SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components
F
f1guru
Help, our company is new to having to do any type of spc but a new customer is requesting spc on some parts we are doing for them, does anyone have any excel spreadsheet formula for a sample size of 40 components that i can have a look at.......:notme:
Jen Kirley
Quality and Auditing Expert
Re: spc
Welcome to the cove!
I did a search in the Post Attachments List (see the green button in the header) using "SPC" key word, and was returned this list to look through.
To see some similar discussions you can view their links near the bottom of this page.
I hope this helps!
Re: SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 componen
Is there a particular reason why you would want to create a rational subgroup that large?
While subgroup sizes this large are possible, rational subgroups of this size are very rare. SPC beginners often err by creating non-rational subgroups that are too large.
F
f1guru
Yes our customer had requested that spc has to be done on the first batch of 40 components so this is what we have had to do!! Thanks for the posts i used one was on a earlier post:cool: its our first foray into aerospace work (which will hopefully be our last) so having to do this stuff is a nightmare bring back motor racing!!!
bobdoering
Stop X-bar/R Madness!!
What kind of process are you trying to implement SPC on?
F
f1guru
they want it on diameters, surface finish and perpendicularity
bobdoering
Are these precision machined diameters? If so, you would use the X hi/lo-R chart and sample 1 part at a frequency determined by your capability study. A sample of 40 parts would be meaningless, and an X-bar R chart would be a waste. It may be OK if you are not precision machining - such as drilling.
Now, unless your perpendicularity and surface finish are horrible, you also have a beta distribution on those characteristics - that is, non-normal. This is from the physical limit of 0 (perfectly smooth, perfectly perpendicular.) Again, it is difficult to understand why you would want a 40 pc sample for those characteristics. On these you might try a X-bar R chart. The only thing is the "mean" will not be centered.
f1guru: Can you clarify what you mean by "SPC on the first batch of 40 pieces"? this is strange even for aerospace companies, UNLESS the pieces are very large and they are looking for 'short run SPC' within the batch. perhaps they are looking for a capability study accompanied by a Gage R&R?
I assume you are measuring all 40 pieces after they are manufactured? or in-process?
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
N SPC charts, simple xls sheets and free software - Need newbie information Statistical Analysis Tools, Techniques and SPC 5
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
P SPC for machining processes Capability, Accuracy and Stability - Processes, Machines, etc. 1
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
T SPC in Insurance Back Office Operations Service Industry Specific Topics 4
C SPC for Particulate Alert/Action Levels Statistical Analysis Tools, Techniques and SPC 3
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
Q Mixed data collection (SPC) for different mold cavities Statistical Analysis Tools, Techniques and SPC 2
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
bobdoering Available SPC and Metrology Consultants Paid Consulting, Training and Services 0
I SPC on Cyclic Data Statistical Analysis Tools, Techniques and SPC 10
S SPC Card for One Sample Size - Customer requires for all critical dimensions Statistical Analysis Tools, Techniques and SPC 8
R Quality Management & SPC Manufacturing and Related Processes 1
B Is SPC data For Special Characteristics always required? TS 16949 clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How to Start SPC in a Shaft Grinding Section Statistical Analysis Tools, Techniques and SPC 1
A I-MR SPC used for Inspection Statistical Analysis Tools, Techniques and SPC 7
E SPC data from multiple Excel files Statistical Analysis Tools, Techniques and SPC 5
S Where to Get SPC Training to Measure our Processes? Training - Internal, External, Online and Distance Learning 12
P SPC Short Run Advice of a Stamping Process Statistical Analysis Tools, Techniques and SPC 3
