SOPs (Standard Operating Procedures) vs. Policies, Procedures and Work Instructions
Helmut Jilling
Auditor / Consultant
#11
Re: SOPs (Standard Operating Procedures) vs. Policies, procedures and work instructio
Whatever the client organisation likes and works for them...
In general, I tend to think of them as roughly:
Level 1, Policy
Level 2, Process
Level 3, Procedure
Level 4, instruction/checklist etc. ('work instruction' if you insist)
Middle, usually - ie, procedures. Could also be processes.
Kind of confused about your use of "process" as a document. Here in the western part of the planet, we think of process as an activity, not a document. That also mirrors the ISO definition.
Does the term have a different meaning in Australia?
JaneB
#12
No. But you can document a process, not just a procedure.
For example, you could have a high-level process as a flow chart, which might be supported by one or more procedures, containing the detail.
PS. Australians consider themselves part of the western world also.
Caster
An Early Cover
#13
I tend to call documents what they are and place more importance on their purpose..
Right On. We have a level of document with a prefix of WI-SOP - whaaa?
If I ever get to build another system, things will just be called what they are.
  • design system
  • entering a PO
  • set up card for polyester clear coat
  • inspection method for ABC123
The registrars are pretty smart, they'll figure it out without the COPS, MOPS, LOPS, WI, Processes, Procedures, Manuals, and tiers.
And of course, the word quality will be replaced with the word business everywhere it pops up.
JaneB
#14
  • design system
  • entering a PO
Agree with you. That's what I do with all the quality system documents I write or help clients with. Makes a lot more sense.
And if the auditors do need a bit of help to understand it, that's one reason why they have someone to answer their questions!
But in very large and complex systems, there can well be benefit in using prefixes (SOP etc) and having a bit more formal structure to the documentation. It's easy to have a 'Entering Sales' procedure when you've only got 1 or at the most 2 documents like that, and perhaps 50 docs all up (including forms), but multiply that by a factor of 100 or even a 1000 in large businesses, and it can get hard to keep a handle on them.
#15
Yes. It's very easy for a larger system to get out of control, and that's why careful planning in the beginning is important. We need to take the "control" in "document control" quite literally, and design the system to be able to accommodate growth and complexity.
Helmut Jilling
#16
I have fond memories of my visit to Australia back in the late 1970's. Went all over. Beautiful country. Especially enjoyed Perth.
Patricia Ravanello
#17
Here's a slightly different twist on system documentation.
Apart from the commonly identified levels, I include "Records and References" as the 5th level. Records and References typically represent "input to" or "output from" any of the many processes in the company.
Records and references may be "controlled" or "uncontrolled", and of "internal" or "external" origin...(controlled external: Customer-specific requirements, customer procedures, or controlled internal: Engineering Drawings, Business Plan, Training Plan, etc.).
Each system SOP is viewed as the "parent" document, which may have any number of "offspring", or "Work Instructions", which are created only when and where there is a need for more detail.
NO Work Instruction is an orphan. Each can be linked back to it's "parent" S.O.P.
The rest is relatively self-explanantory and/or repetitive....see attachment.
Patricia Ravanello
JaneB
#18
Good stuff, Patricia, and a good diagram to illustrate. I do like your clear thinking.
RobQuality
#19
I think we will can all agree there is no right answer to this question except what is right for you and your organization. If you are ISO or TS certified, just make sure you do what you say you’re doing. Keep it simple.
To define question asked I will give my spin on it.
Level 1, Quality Manual. (I use Business System Manual) All associates in organization must embrace.)
Level 2, QSP = Quality system procedures. Documents which describe process however it does not give the details to do the job. These documents provide how the process works and references level 3 documents which provide the details to perform process. I.e. contract review, Control of quality records, Purchasing, etc..
Level 3, SOP’s = Instructions which give details on how to do the job. I break this level into several different categories. MI for Machine instructions, AI for Assembly instructions, PI’s for packaging instructions, PI’s for process instructions. I do this so I can subgroup instructions to make documents easier to access for production associates. The are the value added documents in the organization for the more time you put into these the easier it will be to train associates and identify failures in the process for root cause analysis.
Level 4, Forms = Documents which are controlled and used to provide information or record data which can impact the quality or on time delivery of the product.
I hope this helps.
Robert
2
20110108 Request
#20
Re: SOPs (Standard Operating Procedures) vs. Policies, Procedures and Work Instructio
Try using ISO 9000:2005 for document definitions and ISO/TR 10013 for guidance on documentation.
L IT - Software Development SOPs (Standard Operating Procedures) Software Quality Assurance 3
B Policies, SOPs (Standard Operating Procedures) and WIs (Work Instructions) Quality Manager and Management Related Issues 2
Q How many SOPs (Standard Operating Procedures) do I need? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Short SOPs (Standard Operating Procedures) or Add to Quality Manual? Quality Management System (QMS) Manuals 10
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
C Language of SOPs and SOP IDs Document Control Systems, Procedures, Forms and Templates 7
S EU MDR CAPA - GAP Assessment on CAPA SOPs EU Medical Device Regulations 1
S SOPs applicable for Regulatory Affairs department Other ISO and International Standards and European Regulations 1
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L Templates for three ISO 13485:2016 SOPs ISO 13485:2016 - Medical Device Quality Management Systems 8
M Referencing the MDR by name in QMS SOPs EU Medical Device Regulations 2
D QMS Documentation Process - I want to put all the Process SOPs to a QMS system Document Control Systems, Procedures, Forms and Templates 3
I Best visual description for SOPs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
S How to number and control translated SOPs - Three languages Document Control Systems, Procedures, Forms and Templates 4
M SOPs, Plans and Report templates for Clinical Evaluation of EU MDR Other Medical Device Related Standards 11
Q Any good Checklists for ensuring SOPs cover ISO 13485:2016 and 21CFR 820? ISO 13485:2016 - Medical Device Quality Management Systems 3
S How to enforce my colleagues to update SOPs? Document Control Systems, Procedures, Forms and Templates 4
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
M Are COPs, SOPs, and MOPs required by IATF 16949? IATF 16949 - Automotive Quality Systems Standard 3
S ISO 13485:2016 - How I can integrate a risk management approach in our SOPs ISO 13485:2016 - Medical Device Quality Management Systems 1
S Employee Training Matrix - Keeping track of employee training on various SOPs ISO 13485:2016 - Medical Device Quality Management Systems 4
V Periodic review criteria for reviewing/updating SOPs US Food and Drug Administration (FDA) 1
W Update of SOPs for ISO 13485:2016 / MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 28
V Which SOPs are required by GMP? US Food and Drug Administration (FDA) 2
R Training Production Employees When We Have SOOO Many SOPs Training - Internal, External, Online and Distance Learning 9
L What are some SOPs that a Quality Manager should have? Document Control Systems, Procedures, Forms and Templates 6
S Do you have all your SOPs in place vis a vis 2013/473/EU CE Marking (Conformité Européene) / CB Scheme 3
moritz Defining a good Scope for Critical SOPs ISO 13485:2016 - Medical Device Quality Management Systems 7
M Difference B/W Calibration Methods & SOPs General Measurement Device and Calibration Topics 4
R Do SOPs contained within the QSM require a "Point of Use" and/or "File In" footnote? Quality Manager and Management Related Issues 6
J Should a company create different SOPs for ISO14971? ISO 14971 - Medical Device Risk Management 1
J How do you Create SOPs for Multiple Authorities? EU Medical Device Regulations 8
N Sponsor asked to view our SOPs remotely using File Sharing Document Control Systems, Procedures, Forms and Templates 1
A ISO 13485 required high level SOPs ISO 13485:2016 - Medical Device Quality Management Systems 6
J Guidance on how often company SOPs need to be reviewed per FDA Regulations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
V SOPs and Internal Audit Criteria for Regulatory Affairs (Submissions Function) US Food and Drug Administration (FDA) 4
R SOPs in Manufacturing - Has anyone got a management process that works? Document Control Systems, Procedures, Forms and Templates 4
AnaMariaVR2 [White Paper] Writing & Enforcing Your SOPs for GxP Compliance Success Document Control Systems, Procedures, Forms and Templates 0
M SOPs for a new Cosmetic Product Development Laboratory Calibration Frequency (Interval) 1
T Does FDA consider Flow Charts sufficient instruction for SOPs? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K ROBUST Indexing System for SOPs - Recommendations wanted Document Control Systems, Procedures, Forms and Templates 8
W Chain of Custody for Documents - Preventing Misplaced SOPs Document Control Systems, Procedures, Forms and Templates 4
N Putting SOPs in place in preparation for ISO certification - where to start? Service Industry Specific Topics 5
P Essential List of SOPS for a Medical Device Development & Submission Process? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Business Process Outsourcing - Call Center QA SOPS for Telemarketing Campaigns Quality Manager and Management Related Issues 6
L Software Development and Validation SOPs Software Quality Assurance 14
D Quality Manual and SOPs for imaging core laboratory Other ISO and International Standards and European Regulations 4
B Integrating corporate's quality SOPs into our facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q COPS, MOPS and SOPS - Where is the shall? IATF 16949 - Automotive Quality Systems Standard 6
