Spacing between the solder eyes of the fuse input/output leads
Roland chung
Hello folks,
According to the standard, creepage and clearance between parts of opposite polarity are required before primary fuses. But test house told me that our product failed the standard because the spacing across the surface of the PWB between the solder eyes of the fuse input/output leads is less than 3 mm. The test house said if the spacing under the fuse is too tight, the fuse would be short-circuited and therefore lose its function.
I think spacing under fuse complying with functional insulation is sufficient. As there are no requirements for functional insulation in IEC 60601-1, it seems not reasonable to require the spacing under fuse to meet 3 mm.
Could I have your opinions?
Thanks,
Roland
Pads38
That seems a confusing issue. As you say only insulation that forms a Means of Protection or is between parts of opposite polarity in the mains part have a defined requirement.
I would ask your test house to identify the exact clause they think your device does not comply with. A process that is sometimes called "show me the shall" - that is ask for direct identification of the mandatory requirement.
Roland chung
Thank you for your input.
I actually tried to argue the standard does not have specific requirement. Test house agreed with this but also said the standard does not state many other things clearly, for example, the fuse exploded is not allowed.
Peter Selvey
Moderator
Strictly speaking, creepage and clearance distances only apply to protection against electric shock, not protection against fire or other purposes. This comes from the definition of a "means of protection".
However, in a lot of switching power supplies, the fuse is an important means of protection. Generally, the circuit consists of low impedance parts up to the transformer and then the switching transistor. If the switching transistor shorts, the only reliable protection against burning out the transformer (and hence risking electric shock) is the fuse. If this is the case, the distance under the fuse can clearly be included as a means of protection and therefore creepage and clearance distances apply.
Roland chung
Thank you for your insight.
Yes, the fuse is indeed an means of protection. But the working voltage between terminals of fuse shall be close to 0 V (fuse is no different from a wire). That means no distance required. Of course, the voltage will be raised to 240V if the fuse opened.
According to the definition, working voltage shall be determined when the equipment is operating under conditions of NORMAL USE.
How do you think about it?
Peter Selvey
Moderator
Actually, it goes the other way.
One could argue that shorting the transistor is normal condition (because it is a semiconductor and the spacing between FET D-S is unlikely to meet 1 MOP). In that case the spacing of the fuse should be 2MOP!
Of course in practice, FETs are highly reliable (if used well within specification) and it is reasonable to consider it 1MOP. The fuse is then also 1MOP, making overall 2MOP.
Similar to double insulation, the working voltage for each MOP is taken as the working voltage across both parts (i.e. mains voltage).
So be careful trying to argue out of this one. The test lab is only asking for 1MOP for L-N type insulation (3mm), not full basic (4mm) or reinforced (8mm).
Roland chung
Good points. But I would think the probability of sequence events is extremely low:
1) the FET's Drain shorted to Source
2) the fuse opened
3) the spacing under fuse shorted
4) the transformer burn out and insulation system destroyed
5) people getting shocked
Peter Selvey
Moderator
The problem here is not the basic MOP theory, but more that the limit of 3mm is overkill for a printed circuit board. This is the fault in the standard.
If you follow the zero working voltage argument, no limit would apply, so even a distance of 0.1mm would be acceptable, clearly unsafe.
IEC 60664-1 says that on a PCB, a creepage distance of 1mm should be enough for 1MOP (pollution degree 2). That seems like an more appropriate limit for the situation, given as you say the full sequence of events.
Roland chung
Yup, the distance under fuse now is 2 mm. We think it is sufficent and do not want to change the circuit board. But the test lab insists on 3 mm.
G NOT spacing Internal Audits out over the year (9001) Internal Auditing 6
D Defibrillation Energy Reduction ? PWB Connector Pitch Spacing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
K Lead, Involute & Tooth spacing - Must it be certified by Accreditated Labs? General Measurement Device and Calibration Topics 6
DuncanGibbons How is the arrangement between Design and Production organisation envisaged? EASA and JAA Aviation Standards and Requirements 4
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 7
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 2
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 15
G What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 5
R Plea for advice on transitioning between Notified Bodies (label updates) Medical Device and FDA Regulations and Standards News 1
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 2
DuncanGibbons Clear differences between ISO 13485 and AS 9100D requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
H What is different between PED certificate and CPR certificate? Manufacturing and Related Processes 2
B Angle between two surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
D Variation between Faro Arms Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
P Risk acceptability alignment between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 6
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Reorganizing responsibilities between management teams and Employees in them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Compatibility between MDD and MDR devices EU Medical Device Regulations 7
S Relationship between IEC 62304 problem resolution and ISO 13485 IEC 62304 - Medical Device Software Life Cycle Processes 8
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 5
T Something between a manual and a procedure? Document Control Systems, Procedures, Forms and Templates 9
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
S Differences in CB expectations between the US and Europe Registrars and Notified Bodies 3
Ahang Separation between secondary circuit and accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
F IEC 62304 - Segregation and communication between software items IEC 62304 - Medical Device Software Life Cycle Processes 1
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
M Applicability of IEC 60950-1 Table K2 - Minimum clearances between circuits Various Other Specifications, Standards, and related Requirements 0
J Deciding between Professional Use or Lay Person IVD Test - Human fecal stool specimens Other Medical Device and Orthopedic Related Topics 1
S Is there any connection between PFMEA and Acceptance Plan FMEA and Control Plans 1
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
L Connection between IEC 62304 and Chapter 14 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
