Craig H.
Hi, everyone. Maybe you can help with a problem. I did a search and don't see this discussed. The scenario is this:
We have several gram scales. Some read to .01, others to .0001. We have purchased some NIST tracable weights for each scale that are within the weight range that each scale usually measures. We are planning on having the test weight weighed every morning before the scale is used. This number will then be recorded. The whole idea of this exercise is to have the technician alert someone if the scale is "off". The question is, "off" by how much?
Through experience with a similar scheme, and a reference in a text I am trying to remember but can't, the usual XMR chart will often, sometimes almost always, be out of control. What, then, is the best approach to setting the alarm limits? I have had it suggested that the manufacturer's published accuracy should be used, but it seems to me that age, environment, etc. might make that not the best answer.
Any ideas?
Any ideas?
