SPC in Food Chain Restaurant Complaints
V
vasilist
Hello to you all once more!
Here's a case within a food chain restaurant.
I have almost 7700 QUALITY complaints since 1/1/2001 in 45 restaurants.
These complaints were declared in our phone center from delivery/take out customers.
I have gathered all in an excel sheet and the categories are :
S/N
DATE
MONTH
YEAR
DAY OF THE WEEK
CUSTOMER'S PHONE
COMPLAINT (IN DETAIL)
RESTAURANT
CATEGORY OF THE PROBLEM (E.G. FOREIGN BODY, BURNED PRODUCT...)
So far so good. From now on i am trying to use Statistics to search any special causes that "create" non conformances.
So i tried to sort all problems using the "Category of the problem" column. A simple pareto OK? After that i focus on the 20% of the categories (which is indeed generates the 80% of the problems).
After that i focus on each category trying out to find what is going on through the year (month or day). And after that i try to relate all these with each restaurant.
It is the first time i do this and i would like to know from some people who knows better than me if i am in the right way. Also (for the time being) i am not using the "power" of MINITAB. I do all the job using only excel.
Any comments? Any suggestions (especially for the use of MINITAB)?
I repeat it is the first time so i will be very gratefull for any comments. Thank you in advance!!!!
Vasilist
Al Rosen
That's 2.7 complaints/restaurant/month. Which restaurants have the most complaints? Start with the restaurants, then look at the causes.
Craig H.
Hi, Vasilist
I am working on the same type of Excel file for recording downtime for a piece of equipment. The KEY here is in how you describe the type of problem and the other items. It has to be consistent. For example "pizza" and "Burned" will not be picked up with "pepperoni pie" and "scorched". You have to decide going in what descriptive terms to use.
There will be trade-offs. Sometimes you may have information like "red rubber substance in the sauce on the eggs Benedict". Other times you might just have "red rubber contamination". So, often you have to take the lower common denominator, so to speak, until you decide which category you are going to address first.
Hope this helps.
ralphsulser
One other suggestion in addition to your category Pareto, make another one using $$ costs. That way you know where to get the biggest bang for your buck, and keep your customers as priorities too.
I agree. Subdivide the data along natural groupings such as the particular restaurant. In addition to analyzing complaints by location, do a time series plot by location to see whether an old issue has disappeared, getting worse, or staying constant. Try to normalize the data by volume if this is feasible.
V
vasilist
Dear all ,
i want to thank you for your ideas! I will come back after practising...:thanx:
vasilist
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
P SPC for machining processes Capability, Accuracy and Stability - Processes, Machines, etc. 1
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
T SPC in Insurance Back Office Operations Service Industry Specific Topics 4
C SPC for Particulate Alert/Action Levels Statistical Analysis Tools, Techniques and SPC 3
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
Q Mixed data collection (SPC) for different mold cavities Statistical Analysis Tools, Techniques and SPC 2
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
bobdoering Available SPC and Metrology Consultants Paid Consulting, Training and Services 0
I SPC on Cyclic Data Statistical Analysis Tools, Techniques and SPC 10
S SPC Card for One Sample Size - Customer requires for all critical dimensions Statistical Analysis Tools, Techniques and SPC 8
R Quality Management & SPC Manufacturing and Related Processes 1
B Is SPC data For Special Characteristics always required? TS 16949 clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How to Start SPC in a Shaft Grinding Section Statistical Analysis Tools, Techniques and SPC 1
A I-MR SPC used for Inspection Statistical Analysis Tools, Techniques and SPC 7
E SPC data from multiple Excel files Statistical Analysis Tools, Techniques and SPC 5
S Where to Get SPC Training to Measure our Processes? Training - Internal, External, Online and Distance Learning 12
P SPC Short Run Advice of a Stamping Process Statistical Analysis Tools, Techniques and SPC 3
G SPC in Heat Treatment Workshop Statistical Analysis Tools, Techniques and SPC 2
