SPC - Methods to collect data
L
luckyboyvn85
My company has NC with the following content: "the sample size is 4 pcs/ group, but current the PIC (inspector) take 4 pcs from a shot (including 4 cavities) instead 4 pcs per each cavity from 4 consecutive shots"
But SPC Manual (page 162) Method 1: Subgrouping by column (Cycle). Can help me know this NC is correct? Thank you very much. SPC MTP.png
I am not certain what you mean by NC. Please define.
This is a concept called Rational Subgrouping. You want to include items in the subroup that are similar, but exclude items that are dissimimilar. In my experience, items from consecutive shots of the same cavity are more similar than items from multiple cavities in the same shot. That is: cavity-to cavity variation is usually greater than shot-to-shot variation. In fact, the different cavities often constitute different process streams. Mixing those different streams can increase the within subgroup variation. There are several ways that you can approach this. One would be to assume that the cavities are different and select your subgroup from consecutive shots from the same cavity. The second would be to perform a hypothesis test (e.g., ANOM, 1-way ANOVA) between cavities. If the cavities are not statistically different from each other, you may then safely select your subroup samples from those cavities within the same shot.
L
luckyboyvn85
Thanks for your answer
I think that if Appendix A has instructions, I can use this sampling method (method 1) and I'm not sure about that. Thank you very much, Miner. information about ANOM, 1-way ANOVA.
Golfman25
Who issued the NC? This is minutia into your SPC system. Whether you do shot to shot (same cavity) or just 4 cavities may give you different results. Which sampling is best will probably depend on what you are trying to actually do. Good luck.
L
luckyboyvn85
NC of 3rd party audit. Thank Goflman.
As Miner said, the subgrouping is not dependent on what any manual says. The correct supbgrouping depends on the process and it’s non-homogeneity. This is the basis of rational subgrouping. SPC is not based on random sampling, convenience sampling or willy-nilly choices.
In order for us to know which subgrouping scheme is correct we would have to see the data and be able to properly analyze it.
Regardless of the advisability of your subgrouping scheme, Golfman is correct that this NC seems to be beyond the scope of any auditor.
John Predmore
One thought I had was whether there were Work Instructions how to correctly gather samples, and the operator(s) consistently did not follow company procedures, that might warrant a non-conformance. The basis of the NC should have been enumerated as the section number of the quality standard which was not adhered to.
But SPC Manual (page 162) Method 1: Subgrouping by column (Cycle). Can help me know this NC is correct? Thank you very much. View attachment 25632
Hi
Would you do me a favor and i have been your book (spc manual)?
[email protected]
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
PQ Systems 10 Ways to Improve Your SPC System Using SQCpack Software 0
S Process Monitoring using SPC software Quality Assurance and Compliance Software Tools and Solutions 6
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
K Sr Process Engineer (Hillsboro, OR) - SPC Program Focused - Ultra Clean Technology Job Openings, Consulting and Employment Opportunities 0
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
D SPC procedure Statistical Analysis Tools, Techniques and SPC 5
PQ Systems Scaling Up? Don't Leave SPC Behind Using SQCpack Software 0
PQ Systems 5 Costly Mistakes to Avoid When Applying SPC Using SQCpack Software 0
J Spec Limits in SPC charts Statistical Analysis Tools, Techniques and SPC 24
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
Q CQI-26 SPC Short Run Supplement Capability, Accuracy and Stability - Processes, Machines, etc. 1
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
P SPC for machining processes Capability, Accuracy and Stability - Processes, Machines, etc. 1
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
T SPC in Insurance Back Office Operations Service Industry Specific Topics 4
C SPC for Particulate Alert/Action Levels Statistical Analysis Tools, Techniques and SPC 3
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
Q Mixed data collection (SPC) for different mold cavities Statistical Analysis Tools, Techniques and SPC 2
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
