SPC (Statistical Process Control) for Unilateral Tolerance - Questions
Shivashankara
Re: SPC for Unilateral tolerance
The only difference is that one could only calculate a Ppk. This is the difference between the process average and the specification limit divided by 3 estimated standard deviations. That's about it.
One would have the same sample size -minimum 30 parts, etc.
Dear Sir ,
Mysefl Shivashankar from India , i have atatched few problem in excell shet which contains SPC quentioneries and request anyone can solve and send me back.
Shivashankara
Dear Quality Guru’s
I have Few doubt /Question on SPC study and request you all to Clarify the same.
  • One sided Tolerance (Unilateral Tolerance ) has been categorised as a two Category as below .
  • Unilateral tolerance on Geometrical Tolerances like Perpendicularity , Run out , Symmetrycity etc..
  • Unilateral tolerance on Target Dimensions like Dia 2.5+0.02, Dimn 2.3-0.03, Dimn 2.45+0.02/-0.05 etc..
  • Q1. What is the Cpk formula for ‘a’ Category ?
  • Q2. Do we required Cp as well as Cpk for both for ‘b’ category ?
  • Q3. What is the Cp /Cpk formula for ‘b’ category?
  • We do Batch process like Sintering/Heat treatment etc.. and once after completing this process we collect 50Pcs for Inspection. Here my Question is ,
Q1. What type of SPC study we need to conduct here ?
Q2. What is the Subgroup size need to consider here ?
  • As you all know there is a Hole Basis System /Shaft Basis System (HBS/SBS) like 5H6, 12f6, 7K8, etc.. My Question here is
Q1. Dia 10H6 (Dia 10+0.009mm ) , do we need Cp /Cpk both here or Cpk is enough .
Q2. What is the Cp/Cpk formula for the Above Q1.
Q3.What is the Cp/Cpk formula for 10h6 (Dia 10-0.009mm ) .
Q4. What is the Cp/Cpk formula for 10+0.005 /-0.008mm .
Please have look over these question and if you need further data , clarity , please send queries and solve these question .
It will help us to learn the process excellence.
AMIT BALLAL
SPC only considers specifications such as parallelity, perpendicularity, etc. as unilateral.
For unilateral tolerances such as Perpendicularity, parallelity, etc. calculate only Cpk/Ppk, since our target here is 0 and there can't be any reading less than 0. Cp/Pp is of no significance here, since the specification can only be more than 0. Therefore we want to check only shift(location) of the process.
Cpk formula would be USL-Xdbar/3s
For specifications such as 20 +0.02, Cp/Pp, Cpk/Ppk both should be calculated, since there is a possibility of specification being less than 20.
Cp = USL-LSL/6s
Cpk= Minimum of : USL-Xdbar/3s or Xdbar-LSL/3s
For processes where batch production happens, such as heat treatment, pressing, IMR (XMR) chart can be used. Subgroup size is considered as 2 here for calculating and plotting MR (Moving Range).
For specifications such as Dia 10H6, Cp/Pp, Cpk/Ppk both should be calculated. Eg. in case of 10H6, LSL is 10.000 and USL is 10.009. But the results can be less than 10.000 as well. Cp helps us to identify ratio of tolerance to process variation i.e. USL-LSL/6s. In this case, it can happen that the ratio is good .i.e. Variation is less than tolerance. But the results might be nonconforming (Out of specification), hence we need to calculate Cpk/Ppk to understand shift (Location) of the process.
Proud Liberal
Amit, I don't think this chart is easy to interpret.
Realizing that my changes are purely cosmetic, here's a modified version of test 6 Xbar chart (see attached Excel file for all changes) :
Removing the legend, adjusting the Y-axis scaling, and having the line labels automatically populate make it easier to see patterns in the data and focus on the story being told. I would also advocate excluding the ± 1 sigma and ± 2 sigma lines on the charts. In my option, a good chart should be able to be interpreted from "across the room".
AMIT BALLAL
Thank you so much proud liberal for help. I appreciate.
I've added 1 sigma and 2 sigma limits in order to be able to apply control chart rules to detect special causes. It depends on the user whether he wants to use it or not (depending upon application).
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
O Is SPC (Statistical Process Control) always required? Statistical Analysis Tools, Techniques and SPC 4
M SPC (Statistical Process Control) Book Recommendations wanted Book, Video, Blog and Web Site Reviews and Recommendations 1
I How to use Statistical Process Control (SPC)? Statistical Analysis Tools, Techniques and SPC 8
J Definition Control - Definition of Control in SPC (Statistical Process Control) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
T Recommend books on SPC (Statistical Process Control) Statistical Analysis Tools, Techniques and SPC 3
S SPC (Statistical Process Control) books - Suggestions and reviews please Book, Video, Blog and Web Site Reviews and Recommendations 3
O SPC Statistical Process Control with All data Using Minitab Software 4
J What SPC (Statistical Process Control) software is your company using? Statistical Analysis Tools, Techniques and SPC 15
T Touch Screen Capable Software suggestions for SPC (Statistical Process Control) Quality Assurance and Compliance Software Tools and Solutions 4
H Getting A Supplier to use SPC (Statistical Process Control) Supplier Quality Assurance and other Supplier Issues 5
P ISO 9001 requirement for SPC (Statistical Process Control) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Batguy SPC (Statistical Process Control) on Go/No-Go Checks Statistical Analysis Tools, Techniques and SPC 18
M SPC (Statistical Process Control) analysis and status on two manufacturing plants Statistical Analysis Tools, Techniques and SPC 4
V Statistical Process Control (SPC) for Clean Room Environments ISO 13485:2016 - Medical Device Quality Management Systems 6
V SPC (Statistical Process Control) for Medical Device Company Statistical Analysis Tools, Techniques and SPC 4
J Learning Statistical Process Control - I need a crash course in SPC Statistical Analysis Tools, Techniques and SPC 8
C Starting a Small Lot SPC (Statistical Process Control) program Statistical Analysis Tools, Techniques and SPC 8
I SPC (Statistical Process Control) and SQC (Statistical Quality Control) - Difference? Statistical Analysis Tools, Techniques and SPC 1
R SPC (Statistical Process Control) for Unilateral Tolerance Statistical Analysis Tools, Techniques and SPC 10
S SPC (Statistical Process Control) - I have data, now what? Statistical Analysis Tools, Techniques and SPC 14
S Reaction Plan for SPC (Statistical Process Control) Chart Statistical Analysis Tools, Techniques and SPC 4
M Is SPC (Statistical Process Control) useful? Statistical Analysis Tools, Techniques and SPC 72
C SPC (Statistical Process Control) software recommendations Quality Assurance and Compliance Software Tools and Solutions 23
J User Friendly SPC (statistical process control) Software Quality Assurance and Compliance Software Tools and Solutions 14
Tim Folkerts Is it Time for New Rules for SPC (Statistical Process Control)? Statistical Analysis Tools, Techniques and SPC 22
C SPC (Statistical Process Control) for Management Reports Statistical Analysis Tools, Techniques and SPC 2
Marc Definition Statistical Process Control (aka SPC) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
Q AIAG Releases the 2nd Edition of their SPC (Statistical Process Control) Manual Statistical Analysis Tools, Techniques and SPC 19
J ISO 9001:2000 - SPC (Statistical Process Control) requirements Statistical Analysis Tools, Techniques and SPC 4
Steve Prevette SPC (Statistical Process Control) Overview Statistical Analysis Tools, Techniques and SPC 101
L Defining Pre-Control Zones - Statistical Process Control (SPC) Statistical Analysis Tools, Techniques and SPC 1
S AIAG Statistical Process Control (SPC) Manual - Page 81 Statistical Analysis Tools, Techniques and SPC 4
M Predictive Maintenance vs SPC (Statistical Process Control) Data Misc. Quality Assurance and Business Systems Related Topics 1
D ISO 11462-1 Guidelines for implementation of Statistical Process Control (SPC) Statistical Analysis Tools, Techniques and SPC 4
T I need an add-in for excel that I can use for SPC (Statistical Process Control) Excel .xls Spreadsheet Templates and Tools 4
Raffy Statistical Process Control - ISO 11462-2:2001 Key elements of an SPC System Statistical Analysis Tools, Techniques and SPC 1
K SPC (Statistical Process Control) Training and Courses - Seeking suggestions Training - Internal, External, Online and Distance Learning 2
Marc SPC (statistical process control) charts and SD (System Dynamics) models Preventive Action and Continuous Improvement 18
J Statistical Significance and SPC Control Chart Reports Statistical Analysis Tools, Techniques and SPC 9
I SPC Statistical Analysis in Metrology General Measurement Device and Calibration Topics 2
V Which Statistical Tool for Pressing Components other than SPC Statistical Analysis Tools, Techniques and SPC 5
A P & F value in Minitab Statistical Studies (SPC) and the 8 points rule Using Minitab Software 7
A SPC Training - I want to develop my knowledge in statistical tools Statistical Analysis Tools, Techniques and SPC 5
B Statistical Analysis SPC Trend explanation needed Statistical Analysis Tools, Techniques and SPC 4
I Statistical Tools outside of SPC Statistical Analysis Tools, Techniques and SPC 2
W SPC all the time? Does QS9000 require statistical control on all processes? QS-9000 - American Automotive Manufacturers Standard 3
C Buying Minitab / other SPC or Statistical software Quality Tools, Improvement and Analysis 8
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
