Special Characteristics - What if the customer does not identify any SCs?
L
Lardner
The standard says that the customer should id them, if they have not you shoud via the Fmea failure modes with severity 9 and 10. Question, if the customer does not have any and if you ask they can not provide and you do not have any severities above 8, is it ok not to have any special characteristics stated in the D-FMEA?
Marc
I *assume* you are a manufacturer making a part for a company according to their specifications.
What specific standard and clause are you referring to?
A customer supplies a print. On that print any 'Special', 'Critical' or other characteristics should be defined.
I have rarely seen it, but sometimes the customer provides a Design FMEA. There is a recent discussion here about flow down from a Design FMEA to a Process FMEA. I don't see it off hand. Maybe one of the others here remembers which thread it is.
Here is a very old thread: How to identify Special Process Characteristics in FMEA
My experience is if a customer doesn't supply a Design FMEA and has not communicated any Special Characteristics (either by way of a print or otherwise such as within the contract its self), there isn't any impact on your Process FMEA.
Also see: Special Characteristics
L
Lardner
We are a supplier of electronics systems where we do the D-FMEA on system level (our product defined as a system). Some times we do a System FMEA with the customer as well.
When starting the develpment of this product we start out with a specification but since we are a development partner to our customers the specification is never complete when we start, we always work together on finalizing it.
Here we need the special or critical characteristics as input to our D-FEMA work. If the product has saftety features it's simple they become Special characteristics but if you do not have safety of regulatory requirements on the product and the customer has not pointed out any SC's and on top of that no high severities comes out of the D-FMEA work.
What it really comes down to would an external auditor approve of an D-FEMA without andy special characteristics if above can be proven?
I'll check about SC's but does not req's comes from the TS16949?!
Thanks Mikael
Thanks Mikael
You have to look to general customer requirements. I know that in the past, dealing with GM, it was expected that (for PPAP purposes) if they didn't specify any SCs, the supplier was expected to identify at least one from their process to satisfy the Level 3 PPAP requirement for a capability report.
N
Neil V.
We've operated for years under the premise that if a special characteristic was not noted by the customer then there was no requirement to identify one.
However, at our last surveilance audit we were given a non-conformance for not having identified at least one special characteristic for each part. (TS audit, Chrysler)
We addressed it by making each operation setup 'special'.
In my opinion, this has led to more issues, including flow down of the identification of these new special characteristics to all operator instructions (which we're not doing) and has added no value.
rnrphantom
G'day everyone, This is my first post in here.
My interpretation is that if there are no customer specified SC's or CC's then there is no requirement for you to conduct capability studies.
Yes the TS auditors may request it, but it is not mandatory, and I have successgfully argued this point!
To appease our auditors, we have internal requirements that if severity is greater than 6 and occurrence greater than 4, then it is automatically a an internal "High Impact" characteristic that we take action on to reduce the RPN. Hope this helps.
Cheers
Rob
E IATF 16949 Cl. 8.2.3.1.2 - Customer-designated special characteristics IATF 16949 - Automotive Quality Systems Standard 1
D Customer-Designated Special Characteristics vs. Special Characteristics IATF 16949 - Automotive Quality Systems Standard 2
Q TS 16949 Clause 7.2.1.1 Customer Designated Special Characteristics IATF 16949 - Automotive Quality Systems Standard 6
Q TS 16949 Clause 7.3.2.3 when the Customer has no Special Characteristics IATF 16949 - Automotive Quality Systems Standard 25
J Definition of Special Characteristics Delta C and Delta S - Need for Customer Audit Capability, Accuracy and Stability - Processes, Machines, etc. 2
M Customer Designated Special Characteristics - TS16949 Clause 7.2.1.1 Design and Development of Products and Processes 14
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
K PSA Special characteristics Customer and Company Specific Requirements 0
H SPC for special characteristics - CSR - Control of SC and CC Statistical Analysis Tools, Techniques and SPC 1
F Assignment of Special Characteristics to government regulations IATF 16949 - Automotive Quality Systems Standard 5
P Sanctioned Interpretations - IATF 16949 Cl. 8.3.3.3 Special characteristics IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
C Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 IATF 16949 - Automotive Quality Systems Standard 8
B Is SPC data For Special Characteristics always required? TS 16949 clause 8.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
U SC (Special Characteristics) in CP (Control Plan) not on all Prints IATF 16949 - Automotive Quality Systems Standard 1
J Special characteristics in TS 16949 7.3.2.1 - Why 7.3.2.3 not 7.2.1.1 IATF 16949 - Automotive Quality Systems Standard 4
A Special Characteristics revisited IATF 16949 - Automotive Quality Systems Standard 4
A Special Characteristics -> Any specific additional requirements to be met? IATF 16949 - Automotive Quality Systems Standard 7
D Is Cpk required for all Attribute Data Special Characteristics? IATF 16949 - Automotive Quality Systems Standard 6
R Process to use Special Characteristics as FMEA Inputs IATF 16949 - Automotive Quality Systems Standard 3
R MSA (Measurement Systems Analysis) on a CMM for Special Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Special Characteristics Definitions in TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
D AIAG FMEA 4? Ed. Explanation: Relationship between PFMEA and Special Characteristics FMEA and Control Plans 8
J Special Characteristics Identification x Classification FMEA and Control Plans 3
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
M Request for Clarification on Special Characteristics Definition IATF 16949 - Automotive Quality Systems Standard 1
F Special or Key Characteristics Standards and Symbols IATF 16949 - Automotive Quality Systems Standard 8
O Special Requirements, Critical Items and Key Characteristics - AS9100 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T DFMEA & PFMEA - Special Characteristics Identification FMEA and Control Plans 14
Q Are Special Characteristics mandatory (required)? IATF 16949 - Automotive Quality Systems Standard 41
M Special Characteristics: SPC required? Statistical Analysis Tools, Techniques and SPC 1
M Critical / Key / Significant Characteristics - Special Characteristics Classification FMEA and Control Plans 1
P Special characteristics symbols in work instruction - For whom? IATF 16949 - Automotive Quality Systems Standard 6
M Special Characteristics - (MIC), What does this stand for? FMEA and Control Plans 13
A SC: Significant Characteristics vs. Special Characteristics IATF 16949 - Automotive Quality Systems Standard 4
B When to add Special Characteristics to your drawing/print? FMEA and Control Plans 4
A Identification of Special Characteristics - Cl 7.3.2.3 Interpretation IATF 16949 - Automotive Quality Systems Standard 5
E Defining Special Characteristics and Control Plan - Welding Operation - Need help Document Control Systems, Procedures, Forms and Templates 7
P Capability in ISO/TS 16949 registered firms - No Special Characteristics IATF 16949 - Automotive Quality Systems Standard 27
Q FMEA Special Characteristics - Shipping FMEA and Control Plans 2
B Is SPC Required for all SC's (Special Characteristics) on Drawing (Print)? Statistical Analysis Tools, Techniques and SPC 12
M Not all special characteristics are monitored and Gage MSAs - Two NC's IATF 16949 - Automotive Quality Systems Standard 9
E How far to go into Special Characteristics (SC) Identification on Machines/Equipment IATF 16949 - Automotive Quality Systems Standard 1
R Special Characteristics - ISO/TS 16949 Clause 7.3.2.3 - Required by auditor IATF 16949 - Automotive Quality Systems Standard 54
Manix MSA Only on Special/Critical Characteristics? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q Concerning Special Characteristics Interpretation - Semiconductor commodity standard IATF 16949 - Automotive Quality Systems Standard 3
