in one doc. For example, for the section on the building:
  • Building
    • Plan:
      • Building maintenance is the responsibility of XYZ Mgr.
      • To meet product requirements, the building must maintain a temp range of 65 - 75 deg F, and humidity of 40-70%.
      • The building shall be free of roof leaks, etc.
      • HVAC maintenance is scheduled biannually and records are maintained <here>.
      • Contract cleaners approved by ABC Mgr will be used for weekly cleaning off-hours, and as-needed.
      • The lighting shall be.....etc.
    • Do:
      • HVAC maintenance: see SOP-12345.
      • Cleaning crews perform weekly scheduled cleaning of all areas.
      • Etc.
    • Check:
      • Temp/humidity is monitored by Acme monitoring system, which sends an email alert to XYZ Manager if the system is over/under thresholds.
      • Monthly 5S audits monitor for cleanliness, leaks, etc.
      • Contract cleaners are also monitored in supplier review process SOP-45678.
      • Etc.
    • Act:
      • If temp/humidity is over/under thresholds, then XYZ Mgr shall immediately investigate and contract HVAC service as needed to correct the issue.
      • XYZ Mgr is responsible for addressing 5S findings related to the building in a timely manner.
      • Etc.
L Production and Process Control SOP example or template needed US Food and Drug Administration (FDA) 2
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
M SOP or template for a study to Define Storage Conditions of Orthopaedic Implants EU Medical Device Regulations 3
C SOP Work Instruction (Job Card) Template Revisions question Document Control Systems, Procedures, Forms and Templates 6
J Ever heard of having a Controlled SOP template? Document Control Systems, Procedures, Forms and Templates 12
S Required Complete calibration SOP, calibration Plan and master list template! IATF 16949 - Automotive Quality Systems Standard 3
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 2
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M WI vs SOP - Shipping/Receiving Document Control Systems, Procedures, Forms and Templates 3
C Language of SOPs and SOP IDs Document Control Systems, Procedures, Forms and Templates 7
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
S Converting SOP MDD to MDR Noob ISO 13485:2016 - Medical Device Quality Management Systems 4
K What to include in SOP Definitions section Document Control Systems, Procedures, Forms and Templates 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Naming of SOP doc's - Specific to Calibrations ISO 13485:2016 - Medical Device Quality Management Systems 2
E SIP/SOP requirements for USB port used for charging IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
N Agile SOP for SaMD IEC 62304 - Medical Device Software Life Cycle Processes 3
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 9
R Is it required to have an SOP for external audits? Medical Device and FDA Regulations and Standards News 7
B How to apply external voltage to SIP/SOP IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Sample Calibration SOP for ISO 13485 General Measurement Device and Calibration Topics 4
J Application of mains voltage on SIP/SOP connectors of medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
M What to do in SOP Phase of Head unit testing? IATF 16949 - Automotive Quality Systems Standard 0
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
W SOP examples wanted - Soil, Concrete and Asphalt testing ISO 17025 related Discussions 3
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
pashah Looking for Clinical Evaluation SOP acc. MEDDEV and EU MDR Other Medical Device Related Standards 1
M SOP Sample for BC/ISO22301 (Business Continuity) wanted Business Continuity & Resiliency Planning (BCRP) 4
M Risk/Benefit vs. benefit-risk - Revising an SOP covering Risk Management with the MDR in mind EU Medical Device Regulations 10
A How to manage the QMS system and SOP during the transition from MDD to MDR EU Medical Device Regulations 4
V Protocol, report or SOP for threshold analysis? Human Factors and Ergonomics in Engineering 0
V Nature of references allowed to be cited in the SOP US Food and Drug Administration (FDA) 2
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 3
M Charging consulting fees for SOP development and guidance Document Control Systems, Procedures, Forms and Templates 14
J Just Venting - Do you refer directly to MDR or you just refer to SOP's? CE Marking (Conformité Européene) / CB Scheme 3
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
S Should there be a SOP on Cybersecurity? ISO 14971 - Medical Device Risk Management 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
J Nonconforming product procedures SOP help :) Nonconformance and Corrective Action 2
G NIST SOP 29 - Assignment of Uncertainty - Question General Measurement Device and Calibration Topics 0
A SOP for software validation of software in medical device IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 5
S SOP Training/Competence in 24/7 Operation contractor company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K EU MDR - PMS (Post Market Surveillance) SOP - definition of "register(s)" EU Medical Device Regulations 2
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
