SPC vs. 100% Inspection - Is SPC still value-added when 100% inspection is in place?
brahmaiah
#11
Re: SPC vs. 100% Inspection - Is SPC still value-added when 100% inspection is in pla
Don't forget, you have special causes that can happen between sampling - and sampling may not catch it if it is intermittent. SPC is sampling - and has its limitations. So, even though your process is in control...100% inspection may be needed for certified output.
Doesn't say I like it...just a warning.
Also, you may need 100% inspection if you are using the wrong SPC - like X-bar-R for precision machining.
To say that assignable caues can escape detection in x-r chart is not correct.If such a thing is a possibility in any process you have to increase the frequency of sampling and even you can increase the sample size.100% INSPECTION IS NO SOLUTION IN A MASS PRODUCTION SITUATION.
V.J.Brahmaiah
#12
It is correct. As Bob suggested, an intermittent cause can happen between samples.
But how is it possible to be aware of all possible process failure modes, 100% of the time?
Great. Tell us where the dividing line is between not-mass-production and mass production so we can know when 100% inspection is OK.
bobdoering
Stop X-bar/R Madness!!
#13
To say that assignable cause can escape detection in x-r chart is not correct. If such a thing is a possibility in any process you have to increase the frequency of sampling and even you can increase the sample size.
Actually it is correct if the condition does not persist long enough to be detected by the sampling for the charting. If it is very infrequent, you will need to increase you sample size....to 100%
Actually, there are some very effective 100% inspection systems using vision systems, lasers, etc. These are very common in automotive where low failure rates are still not acceptable.
#14
Brahmaiah: perhaps this is a wording problem. in your first sentence you say you must increase your sample size and in the last you say that 100% inspection is no solution. these seem to be contradictory statements...perhaps you could clarify your meaning?
brahmaiah
#15
When I said we should increase sample size, I didnot mean we should increase it to 100%.I meant we should increase the sample qty.Because 100% is not a sample.
V.J.Brahmaiah
brahmaiah
#16
True but we are keeping them out of the perview.We are cosidering only manual inspection.
V.J.Brahmaiah
V
Vicman
#17
I insist on using SPC instead of 100% inspection. And try to keep my process under control with a cpk above 1.66.
If we remember history, sampling plans were first use by military suppliers and because of high rejections, finally were replaced by SPC techniques.
Something that can help here is to use other tools besides SPC like Poka Yoke.
bobdoering
#18
If and only if all of the failure modes you have identified in your FMEA will persist when they occur, then the sampling rate used for SPC will allow you to not need to 100% Inspect.
SPC is an improvement over sampling by itself - but is still based on sampling and exhibits some of its limitations. In fact, some of the variation in SPC charts can be attributed to sampling error - not entirely the process. SPC is not foolproof and should not be expected to detect 100% of the defects. If 100% good product is the customer requirement (critical characteristic) You may need 100% inspection to verify the product in addition to SPC to control the process to avoid rejects.
If a poka yoke can be developed for the condition, it can be an effective approach in that it verifies 100%
#19
V.J.Brahmaiah
we are? I ddint' see that in the OP's post or anyone else's response. did I miss something? but beyond that why woudl we keep them out of the perview as you say?
brahmaiah
#20
100% Inspection is justifiable only in aerospace&medical Products. .If you depend on it in automotive and consumer industry.You cannot stand in the global competition.The success of japanese is there to see for all of us.
V.J.Brahmaiah
K SPC to apply for Particle in Clean Room Class 100 Statistical Analysis Tools, Techniques and SPC 7
R SPC vs. 100% testing Statistical Analysis Tools, Techniques and SPC 1
J SPC in 100% Population - Monitoring Overtime Expenses - Financial Application Statistical Analysis Tools, Techniques and SPC 3
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
P Informational SPC in Batch Processing Statistical Analysis Tools, Techniques and SPC 3
A How to reduce the process SPC monitoring Capability, Accuracy and Stability - Processes, Machines, etc. 3
P SPC for machining processes Capability, Accuracy and Stability - Processes, Machines, etc. 1
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L SPC - Methods to collect data IATF 16949 - Automotive Quality Systems Standard 7
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
Proud Liberal Informational Use of Classical SPC in Precision Machining Statistical Analysis Tools, Techniques and SPC 9
J Recommendations on Inspection/SPC Software Statistical Analysis Tools, Techniques and SPC 4
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
J Properly understanding SPC - Newbie SPC questions Statistical Analysis Tools, Techniques and SPC 34
bobdoering SPC Charting frequency calculator for X hi/lo chart Imported Legacy Blogs 0
bobdoering Handy training tip for SPC - the Check Engine Light Analogy Statistical Analysis Tools, Techniques and SPC 0
QMMike SPC Software for MAC computers Statistical Analysis Tools, Techniques and SPC 2
Marc SPC based Dashboards - By Steve Prevette (November 2017) Statistical Analysis Tools, Techniques and SPC 1
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
Tagin Can/should SPC be applied to Computer Assembly and Software Imaging? Statistical Analysis Tools, Techniques and SPC 8
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
T SPC in Insurance Back Office Operations Service Industry Specific Topics 4
C SPC for Particulate Alert/Action Levels Statistical Analysis Tools, Techniques and SPC 3
M SPC with many data points from one dimension Statistical Analysis Tools, Techniques and SPC 16
Q Mixed data collection (SPC) for different mold cavities Statistical Analysis Tools, Techniques and SPC 2
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
bobdoering Available SPC and Metrology Consultants Paid Consulting, Training and Services 0
I SPC on Cyclic Data Statistical Analysis Tools, Techniques and SPC 10
S SPC Card for One Sample Size - Customer requires for all critical dimensions Statistical Analysis Tools, Techniques and SPC 8
R Quality Management & SPC Manufacturing and Related Processes 1
B Is SPC data For Special Characteristics always required? TS 16949 clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S How to Start SPC in a Shaft Grinding Section Statistical Analysis Tools, Techniques and SPC 1
A I-MR SPC used for Inspection Statistical Analysis Tools, Techniques and SPC 7
E SPC data from multiple Excel files Statistical Analysis Tools, Techniques and SPC 5
