Sorting Supplier Requirements - IATF 16949 Cl. 8.4.2.3
Hendor
Yes by IATF, we currently have suppliers sorting , and do not have ISO 9001 certificates, then we should develop their quality system?
thank you
Golfman25
Yes I believe sorting vendors would be subject to supplier development. Check the standard language. It may even mention them as being included - I can't recall right now.
Marc
Fully vaccinated are you?
The key here is the definition of "supplier development". There is a wide range of things which can be considered supplier development, some quite limited and some quite extensive. For a sorting company I would think it would be a small "project", so to speak, and I'm not sure it would be required. Usually sorting is relatively rare so an expensive, exhaustive supplier development program/effort wouldn't be of value unless you used them extensively, frequently, and if it is related to a safety item (such as airbags) critical to safety.
Golfman25
IATF is pretty clear about the development of suppliers from no QMS to full IATF certification.
Marc
Please cite the requirement(s) from the standard or sanctioned interpretations.
It is certainly NOT the requirement that all suppliers must be "developed". Consider how much that would cost. It isn't realistic.
I first got into which suppliers have to be "developed" back in the 1990's and I don't think anything has significantly changed. In addition, I have gotten a number of companies tier 2 and below to successfully only be required ISO9001 rather than full blown TS 16949, and QS 9000 before that.
I have also been involved with sort projects where the company doing the sorting wasn't even ISO 9001 (admittedly some years ago).
Also see:
Supplier Development Requirements - TS 16949
Supplier Development - TS 16949 Flow Down Requirements - Tier 2 Supplier
You may find some more specific supplier development requirements in customer specific requirements such as http://www.iatfglobaloversight.org/wp/wp-content/uploads/2016/12/IATF-16949-GM-CSR_Dec.-2016-1.pdf
Golfman25
So start with 8.4.1.1 which requires the definition of externally provided products, processes, and services to include sorting, among others.
8.4.2.3 requires those suppliers to develop, implement and improve a QMS certified to ISO, unless otherwise authorized by the customer, with the ultimate objective of becoming IATF certified. It then lists several steps, such as min. Automotive supplier criteria, compliance wit IATF, etc.
So in response to Hender's question, their sorting suppliers should be ISO or at least working toward it and eventually toward IATF.
Marc
I'll go along with that, but the real question is how far a company has to go in actually involving themselves in/with a supplier to help "develop" them. Mostly what I saw was a requirement without actual involvement. On the other hand, I have seen, and been involved in, actually visiting a (typically a critical supplier who has been experiencing problems) supplier's facility and working directly with them on their systems and processes. I bring this up, as in my post above, because I saw a lot of
...unless otherwise authorized by the customer...
where the customer agreed that, for example, TS 16949 (and formerly QS-9000) was overkill for many suppliers (not to mention simply too expensive).
When I wrote the above I was thinking of several companies which called me in to help because they were being required by a customer to register to TS 16949 or QS-9000 where the first thing we did was contact the customer and ended up with something like "Well, if you can be working towards ISO 9001 registration we'll be happy." And in none of the cases did the customer in any way help the supplier - It was simply their boilerplate requirement. So, in those cases "supplier development" meant no more than to simply place a requirement on the supplier.
The "supplier development" requirement isn't new to IATF 16949 by any means.
R Problems with Supplier - Always with 100% Sorting - No Corrective Actions Supplier Quality Assurance and other Supplier Issues 22
Anerol C Looking for sorting services at Singapore Career and Occupation Discussions 2
A Non-Conformances Found After 3rd Party Sorting Supplier Quality Assurance and other Supplier Issues 12
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
M 3rd Party Sorting and Inspection Company Certification Service Industry Specific Topics 4
Marc Sorting Forum Listings (Filterss) - 19 November 2018 Elsmar Xenforo Forum Software Instructions and Help 0
T Is Sorting a kind of Rework? IATF 16949 - Automotive Quality Systems Standard 3
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
S Can any one share the Sorting Protocol? US Food and Drug Administration (FDA) 2
B Non Acceptable % Tolerance Result - Decrease Sorting Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
AnaMariaVR2 Excel - Sorting by Product or Raw Materials [need Help] Excel .xls Spreadsheet Templates and Tools 4
A Template for Agreements with Third Party Sorting Houses IATF 16949 - Automotive Quality Systems Standard 2
T Sorting Out Attribute Data - What is this data telling me? Statistical Analysis Tools, Techniques and SPC 7
L Sorting Instruction Template wanted Document Control Systems, Procedures, Forms and Templates 5
L Sorting instruction when point out of control chart Statistical Analysis Tools, Techniques and SPC 11
C Minitab Column Sorting Issue - Invalid variable(s) to sort Using Minitab Software 9
Kales Veggie Fastener Sorting Capability Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Getting a Sorting Company ON the GM CS-2 Authorized Controlled Shipping List? Service Industry Specific Topics 10
Jim Wynne How much third-party sorting is unnecessary - War Stories Wanted Misc. Quality Assurance and Business Systems Related Topics 2
J 100% Visual Sorting Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
P Is there a TS/ISO 16949 requirement for 3rd Party Sorting companies? Customer and Company Specific Requirements 4
W Sorting in Microsoft Excel .xls - I want to create a Pareto Chart Excel .xls Spreadsheet Templates and Tools 21
P Sorting Charges - Figuring a rough way to charge suppliers for sorting Supplier Quality Assurance and other Supplier Issues 5
D MSA for Vision Sorting Equipment (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Z Gage R&R for sorting gage - Leaktester to inspect for leakrates on parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
sonflowerinwales American supplier of faulty goods into the EU After Work and Weekend Discussion Topics 2
P Product label supplier, critical or non-critical vendor ISO 13485:2016 - Medical Device Quality Management Systems 6
R 5.6.1.2 Initial Supplier Evaluation—Critical Purchases Supplier Quality Assurance and other Supplier Issues 0
A Guidance on Supplier Qualification - Phase 1 pharma manufacturing Supplier Quality Assurance and other Supplier Issues 3
S Subcontractor's subcontractor - Outsourcing of Sterilization to a sub tier Supplier ISO 13485:2016 - Medical Device Quality Management Systems 11
K "Supplier's multi-disciplinary approach to decision making" IATF 16949 - Automotive Quality Systems Standard 4
Jen Kirley Lead Supplier Quality Engineer - MR in Florence, South Carolina USA Job Openings, Consulting and Employment Opportunities 0
G Ergonomic issue caused by supplier material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Classifying a Supplier Medical Device and FDA Regulations and Standards News 3
J API Q1 - 5.6.1.2 (b) - Initial Supplier Evaluation—Critical Purchases Oil and Gas Industry Standards and Regulations 1
M ISO 13485 Supplier Question ISO 13485:2016 - Medical Device Quality Management Systems 13
S Supplier AS9100 certificate suspended - still ship goods ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Supplier change management Supplier Quality Assurance and other Supplier Issues 3
Robin H Wanted: Supplier Quality Engineer Job Openings, Consulting and Employment Opportunities 0
G Root cause for outsourced pest control service not in approved supplier list ISO 13485:2016 - Medical Device Quality Management Systems 4
A Supplier capacity analysis template IATF 16949 - Automotive Quality Systems Standard 1
L PACCAR Parts Supplier Portal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Supplier problem solving IATF 16949 - Automotive Quality Systems Standard 8
J Critical Supplier Initial evaluation for single purchases Oil and Gas Industry Standards and Regulations 16
T Supplier Evaluation - *ALL* Suppliers to business? ISO 13485:2016 - Medical Device Quality Management Systems 5
F Supplier : Product Qualification Supplier Quality Assurance and other Supplier Issues 0
M Supplier Scrap Cost Supplier Quality Assurance and other Supplier Issues 2
I Supplier Evaluation Process ISO 13485:2016 - Medical Device Quality Management Systems 4
Pmarszal Technical File - Critical Supplier List Questions CE Marking (Conformité Européene) / CB Scheme 2
W Rights of Supplier in Design & Build WP Manufacturing and Related Processes 0
