SOP - Unforeseen Circumstances (Waiver) Procedure
MichelleH
Hi all,
Does anyone have the experience with procedure called "Unforeseen circumstances"?
This procedure should cover every case when we have to do something outside the procedures of the QMS- there is a danger that it can be done unsafely.
This procedure was recomented by the auditor : "You need an SOP to cover how you deal with every case where the QMS does not make a provision. It needs a record document that specifies the “unforeseen circumstance” and the action that is to be taken to ensure the situation is handled safely."
Can you please provide the example for this kind of procedure?
Thank you
SteveK
Re: SOP - Unforeseen Circumstances
Hi Michelle,
Is this not a CAPA procedure or covered in one - which you should have as part of e.g. ISO 9001? The scope of my CAPA procedure states:
"This procedure applies to identified product, process, system nonconformities and problematic performance with respect to internal quality, manufacturing, customer complaints, work safety issues and discrepancies cited during internal audits and external audits (e.g., ISO, MDD, Supplier) at the company’s facilities."
i.e. Unforeseen Circumstances.
:2cents:
Steve
sagai
:lmao: what a heck is that? ROFL :lol:
It shall be the CAPA procedure, I guess.
br.
Sz.
Pancho
wikineer
Re: SOP - Unforeseen Circumstances Procedure
Hi all,
Thank you
As others, most of our "unforseen circumstances" are handled through NC and CAPA, but we also have a simple procedure called "Waiver of internal requirement" which allows senior management to waive a requirement of our QMS if it conflicts with a client requirement.
The procedure is seldom used. In one case a client decided to formally forgo review of our drawings. Our QMS does not allow manufacturing to proceed without client's signed approval on the drawings. The "Waiver of internal requirement" procedure and associated record allows us to proceed with the manufacture in this unusual circumstance.
We could, of course, modify the approval procedure itself, but then we would have a much more complex procedure that would only help cases that are extremely rare.
MichelleH
Thank you this is exactly what I´m looking for.
Sometimes our customer want us to do something which is in conflict with QMS - not approved product to be shipped, different packaging (than approved) to be used etc.
Last time our production followed customer "special" requirement (extra parts in the box) but nobody think about the risk of crushing some pieces or how to label not standard packaging (labeling based on standard box qty is done through barcodes generated automaticaly from our system).
Do you have the example of such a procedure?
Pancho
wikineer
Here's an excerpt from our procedure:
1. Request for Waiver.
If a member of the Management Committee sees the need to excuse our product from any of the requirements of the QMS because of internal conflict between that requirement and other applicable requirements, he or she may request an exemption from the internal requirement using [FO: Request for Waiver of Internal Requirement]. The waiver request must be completed and approved prior to bypassing the subject internal requirement.
2. Approval / Rejection.
Before proceeding with the waiver, the request shall be approved by a second member of the Management Committee:
2a. for the engineering process: If the waiver request involves the engineering process, or exemption in other processes from engineering requirements, only the (named executives/posts) may approve it.
2b. for (other critical processes): the waiver may be approved only by (named executives/posts).
3. Implementation.
If the exemption is
3a. Approved, the internal requirement need not be met.
3b. Rejected, the internal requirement shall be met.
4. Filing.
The approved or denied request is filed in the internal project wiki indexed on a page titled [Exemptions from QMS requirements].
The [FO: Request for Waiver of Internal Requirement] form has the following fields:
  • Project
  • QMS document
  • Waiver required
  • Why is a waiver required
  • Conditions of waiver
  • Consequence of waiver
  • Requested By, date
  • Approved By, date
sagai
Have never seen such, but it is time to learn. :)
In medical devices, as long as I saw Michelle is in that industry, I would take special care that the waiver itself not to be a documented proof of non conformance with the hell of a lot standards we have here and in its approval route the QM should be involved.
br
Sz.
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 2
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M WI vs SOP - Shipping/Receiving Document Control Systems, Procedures, Forms and Templates 3
C Language of SOPs and SOP IDs Document Control Systems, Procedures, Forms and Templates 7
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
S Converting SOP MDD to MDR Noob ISO 13485:2016 - Medical Device Quality Management Systems 4
K What to include in SOP Definitions section Document Control Systems, Procedures, Forms and Templates 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 5
D Naming of SOP doc's - Specific to Calibrations ISO 13485:2016 - Medical Device Quality Management Systems 2
E SIP/SOP requirements for USB port used for charging IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
C SOP Template needed for ISO 13485 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 9
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
N Agile SOP for SaMD IEC 62304 - Medical Device Software Life Cycle Processes 3
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 9
R Is it required to have an SOP for external audits? Medical Device and FDA Regulations and Standards News 7
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
B How to apply external voltage to SIP/SOP IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Sample Calibration SOP for ISO 13485 General Measurement Device and Calibration Topics 4
J Application of mains voltage on SIP/SOP connectors of medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
M What to do in SOP Phase of Head unit testing? IATF 16949 - Automotive Quality Systems Standard 0
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
W SOP examples wanted - Soil, Concrete and Asphalt testing ISO 17025 related Discussions 3
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
pashah Looking for Clinical Evaluation SOP acc. MEDDEV and EU MDR Other Medical Device Related Standards 1
M SOP Sample for BC/ISO22301 (Business Continuity) wanted Business Continuity & Resiliency Planning (BCRP) 4
M Risk/Benefit vs. benefit-risk - Revising an SOP covering Risk Management with the MDR in mind EU Medical Device Regulations 10
A How to manage the QMS system and SOP during the transition from MDD to MDR EU Medical Device Regulations 4
V Protocol, report or SOP for threshold analysis? Human Factors and Ergonomics in Engineering 0
V Nature of references allowed to be cited in the SOP US Food and Drug Administration (FDA) 2
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 3
M Charging consulting fees for SOP development and guidance Document Control Systems, Procedures, Forms and Templates 14
J Just Venting - Do you refer directly to MDR or you just refer to SOP's? CE Marking (Conformité Européene) / CB Scheme 3
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
S Should there be a SOP on Cybersecurity? ISO 14971 - Medical Device Risk Management 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
J Nonconforming product procedures SOP help :) Nonconformance and Corrective Action 2
G NIST SOP 29 - Assignment of Uncertainty - Question General Measurement Device and Calibration Topics 0
A SOP for software validation of software in medical device IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 5
S SOP Training/Competence in 24/7 Operation contractor company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K EU MDR - PMS (Post Market Surveillance) SOP - definition of "register(s)" EU Medical Device Regulations 2
A Definition Difference between Quality System Procedure and Standard Operating Procedure (SOP) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
J Business Impact Analysis SOP Business Continuity & Resiliency Planning (BCRP) 2
Jane's Do you have an SOP for communicating with regulatory authorities ISO 13485:2016 - Medical Device Quality Management Systems 8
D 21 CFR Part 11 - Electronic Signature Management SOP Other US Medical Device Regulations 0
