SPC for machining processes
Dear Elsmar Forum Users,
In my plant we have 15 CNC machinees and produce 130 types of alu body for hydraulic pumps. Each machine has for 4 to 8 fastenings for alu body to be prepared before machining start. After operations each alu body has several holes in different diameters. Total ca 30-40 special characteristics are monitored per part.
Standard set up procedure is a follow:
1. Operator chose correct NC program No for part number he want to produce.
2. He starts machine and after machining measure first parts.
Problem is that for set up he use all available tolerance according technical specification.
If he use 75% tolerance to achieve min 1,33 Cpk the set up time will go up and deteriorate OEE.
How to correct set up of machining process to achieve required Cpk 1,33 level without OEE deterioration? How to correct set up machine if fastenings are not in line and you can adjust all fastenings at the same time but not individually.
Thanks in advance for you advice and support.
You’re barking up the wrong tree. OEE is a sub metric to on time delivery of quality parts at a profitable cost. Perhaps a better question is why do you have to meet a Cpk of 1.33? (That’s a trick question by the way). Perhaps you should be looking elsewhere for cycle time improvements?
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
bobdoering SPC for Precision Machining Presentation March 25, 2010 ASQ Central Kentucky Section ASQ - American Society for Quality 1
U Introduction of SPC - Embarking on my first implementation for precision machining Statistical Analysis Tools, Techniques and SPC 11
bobdoering SPC for Precision Machining - ASQ Presentation Imported Legacy Blogs 0
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
PQ Systems 10 Ways to Improve Your SPC System Using SQCpack Software 0
S Process Monitoring using SPC software Quality Assurance and Compliance Software Tools and Solutions 6
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
K Sr Process Engineer (Hillsboro, OR) - SPC Program Focused - Ultra Clean Technology Job Openings, Consulting and Employment Opportunities 0
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
D SPC procedure Statistical Analysis Tools, Techniques and SPC 5
PQ Systems Scaling Up? Don't Leave SPC Behind Using SQCpack Software 0
PQ Systems 5 Costly Mistakes to Avoid When Applying SPC Using SQCpack Software 0
J Spec Limits in SPC charts Statistical Analysis Tools, Techniques and SPC 24
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
Q CQI-26 SPC Short Run Supplement Capability, Accuracy and Stability - Processes, Machines, etc. 1
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
T SPC in Insurance Back Office Operations Service Industry Specific Topics 4
C SPC for Particulate Alert/Action Levels Statistical Analysis Tools, Techniques and SPC 3
