SOP Work Instruction (Job Card) Template Revisions question
cubix rube
We are a contract manufacturer that makes thousands of different parts for many different customers. We're certified to ISO 9001:2008, and ISO 13485:2003. We have a form in our system that we call a Job Card. This is what we use as work instructions for our operators on the floor. Each unique part we manufacture has its own Job Card, detailing the materials, equipment, process steps, etc.
When a new Job Card is created, it is created on whatever version of that controlled Job Card template is the current version at that time. If a part has not undergone any engineering changes, it's likely that that job card is still the original one that was developed so many years ago. This creates a situation where our current template is revision 3, however we still have thousands of other Job Cards already made up, but they are on template revision 2 or even 1, yet they are all active in our system at a time when the only current revision is technically Rev 3. First of all, is THIS a problem? If not, allow me to continue.
A change order has just come through for a part whose job card was originally produced on template rev. 1. When we revise this Job Card, can we simply revise the information that's on template rev.1, per the change order, or do we need to transfer all of that information over to template revision 3, which is the currently active version, and then update the content of that per the change order? The differences in the templates are such that it would require a lot of cutting and pasting to do it this way.
Unless there is a compelling reason to have to migrate older job cards to the newer template revision when Engineering Change Orders come through, I'd prefer to leave them in their original format, and only have to use the current form when generating a new Job Card. Would this be OK, if that's how I describe it in our QMS documentation, or is there something in the standard that would make this unacceptable?
andrev
To have more than one template for different parts(changes)pose a problem and may need some clear guidelines eg: every part/component have its own job card,which will result in more than 3 templates.
It will be less complicated to have only 1 template for all prod/comp. The change(difference) could be shown somewhere small on the job card.
Not sure if it is that simple though,but once the comments come in,your answer will too.
Tara Monson
My first question is if the template had changes large enough that a revision was necessary, why would you not want this on all your job cards?
If the revisions are not required and you are okay with using the old templates with a revision of content, why was the template even revised?
insect warfare
QA=Question Authority
Exactly my thoughts. If it is not the right template, then it is not the right template for a specific reason (tracking, added functionality, more features, etc.). A gradual phase-out of the old versions should have been properly timed and executed when the new job cards were released for use. I would suggest reviewing the ECO process and seeing where improvements can be made in this area.
Brian :rolleyes:
Spanner
At the time the ECO is raised to change the format you should think about how you implement the change. So you could say only new jobs use the new template or as jobs on old templates are revised they should be transferred to the new template. Or all jobs will be upgraded to the new template in a certain time frame. The basis for the decision will depend on what has changed on the template.
cubix rube
Thank you, Spanner. That's what I was looking for. My main concern is whether the standard requires us to revise everything, or if I have the option to word the change in such a way as to omit some from the change, and change others. We have a job card for nearly each and every unique part we've ever run for any customer, since we started in this business over 20 years ago (We do purge those that we are aware of as no longer being ordered, but this still leaves thousands in the system). Some may never be ordered again, others are ordered only once every few years or so, and others are ordered several times per month. In order to avoid revising "dead" job cards, or spending time now, to revise a job that might not run for another 2 years, I'd like to word it such that new Job cards, and job cards being revised per an ECO will be migrated, but others would be left in their original format. If anybody sees a nonconformance in my future by taking this route, please share your opinion. Thanks!
leftoverture
Cubix rube you are taking the correct path. Meeting ISO standards is about having a system that makes sense for your business. What you outlined is perfectly sensible and you have a perfectly acceptable rationale for that decision. Document it that was and move forward accordingly.
G SOP or Work Instruction for PFMEA? FMEA and Control Plans 5
A Definition SOP (Standard Operating Procedure) vs. Work Instruction vs. Procedures Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 16
E SOP or system Work Instruction? Controlled Document - Where does one draw the line? Document Control Systems, Procedures, Forms and Templates 5
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S SOP Identification of Special Characteristics IATF 16949 - Automotive Quality Systems Standard 6
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 6
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M WI vs SOP - Shipping/Receiving Document Control Systems, Procedures, Forms and Templates 3
C Language of SOPs and SOP IDs Document Control Systems, Procedures, Forms and Templates 7
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
S Converting SOP MDD to MDR Noob ISO 13485:2016 - Medical Device Quality Management Systems 4
K What to include in SOP Definitions section Document Control Systems, Procedures, Forms and Templates 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
D Naming of SOP doc's - Specific to Calibrations ISO 13485:2016 - Medical Device Quality Management Systems 2
E SIP/SOP requirements for USB port used for charging IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
C SOP Template needed for ISO 13485 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 9
C SOP unification. Revision No, Revision history Document Control Systems, Procedures, Forms and Templates 4
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
N Agile SOP for SaMD IEC 62304 - Medical Device Software Life Cycle Processes 3
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 9
R Is it required to have an SOP for external audits? Medical Device and FDA Regulations and Standards News 7
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
B How to apply external voltage to SIP/SOP IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Sample Calibration SOP for ISO 13485 General Measurement Device and Calibration Topics 4
J Application of mains voltage on SIP/SOP connectors of medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Software SOP - Use and maintenance of an ERP system Software Quality Assurance 6
M What to do in SOP Phase of Head unit testing? IATF 16949 - Automotive Quality Systems Standard 0
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
W SOP examples wanted - Soil, Concrete and Asphalt testing ISO 17025 related Discussions 3
F Linking an ISO 31000 Risk management SOP to ISO 17025 ISO 17025 related Discussions 2
pashah Looking for Clinical Evaluation SOP acc. MEDDEV and EU MDR Other Medical Device Related Standards 1
M SOP Sample for BC/ISO22301 (Business Continuity) wanted Business Continuity & Resiliency Planning (BCRP) 4
M Risk/Benefit vs. benefit-risk - Revising an SOP covering Risk Management with the MDR in mind EU Medical Device Regulations 10
A How to manage the QMS system and SOP during the transition from MDD to MDR EU Medical Device Regulations 9
V Protocol, report or SOP for threshold analysis? Human Factors and Ergonomics in Engineering 0
V Nature of references allowed to be cited in the SOP US Food and Drug Administration (FDA) 2
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 7
M Charging consulting fees for SOP development and guidance Document Control Systems, Procedures, Forms and Templates 14
J Just Venting - Do you refer directly to MDR or you just refer to SOP's? CE Marking (Conformité Européene) / CB Scheme 3
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
S Should there be a SOP on Cybersecurity? ISO 14971 - Medical Device Risk Management 1
T The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
J Nonconforming product procedures SOP help :) Nonconformance and Corrective Action 2
G NIST SOP 29 - Assignment of Uncertainty - Question General Measurement Device and Calibration Topics 0
A SOP for software validation of software in medical device IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 5
S SOP Training/Competence in 24/7 Operation contractor company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K EU MDR - PMS (Post Market Surveillance) SOP - definition of "register(s)" EU Medical Device Regulations 2
