Special 510k Update - Cease Sales and Distribution until a Decision is Rendered?
aoldendo
Hello all:
My company is preparing a Special 510k to update the FDA on all changes to our product during the past few years since the original 510k clearance.
The question I have is this: during the 30 day clock in which to review a Special 510k, must a company cease sales and distribution until a decision is rendered?
And hypothetically speaking, were the FDA to come back and require a traditional submission (in the instance the Special 510k were not sufficient), would our company be required to cease sales and distribution for that 90 day clock?
Thanks for your help..
Sincerely,
G
George Weiss
The special 510k, is like a pilot calling the traffic tower, (FDA), to change course.
Most pilots would wait for approval before changing course.
Reporting changes made in the last few years, and now calling the traffic tower, (FDA). OMG!
Your changes may be minor changes, or major changes in medical device regulation speak.
I can verify the 30 days for special 510K
I can verify the 90 days for 510K
The FDA instructions after these guidance days pass, is to call and check, "what is the status?"
Almost all/all Class I, and some Class II devices are exempt from special 510k per FDA,
so you must be taking about your Class III device, right?
Your comments also speak of possible rejection of special 510k filing.
I hear this whisper in the background, "Recall" or "Market Withdrawal".
Medical Device 101 from the FDA 229 pages of guidance @
http://www.fmdic.org/events/devices101/20090605w.pdf
I am just adding the PMA item:
30-day Notice and 135 PMA
Supplement—814.39(f)
This is used for modifications to manufacturing procedures
or methods that affect the device’s safety and
effectiveness. If FDA does not respond within 30 days
after notification, the change can be made
referenced page 9 @
http://schiffandcompany.com/userfiles/fusra-6ed-201-215(2).pdf
I have no direct answer, but some concern.
MIREGMGR
...during the 30 day clock in which to review a Special 510k, must a company cease sales and distribution until a decision is rendered?
As George discusses, if you are actually noncompliant at present, the situation you outline in theory should not occur (though of course in practice it does), and therefore the FDA has no published guidance on how to handle it. The FDA's policy is one of not accepting any noncompliance, even when an effort to come into compliance is under way. This of course leads to lies-of-omission in discussions with them, because any admission of past or current noncompliance can result in enforcement action.
If your documented and internally accepted stance is that you regard the Special submission as timely, appropriate and likely to be accepted, given the Bluebook discussion of how a filing may become appropriate in respect to accumulated minor (memo to file) product evolutions over time, then my understanding would be that continued marketing would be acceptable. In the worst case, the level of trouble your company in theory could be in won't be any different whether you continue sales or halt them.
If however the FDA has an unfixable problem with the Special and demands a Traditional, then you're in effect on notice as to noncompliance. That's a much more problematic situation. I think then you'd have to stop sales, at least, and maybe do a recall. In that case, I'd think you might want to get expert legal advice.
aoldendo
George and Miregmgr,
Thanks for your input.
I will try and give a little more background on the situation we find ourselves in. Our device is Class II. The position we've taken internally is that which Miregmgr described thusly:
"If your documented and internally accepted stance is that you regard the Special submission as timely, appropriate and likely to be accepted, given the Bluebook discussion of how a filing may become appropriate in respect to accumulated minor (memo to file) product evolutions over time, then my understanding would be that continued marketing would be acceptable."
We do not believe the device has changed appreciably from the original 510k either in function, material, technology, labeling, etc.
However, I also appreciate the frank assessment of what might happen were FDA to find unsolvable problems with the Special 510k. This is important to know as we assess the benefits and risks of updating the original 510k.
Regarding advice on this topic, would DSMICA be able to help?
Thanks,
Biobry
"We do not believe the device has changed appreciably from the original 510k either in function, material, technology, labeling, etc."
I realize I'm jumping into this a little late, but if you believe what you stated, then based on the Memorandum #K97-1 "Deciding When to Submit a 510(k) for a change to an existing device", the Special 510(k) may not be necessary at all:
"In effect, manufacturers need to submit a new 510(k) only when a change, or the sum of the incremental changes exceeds the §807.81(a)(3) threshold, "could significantly affect the safety or effectiveness of the device.""
Why do you feel the Special 510(k) is necessary in the first place?
Bruce Banner
I agree, if you have documentation supporting a filing was not necessary, then there is no basis to file.
However if you are going back on that documentation, then you need to rationalize why it was the wrong decision to begin with and go from there
drewsky1
In regards to this topic of Special 510k, is it required that the predicate be a device that the company submitting the Special 510k be the manufacturer? Or can one submit a Special 510k with a predicate that they do not manufacturer?
P Letter to file or special 510k or traditional 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G Special 510K possible? Only the packaging has changed Other US Medical Device Regulations 0
S The key differences in 510k types - Traditional vs. Abbreviated vs. Special US Food and Drug Administration (FDA) 0
P V&V for Special 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Special 510k Imported Legacy Blogs 0
E 'Special' 510k as a Predicate Medical Device? Other US Medical Device Regulations 3
J Change in wording, but not content - Special 510k? Other US Medical Device Regulations 2
M A traditional 510K or Special 510K - Manufacturing facility and other changes US Food and Drug Administration (FDA) 16
N IEC 60601-1 , 3rd edition and the FDA - Special 510k to my updated Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 40
P Do we need to submit Special 510K for a Blood Glucose System? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J Testing data for Special 510k and contact person Other US Medical Device Regulations 4
N Special Contract Manufacturing or 510k Licensing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Sterility Assurance Level? Special 510k US Food and Drug Administration (FDA) 5
S Special 510k Operating System for Data Management Software Design Documents IEC 62304 - Medical Device Software Life Cycle Processes 5
S Special 510k for Data Management Software Document Requirements IEC 62304 - Medical Device Software Life Cycle Processes 1
D Special 510k - Data Results of the Design Verification and Validation Other US Medical Device Regulations 3
S Time for a Special 510k? Making a formulation change to an existing 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Special 510(k) for orthopedic implant 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Riveting - special process Manufacturing and Related Processes 11
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
Y What are different Special Inspection Level 1-4 and General spesification 1-3 ? AQL - Acceptable Quality Level 0
L Special Processes for SERVICES AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
K PSA Special characteristics Customer and Company Specific Requirements 0
Watchcat Advantages to pursuing a Special 510(k) instead of a Traditional 510(k) Other US Medical Device Regulations 5
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Special 510(K) - Labeling change from Rx to OTC Other US Medical Device Regulations 11
M Special Controls and Class II Medical Devices Medical Device and FDA Regulations and Standards News 18
A ISO 10993-7:2008/ Amd.1:2019 - Classification of special populations Other Medical Device Related Standards 3
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
F Replacement Bone Screws - Traditional 510(k) or Special 510(k)? Other US Medical Device Regulations 7
F Assignment of Special Characteristics to government regulations IATF 16949 - Automotive Quality Systems Standard 5
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt? ISO 13485:2016 - Medical Device Quality Management Systems 5
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D I'm new in IMDS special using the IMDS application Manufacturing and Related Processes 8
S VW Special status condition IATF 16949 - Automotive Quality Systems Standard 3
K Letter to file vs Special 510 for additional accessory in orthopaedic kit Other US Medical Device Regulations 1
P Special 510(k) - Modified Medical Device Description Other US Medical Device Regulations 8
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B AS9100 - Are special process suppliers required to be NADCAP accredited? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
P Sanctioned Interpretations - IATF 16949 Cl. 8.3.3.3 Special characteristics IATF 16949 - Automotive Quality Systems Standard 3
