Special Process definition - Clause 7.4.1 part d
Sohail
Please refer to clause 7.4.1 part d
"Ensure where required that both the organization and all suppliers use customer-approved special process sources"
Does this word "Special Process" mean the "Validation of processes for production and service provision"?(7.5.2)
Can some body explain this with an example please?
andygr
For the aerospace world many times the exact definition of special process is driven by your customer. Based on what they concider special process they require that you get their approval and be listed on their approved process list. This is where they come visit you every year to make sure you are still playing nice. The concensus ones for all aerospace is the Nadcap checklists which cuts down the mutiple visits to one.
For example Boeing coveres special processes and list those firms that are approved in their D14426 document. If your subtier supplies castings and is required to have them X-rayed then you need to ensure that your supplier's source or the supplier is a Boeing approved X-ray source.
Typicaly this is by contractual flow down and verification is covered as part of the FAI to AS9102 which will have all the detail info as part of the report.
al40
Special/controlled processes as defined by Lockheed Martin is "The process and the processes that require approval, prior to use for items delivered to the Buyer. A controlled/special process is an operation performed on an item where the operation is not readily inspectable subsequent to its conclusion".
They too control special processes with their specification QCs-001 which they have to grant approval and may require Nadcap accreditation.
Best regards,
al40
Manix Definition Special Process Scope - CQI-11 & CQI-12 - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
D Definition Special Processes - Can anyone give me a definition of what a Special Process is? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 50
N Riveting - special process Manufacturing and Related Processes 11
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B AS9100 - Are special process suppliers required to be NADCAP accredited? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
x-files [Thermal powerplant] Why "Generation of electricity" is a special process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
P Customer Validated Special Process Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Z299 Special Process Supplement Document Manufacturing and Related Processes 1
J Is painting considered a Special Process as defined by ISO 9001 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Is Computer Helpdesk a Special Process ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J AS9100 C - Is Molding of Rubber Parts a Special Process (7.5.2)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Is Quarry Blasting a Special Process according to 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
R Process to use Special Characteristics as FMEA Inputs IATF 16949 - Automotive Quality Systems Standard 3
A Explanation of AS/EN 9100 Clause 7.4.1 Special Process Sources AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Specific Special Process requirements in TS 16949 for MIG Welding IATF 16949 - Automotive Quality Systems Standard 1
M Application of Special Process - Validation and FAI in Wind Tunnel Testing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Any CQI-Special Process related to Printed Circuit Boards (PCB)? IATF 16949 - Automotive Quality Systems Standard 1
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
sonflowerinwales Is there a Process Equivalent to NASA Special NDI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100C Special Process Procedure - Work Instruction for AS9100 Clause 7.5.2 wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Seeking advice on how to handle a Special Process Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
R Special Process Checklists for Plating, Phosphate Coating, Welding and NDT AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S No Process Defined to Capture the Special Requirements of Customers Problem Solving, Root Cause Fault and Failure Analysis 10
S Anyone had a requirement for Conventional Machining as a Special Process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Supplier Special Process System Assessments - CSR Requirements Customer and Company Specific Requirements 2
H AS9102A - What is meant by 5.2.5, "... approved Special Process sources..." AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Process Approach - Special Focus? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Seeking CQI-11 (Special Process Plating Assessment) Training Training - Internal, External, Online and Distance Learning 4
R CQI-15 Welding System Assess. & CQI-17 Special Process: Soldering Various Other Specifications, Standards, and related Requirements 6
B Is Design of Molds and Dies a Special Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Is Heat Treatment for Metal a Special Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 87
S Special Process Validation - ISO9001 Clause 7.5.2 - How do I go about it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
eternal_atlas Is cable jointing process is a special process like welding? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Stijloor Special Process Training from AIAG Training - Internal, External, Online and Distance Learning 0
D "Special Production Process" Validation and TS16949 Clause 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 5
C Laboratory Testing as a "Special Process" - element 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Stijloor New Special Process Guidelines are now available from AIAG IATF 16949 - Automotive Quality Systems Standard 18
S Welding - Is welding always a special process per ISO9001:2000 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
C Special Process Validation - Electroplate - 7.5.2 of AS9100B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I Validation of Special Process - Soldering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N How to identify Special Cause(s) in a process? IATF 16949 - Automotive Quality Systems Standard 30
S I need help about Dyeing process - Is dying process a special process? IATF 16949 - Automotive Quality Systems Standard 9
A Process audit - Is it necessary to audit the special processes like plating? Process Audits and Layered Process Audits 2
A Removing the effect of special causes on Xbar-R chart - Centerless grinding process Statistical Analysis Tools, Techniques and SPC 6
Marc Definition Statistical Control - A stable process free of special causes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
E Supplier audit checklists for special processes - Plating Process audit Checklist Process Audits and Layered Process Audits 2
