SPC Help - Probability of SL=CL
L
Link Xue
Spc
Hi all
I have a question, how about the probability of SL=CL in SPC study?
SL=specific limit CL=cernter limit
Any inputs appreciated.
SteelMaiden
In simplest terms (don't want to fire up any big debates) yes, your process can be running and centered on your specification limit. It's not a good thing, but it could happen. If your process is centered on the spec limit, it means that (around) half of what you are producing is out of spec.
K
ksanders
With SPC, almost anything is possible. If the process average is shifted away from nominal to a point where it becomes equal to one of the specification limits, the result is a Cpk of zero (0), and 50% of the product is being produced outside of the specification limit. Take a look at the Cp value. If the Cp value is within normally acceptable limits (1.00 or larger), then there is hope. The process average can be shifted to the print nominal, and your process will again be producing most of it's product within specification. Further refinement of the process will result in larger values for both Cp and Cpk, increading your capability.
Basic rules for Capability Ratio's Cp and Cpk:
1. Cp tell the process potential (if it were centered). This is the best your process can do at it's current state.
2. Cpk tell you how your process is currently running against it's potential.
3. Cpk can never exceed Cp. If Cpk and Cp are equal, your process is perfectly centered within the specification. Any differences between the two, is an indication of how well your process is centered within specification.
4. A Cpk of 1.33 indicates that ±4 sigma are within the specification limits.
5. A Cpk of 1.00 indicates that ±3 sigma are within the specification limits.
6. A Cpk of zero (0) indicates that nominal is equal to one of the specification limits. (At least 50% nonconforming)
7. A negative Cpk indicates that nominal is outside the specification limits. (>50% nonconforming)
I hope this will help.
L
Link Xue
In this situation, how many Sigma does it imply?
K
ksanders
Sigma is based on the variation present in the samples collected and is used to calculate the capability indecies. Capability doesn't imply sigma, it is a result of sigma as it relates to the process tolerance. The larger the tolerance relative to sigma, the better the capability. The larger the sigma relative to the tolerance, the worse the capability.
L Help with concept of PPM in SPC Statistical Analysis Tools, Techniques and SPC 6
S Can you help with a simple SPC sheet to judge if inspection is Good / No Good ? Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Errors in the AIAG's SPC manual? Need help reviewing charts. Statistical Analysis Tools, Techniques and SPC 8
C Help !! Problem of SPC on continuous variable Statistical Analysis Tools, Techniques and SPC 6
S Process Monitoring using SPC software Quality Assurance and Compliance Software Tools and Solutions 3
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
K Sr Process Engineer (Hillsboro, OR) - SPC Program Focused - Ultra Clean Technology Job Openings, Consulting and Employment Opportunities 0
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
D SPC procedure Statistical Analysis Tools, Techniques and SPC 5
PQ Systems Scaling Up? Don't Leave SPC Behind Using SQCpack Software 0
PQ Systems 5 Costly Mistakes to Avoid When Applying SPC Using SQCpack Software 0
J Spec Limits in SPC charts Statistical Analysis Tools, Techniques and SPC 24
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
Q CQI-26 SPC Short Run Supplement Capability, Accuracy and Stability - Processes, Machines, etc. 1
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
P SPC for machining processes Capability, Accuracy and Stability - Processes, Machines, etc. 1
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
T SPC in Insurance Back Office Operations Service Industry Specific Topics 4
C SPC for Particulate Alert/Action Levels Statistical Analysis Tools, Techniques and SPC 3
