SPC and Acceptance Sampling - Is Acceptance Sampling Obsolete?
Govind
In the last 5 years, there is not much talk about “Acceptance Sampling”. Very few articles in this subject are published in journals. On the other hand, SPC techniques are discussed in every Quality Magazine, many published papers and in conferences. Is there any Correlation to these two trends? :confused:
Has the development and rapid recognition of Statistical Process Control techniques have made the "Acceptance Sampling" almost obsolete?
Govind.
Steve Prevette
Deming Disciple
Govind.
I don't know if this is the definitive answer, but here is my theory at least.
Acceptance Sampling is primarily a go-no go test. Let me use an arbitrary, simplistic example for sake of discussion. If the bolt is longer than 3.5 mm it is bad, if it is shorter than 3.5 mm it is good. Granted, with these sort of tests I can make operator aids (a gage) or even automate the test. But acceptance sampling doesn't provide much information, which has costs.
The first cost is since the data are binary, I must sample a lot more items. If I were actually measuring the length of the bolt, I may be able to generate equal confidence levels with a lot less data.
The second cost is the go-no go nature of the specification. A bolt that is 3.49999 mm long is "good", 3.500001 is "bad". Yet both bolts are likely indistinguishable in use. The "true losses" of a bolt that is not the proper length is not a step function, but likely a parabola. This opens up the topic of the Taguchi loss function, which I will not go into detail on this post (but will if requested).
The third cost is that in attribute sampling I don't keep the time sequence of production. I simply sample 59 bolts from the bin. I could keep track of time sequence, but short of using logistic regression on this binary data, it is very difficult to trend versus time.
The use of SPC allows me to overcome much of the three problems stated above. I can determine if my production is "capable" of meeting the spec with a smaller sample. I can work to reduce variation, which would allow parts to be more of a "snap fit" and gain other savings over parts which are right at the specification limit. And I can trend versus time.
Now I have no personal knowledge if indeed "acceptance sampling" is "out" and SPC is "in". But hopefully this contributes some ideas about the differences between the two.
Steve Prevette
ASQ CQE
Fluor Hanford
City University
Govind
Steve,
Thanks for your views. I actually posted the same question in the inside Quality discussion forum. Here are the other responses:
http://www.insidequality.com/index.v3page?d_v=rm&d_mid=68919&p=9310
My theory for this trend is:
Many Quality practitioners see SPC as a real time proactive approach to process quality management and acceptance sampling as a reactive approach to product quality management. Iam not supporting this theory. There are advanced Sampling techniques that are proactive. They are published but not necessarily enter industry.
Did your reply take into consideration the "variable" Sampling as well?
Thanks,
Govind.
Tim Folkerts
I see acceptance sampling as "insurance" - paying a little to mitigate major problems.
If the situation is "healthy" - the supplier's processes are in control and producing items to spec - then the shipments coming in will automatically be fit for use. Acceptance ampling is actually counterproductive here! The money spent on testing will never find a bad lot (because there are none!) but it will occasionally reject good lots, adding costs for both consumer and producer. It is a waste of money. Just like health insurance is a waste of money as long as you stay healthy!
If the situation is "ailing" - the processes aren't in control and the shipments have varying quality - then you will get good shipments and bad shipments. Now the "insurance" is vital. Receiving an "unhealthy" shipment will cost you money and time, but it will cost a lot less than paying the price down the road for the bad situation.
I suppose you could equate the deductable to the style of sampling you do. A high deductable is like a relatively weak sampling plan (like "reduced inspection" or "Level I" in Z1.4 language). With a high deductable (weak sampling plan), the premium (testing expense) is low, but each accident (bad shipment) results in higher out-of-pocket expenses.
Just like with insurance, the amount & type of insurance depends on your lifestyle and willingness to take risks. If your business is "young and carefree", you might live a little dangerously and skip the insurance. Similarly, if you are in a "trusting, monogamous relationship" with a supplier, then you may now need as much insurance. If you take up with a new, unknown salesman every month, you might just want a little more "health" insurance. wink.gif
I suppose we couls say that SPC is like getting yearly (or in this case daily or hourly) physicals. If you check your "vital signs" on a regular basis, then your know how your health is doing and you can head off problems before they start.
OK, OK. I probably pushed the analogy a bit far, but I think it works pretty well. Preventive maintainence keeps you healthy, but a little insurance may still be a wise investment.
Tim F
Steve Prevette
Deming Disciple
Thanks,
Govind.
Yes. The basic statistical principle is that there is more information within a datum if it is actually recorded as a number, its "actual" value. You lose a lot of information (and statistical power) when you only record a result as go - no go. And yes, I can do SPC on go - no go data, but you will find the chart will tell you a lot less than when you record the data values. And for those that follow six sigma and/or want to know process capability, you have to have the data values for that.
APQP Influence on Acceptance Sampling Decline
Just a thought, but I have seen the deployment of the automotive APQP process (PPAPs, MSA, etc.) virtually eliminate acceptance sampling in my company. In fact, we have eliminated incoming inspection.
If there is an issue on the floor, the supplier must pay a penalty for lost production and pay for a 3rd party to sort 100%.
Govind
Ben,
Any specific reason why the acceptance sampling was eliminated?
To cut down inspection Cost and or The process is highly Capable?
If you had an issue on the floor, is it not too late to discover and correct the problem? Supplier covering cost is a different subject though.
You would still miss your customer delivery.
I would follow the Sampling Switching rules rather than eliminating the Sampling. How is your experience so far after elimination?
Regards,
Govind.
Govind
Tim F
Tim,
I think the analogy is appropriate and explained the benefits of Sampling and SPC in real life example. :thanx: Thanks for that insight.
I found this interesting article that talks about combining the strength of SPC and Sampling (SQC). Let me share with the forum:
Integrating SPC and SQC to Overcome Weakness in Either
http://www.isixsigma.com/library/content/c040202a.asp
Regards,
Govind.
Caster
An Early Cover
SPC good - Sampling Bad - Poka Yoke better
Here is a non statistical based answer - sorry.
Acceptance sampling starts from a desire to avoid the cost and pain of 100% inspection. It is a risk and cost based decision to find "most" of the bad ones.
The base assumption is old school (think QC, MIL STD, inspect the quality in).
SPC (as Steve has said so well starts) with a recognition that all processes have variation. If I choose to, I can roll up my sleeves and use SPC to improve my process to any capability I choose.
Both Acceptance sampling and SPC still leave bad parts as a possibility. Poka Yoke offers the impossibility of zero defects. It is really hard to do well. It is harder to convince people (especially accountants) that it can work. I have seen only 2 perfect poka yokes. Both tested in excess of 1 million parts with zero defects for the feature in question. I have seen dozens of ineffective poka yokes.
We use currently all three tools here.
I will watch this topic with interest since I now have to come up with an improved sampling scheme for x-ray inspection.
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
P SPC for machining processes Capability, Accuracy and Stability - Processes, Machines, etc. 1
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
T SPC in Insurance Back Office Operations Service Industry Specific Topics 4
C SPC for Particulate Alert/Action Levels Statistical Analysis Tools, Techniques and SPC 3
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
Q Mixed data collection (SPC) for different mold cavities Statistical Analysis Tools, Techniques and SPC 2
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
bobdoering Available SPC and Metrology Consultants Paid Consulting, Training and Services 0
I SPC on Cyclic Data Statistical Analysis Tools, Techniques and SPC 10
S SPC Card for One Sample Size - Customer requires for all critical dimensions Statistical Analysis Tools, Techniques and SPC 8
R Quality Management & SPC Manufacturing and Related Processes 1
B Is SPC data For Special Characteristics always required? TS 16949 clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How to Start SPC in a Shaft Grinding Section Statistical Analysis Tools, Techniques and SPC 1
A I-MR SPC used for Inspection Statistical Analysis Tools, Techniques and SPC 7
E SPC data from multiple Excel files Statistical Analysis Tools, Techniques and SPC 5
S Where to Get SPC Training to Measure our Processes? Training - Internal, External, Online and Distance Learning 12
P SPC Short Run Advice of a Stamping Process Statistical Analysis Tools, Techniques and SPC 3
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
