Spec Limits in SPC charts
JasnahKholin
Hi All,
Is it OK to include the spec limits on control charts? This was found by one of my peers during an internal audit and is apparently a common practice that has been in place for years here. My peer insists that this is an NC and that spec limits are not allowed to be included on control charts. Production's opinion is that it is relevant to include on the charts because it affects what OCAP operators follow depending on if you are outside control limits vs. outside spec limits. For example, something that is outside control limits but inside spec limits may still be a good product but if you are outside spec limits then it may require rework or scrap. I cannot find anything in the AIAG SPC manual that states that spec limits can't be included on the charts. Is this a common practice anywhere else?
We are both internal auditors in the quality department. We are certified to ISO9001, IATF16949 and AS9100.
Thanks,
I can't think of a reason that anyone would not want to see the spec limits on an SPC chart. The idea that it's somehow considered a bad idea is frankly ludicrous. The whole idea is to be able to compare process behavior with the specifications.
Matt Savage
The job that control limits do is completely different than the job that spec limits are used for. Are you working with an Individuals & Moving Range (X-MR) chart of X-bar?I ask because if it is X-bar chart, I would never put spec limits on the chart.
Lets assume you are working with Individuals data. One negative consequence is that if it is "In Spec" yet out-of-control, why should I change anything? I mean, the measurement is good, correct? In short, the idea of improvement may not occur when specs are included on the control chart.
Another issue with adding spec limits to sub-grouped control charts is that it can mislead an operator into thinking that because the point was inside the specification that all is well. The problem is that the point is an average, and individual results may well be out of spec.
JasnahKholin
These are not X-bar charts. Each data point is a measurement from that specific part.
Our MES system stops the machine from running when there is a violation of WECO rules for the feature being measured and operators/engineers must address the issue before continuing production. The OCAP processes also have different procedures on what operators should do if the point is outside the UCL/LCL but still inside spec limits vs. a point which is either above or below the spec limit.
For example, if a hole diameter is outside the UCL/LCL the OCAP is to change the tool but product is still OK to use. A hole diameter smaller than LCL and LSL has an OCAP to rework while a diameter larger than UCL and USL would mean the product is scrap.
AMIT BALLAL
Use of specification limits on a control chart leads to tampering (over-adjustment). And it causes more problem than benefit.
So I would suggest to stop such a practice.
As you mentioned, every time the hole diameter point is outside a control limit, considering such a problem due to special cause related to tool and change of tool seems like tampering. I recommend revisiting the procedures in such a case.
@Miner will be able to give more insights.
Here we're talking about incompetent operators. Also, before subgroup results can be charted, the individual samples must be measured. Anything anomalous should be evident when the parts are measured.
Just because all of the parts in a subgroup are in spec does not mean that all parts produced at that time are in spec.
If I recall, you have a machining background which likely has a very tight distribution. My background includes processes with a lot of variation, so I have seen tis occur.
Ron Rompen
it is definitely NOT a nonconformance to put specification limits (or any other limits you like) on a control chart. A nonconformance is a failure to comply with the standard, and to the best of my knowledge there is nothing in any of the standards you mentioned that would prohibit this.
There may be valid reasons not to do it (several have been cited) however I always like to have the specification limts AND the control limits shown on charts - that way I can determine if parts are still acceptable to print spec, even if they have gone out of control.
I suggested nothing of the kind. I said that the majority of anomalous conditions will be seen when parts are being measured. I will also reiterate that arguments against spec limits on control charts assume operator incompetency.
I've worked in machining, metal stamping, sheet metal, precious-metal plating, and injection molding molding job shops. I've also worked for OEMs in manufacture of toxic-gas monitoring systems and motorcycles.
H Johnson Transformation in Minitab - How upper & lower spec limits are recalculated Using Minitab Software 1
B If I know x-bar, spec limits, and Cpk, can I calculate the control limits? Capability, Accuracy and Stability - Processes, Machines, etc. 16
Bev D Development Process: FMEA, Critical Characteristics, Spec Setting and Controls Misc. Quality Assurance and Business Systems Related Topics 0
Sam.F Question about granite surface plates out of spec AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M API SPEC Q1 9th edition NCR Oil and Gas Industry Standards and Regulations 3
J API Spec Q1 9th Ed. Oil and Gas Industry Standards and Regulations 4
B Evaluation of suppliers API Spec Q1 5.6.1.2c Oil and Gas Industry Standards and Regulations 2
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
Q API Spec Q1 9th Ed 4.4.2 Non-conformance Oil and Gas Industry Standards and Regulations 8
M Customer Specific Requirements - Packaging Spec IATF 16949 - Automotive Quality Systems Standard 10
J API Spec 6D 25th edition release date? Oil and Gas Industry Standards and Regulations 23
T API SPEC Q1 Clause 5.6.1.2.C).2) First Article Oil and Gas Industry Standards and Regulations 16
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
lanley liao How to understand correctly the section of 5.11 MOC in API Spec Q1? Oil and Gas Industry Standards and Regulations 3
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
A API Spec Q1 Purchasing Process - Supplier Reevaluation based on Supplier Risks 5.6.1.4 Oil and Gas Industry Standards and Regulations 19
lanley liao The validity of API Spec Q1 certificate Oil and Gas Industry Standards and Regulations 2
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 9
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
SANTHSH API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
SANTHSH API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 12
SANTHSH API spec Q1 9th edition - Castings & Forgings Oil and Gas Industry Standards and Regulations 4
N API spec Q1 9th edition Oil and Gas Industry Standards and Regulations 2
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
M API Spec. Q1, 8th Ed. Section 7.5.2 vs. Q1, 9th Ed. Section 5.7.1.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
M Proper way to develop LCL when only given a lower spec limit Reliability Analysis - Predictions, Testing and Standards 7
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 25
B Set RH spec from dewpoint spec General Measurement Device and Calibration Topics 2
A API Spec Q1 9th Edition # Re-audit - Disputing with API AARs Oil and Gas Industry Standards and Regulations 1
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
G Can calibrated device values be used instead of manufacturers spec? General Measurement Device and Calibration Topics 2
DuncanGibbons OEM specifications such as AIPS spec from Airbus AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
R Interesting Discussion API Spec Q1 Addendum 2 Oil and Gas Industry Standards and Regulations 0
F API Spec Q1 Scope - Limiting the scope of certification Oil and Gas Industry Standards and Regulations 3
F API Spec Q1 9th Edition Surveillance Audit - Questions about internal audits. Oil and Gas Industry Standards and Regulations 22
N When to record values if a spec for a mfg process is set Manufacturing and Related Processes 3
M AMS0320 - Electro-deposition of zinc - Anyone come across this spec? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
D What is your Sterile Medical Device Pouch Peel Strength Spec? Other Medical Device Related Standards 3
P Any official doc/spec on different types of Yield calculation? Manufacturing and Related Processes 0
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
V Plating Spec - Electro plating Manufacturing and Related Processes 3
Moumen H API Spec Q2 Design and Development Requirements for Service Providers Oil and Gas Industry Standards and Regulations 11
A Integrating API Spec Q1 with ISO 9001:2015 Oil and Gas Industry Standards and Regulations 18
S API SPEC 7-1, 7-2 and 5 CT implementation Oil and Gas Industry Standards and Regulations 3
