SPC for Single Batch Nickel Plating Process
AndrisSkulte
Hi fellow Covers,
We have a customer print that requires the outer diameter of a nickel plated shaft (.750" ?.00025") process to meet 1.33 CPk. The nickel plating is a single batch process done by a supplier where parts are 100% inspected after the batch plating, accepted if in-size, and lapped into size if oversize.
Per our supplier, the plating operation is not capable of plating all parts to size, let alone statistically capable without the lapping step.
Is there a statistical technique we can recommend to our customer? Or just push back stating SPC isn't valid for this process and we'll provide 100% measurement results.
Golfman25
"Or just push back stating SPC isn't valid for this process and we'll provide 100% measurement results. "
That's the route I would take. If you are doing 100% inspection, then no need for SPC. Maybe ask them what they would do if cpk wasn't 1.33. Good luck.
Steve Prevette
Deming Disciple
Just want to state - I highly disagree with the statement if you are doing 100% inspection you don't need SPC. The analysis of the measurement data will tell you how likely you are to making an out of spec part, and will also pick up on a trend towards a limit faster than waiting to exceed the limit.
AndrisSkulte
Steve - The challenge with this part is there is no opportunity to identify a trend and make a correction. It's done in one batch, all parts plated in the tank at once, twice a year.
I could see merit in mapping out the tank, seeing which areas plate heavier than others based on currents, to improve the process (and predict which 'stations' will need lapping), but that's still not SPC per the print.
Is there a statistical way to do SPC on a single batch?
Thanks for the feedback.
Steve Prevette
Deming Disciple
Yes, although there may not be a natural sequence to the parts within a batch, you can still do a data analysis that calculated the mean and standard deviation of the batch. With those results, you may still calculate the "capability" of the batch, and you could do xbar-S charts across the batches however often they occur to see if something shifts in a given infrequently made batch. If you are committed to collecting 100% of the measurement data anyway, the additional time to put them on a control chart is very minimal, especially compared to the potential benefits and avoidances.
You could also use SPC (or automated controllers) on the process itself, specifically temperature, chemical concentrations, time in tank, etc.
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
P SPC for machining processes Capability, Accuracy and Stability - Processes, Machines, etc. 1
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
T SPC in Insurance Back Office Operations Service Industry Specific Topics 4
C SPC for Particulate Alert/Action Levels Statistical Analysis Tools, Techniques and SPC 3
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
Q Mixed data collection (SPC) for different mold cavities Statistical Analysis Tools, Techniques and SPC 2
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
bobdoering Available SPC and Metrology Consultants Paid Consulting, Training and Services 0
I SPC on Cyclic Data Statistical Analysis Tools, Techniques and SPC 10
S SPC Card for One Sample Size - Customer requires for all critical dimensions Statistical Analysis Tools, Techniques and SPC 8
R Quality Management & SPC Manufacturing and Related Processes 1
B Is SPC data For Special Characteristics always required? TS 16949 clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How to Start SPC in a Shaft Grinding Section Statistical Analysis Tools, Techniques and SPC 1
A I-MR SPC used for Inspection Statistical Analysis Tools, Techniques and SPC 7
E SPC data from multiple Excel files Statistical Analysis Tools, Techniques and SPC 5
S Where to Get SPC Training to Measure our Processes? Training - Internal, External, Online and Distance Learning 12
P SPC Short Run Advice of a Stamping Process Statistical Analysis Tools, Techniques and SPC 3
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
