Special Process Validation - ISO9001 Clause 7.5.2 - How do I go about it?
Superchris
Hi all!
Long time listener first time caller:D
As I'm writing our Quality Manual, I'm wondering how I should cover section 7.5.2. The only "special process" we have is welding and it is out-sourced.
Should I just say that the process is validated through our Supplier qualification-evaluation process?:eek:
Thanks a million!:thanx:
SteveK
Re: 7.5.2 : How do I go about it?
Note form my QM might help:
7.5.2
XXXXXX's products involve basic hand assembly operations; all the resulting assemblies and sub-assemblies are monitored or measured throughout the process. As such the resulting output can be verified. This sub-clause can therefore be excluded under Module E for BS EN ISO 9001:2000.
An external auditor (recently) seemed quite happy with this.
Sidney Vianna
Post Responsibly
That would not fly with me. Since you are outsourcing the process, you are still responsible for ensuring that the process is validated and revalidated. What is the criteria for process validation? How do you ensure the supplier has validated the process? Do they have records? Do your purchasing documents clearly stipulate this as a requirement?
Superchris
I would guess that the only way for us to validate the process is by measuring customer complaints related to the welding. Keep in mind that the whole reason we outsource this process is because we do not have the "know how" in house. This is why I think the only real power we have over this process is limited to the selection of the supplier (making sure they have procedures, controls, records, etc. in place)
:confused::(
Thanks again!:thanx:
Sidney Vianna
Post Responsibly
That is incorrect. Can you imagine if you were welding high pressure piping in the primary cooling system of a nuclear reactor? Would you wait until you have a "radioactive spill" before you validate that process? Depending on the type of welding you are doing, there could be many different types of validating a process. Pressure containment weldments, structural components welding are critical. Most standards will have criteria for welding process and welder qualification.
On the other hand, some welding processes do not raise to the category of "special process", thus, don't need to be validated at all. There is no one-size-fits-all scenario here.
Superchris
I think this categorizes my case. :bonk:
By reading other posts, I was under the impression that welding = special process. However you're explanation makes much more sense.
Thanks!
:D
H
Hanr3
Since your outsourcing it to the "experts" let them provide the evidence that thier process meets your specs. Ask them to validate thier process and provide evidence that is build is up to spec. If they are a quality shop, they no doubt already ahve controls and records in place, especially if they are ISO Certified.
Superchris
Sorry to be so hard headed but wouldn't this prove my initial point that the only real power I have over my welding process is in the selection of the supplier?
:frust:
Thx again!
Cris
H
Hanr3
Yes and No.
Yes you have control over who the vendor is.
No that is not your only control in the process.
You have product specifics that must be meet. Your vendor is the expert, they will know the questions to ask you about what you expect from them.
Let's say you need a transmission for an old car your going to rebuild.
You can choose 1 of a 1,000 different places to get the tranny. Local salvage yard, dealer, independent shop, Uncle Buck, nieghbor, or some guy you just meet on the web. How do you whittle that list down? Vendor certification process.
Let's say for simplicity sake you decided that I might be the vendor.
I will ask you for the year, make, model, engine, and intended use of the vehicle. Each answer will point me in a different direction. To keep it smiple lets say your vehicle is an old S10 Blazer and the engine is a 4.3L V6, you want an automatic and the truck is a 4x4 used mostly for hunting and winter weather driving. That tells me that your looking for either a 4L60 or 4L60E tranny. If the truck is a '93 or newer your looking for a 4L60E. Pre '93 you will need a 700R4 or 4L60, roughly the same tranny and you wont know the difference once its rebuilt. Being that it will see off-road use I will ask if you plan to tow a trailer? If you have a boat you will pull with it in the summer I will suggest a shift kit, kevlar clutch packs, auxilary tranny cooler, and larger oil pan. Now we can talk price and reliability. You agree and we have a deal. I build the tranny and deliver. What kind of certification would you like me to provide to verify or validate that I build the tranny to your specs? Do you want to inspect the build process? Do you want me to provide checklists or inspection records of the build process?
Sure picking the vendor is part of the process, however the vendor must know the industry and must be able to provide records as needed. In the case of the tranny I could provide you with our test records. The test records are taken as the tranny is being assembled and after final assemble. During assemble we measure things like gaps between cluth packs, verify gaskets are facing the correct direction, we air test each clutch pack prior to the valve body being installed. And Finally we hook the tranny up to a test machine and verify that all pressure readings are within spec, and the tranny shifts as expected.
There is more to it than picking a vendor. You still have to provide them with teh specs they must meet. A good vendor will know the industry and can help you ask the right questions.
One last thing, before you hang the tranny on the engine get a new torque converter, put tranny fluid on teh input gasket before you install teh torque converter, and blow out the tranny cooler lines / tranny cooler so you don't introduce dirt into the clean tranny and destroy it. Failure to do so will violate your warrenty.
I hope that helps.
H
Hanr3
Whew!
Allright, now how does all that tie into ISO?
This is what your looking for as an answer correct?
Simple.
7.2.1 Determination of requirements related to the product- should be negotiated between you and the customer.
7.2.2 Review of Requirements Related to the Product- between you and your vendor.
7.3 Design and Development- specifically 7.3.5 and 7.3.6 Verification and Validation. Your vendor must be able to Verify and Validate their proces meets your specs, just as you do for your customer.
7.4 Purchasing ensures you are using an Approved Certifed Vendor.
7.5.3 Identification and Traceability- if you have a return from your customer you must be able to trace the problem, and if that trace leads you back to your vendor then they must be able to trace the problem on their end. You will look for them to do a CAR and replay to you with the root cause which you will use to reply to your customer for your CAR and root cause.
7.4.3 Verification of Product- you will inspect the product to ensure it meets your specs prior to use.
8.2.3 & 8.2.3 Monitoring and Measurement- you will audit your vendor to ensure they are still meeting your expectations. Prior to approving a vendor you should conduct an audit to see how they handle everything I pointed out so far.
and finally.
8.5 CAR's do they have a process in place to address the root cause of problems?
Selecting an approved vendor isn't a quick and simple process in most cases. It can be if they are ISO certified.
Your control of the outside vendor is in more than one section of the ISO Standard, you need to make sure you address it in each section.
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M Application of Special Process - Validation and FAI in Wind Tunnel Testing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D "Special Production Process" Validation and TS16949 Clause 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 5
C Special Process Validation - Electroplate - 7.5.2 of AS9100B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I Validation of Special Process - Soldering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
F Process Validation of 'Special Processes' - How do I? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Process Validation - Hand soldering of components & wires on PCB - Special Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A special process validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Validation of Processes for Injection Moulding - Special Process? Clause 7.5.2 IATF 16949 - Automotive Quality Systems Standard 9
T Passivation Validation - Is passivation is considered a "special" process by the FDA? ISO 13485:2016 - Medical Device Quality Management Systems 1
N Riveting - special process Manufacturing and Related Processes 11
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B AS9100 - Are special process suppliers required to be NADCAP accredited? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
x-files [Thermal powerplant] Why "Generation of electricity" is a special process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Customer Validated Special Process Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Z299 Special Process Supplement Document Manufacturing and Related Processes 1
J Is painting considered a Special Process as defined by ISO 9001 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Is Computer Helpdesk a Special Process ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J AS9100 C - Is Molding of Rubber Parts a Special Process (7.5.2)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Is Quarry Blasting a Special Process according to 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
R Process to use Special Characteristics as FMEA Inputs IATF 16949 - Automotive Quality Systems Standard 3
A Explanation of AS/EN 9100 Clause 7.4.1 Special Process Sources AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Specific Special Process requirements in TS 16949 for MIG Welding IATF 16949 - Automotive Quality Systems Standard 1
C Any CQI-Special Process related to Printed Circuit Boards (PCB)? IATF 16949 - Automotive Quality Systems Standard 1
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
sonflowerinwales Is there a Process Equivalent to NASA Special NDI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100C Special Process Procedure - Work Instruction for AS9100 Clause 7.5.2 wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Seeking advice on how to handle a Special Process Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
R Special Process Checklists for Plating, Phosphate Coating, Welding and NDT AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S No Process Defined to Capture the Special Requirements of Customers Problem Solving, Root Cause Fault and Failure Analysis 10
S Anyone had a requirement for Conventional Machining as a Special Process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Supplier Special Process System Assessments - CSR Requirements Customer and Company Specific Requirements 2
H AS9102A - What is meant by 5.2.5, "... approved Special Process sources..." AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Process Approach - Special Focus? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Seeking CQI-11 (Special Process Plating Assessment) Training Training - Internal, External, Online and Distance Learning 4
R CQI-15 Welding System Assess. & CQI-17 Special Process: Soldering Various Other Specifications, Standards, and related Requirements 6
B Is Design of Molds and Dies a Special Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Is Heat Treatment for Metal a Special Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 87
eternal_atlas Is cable jointing process is a special process like welding? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Stijloor Special Process Training from AIAG Training - Internal, External, Online and Distance Learning 0
Manix Definition Special Process Scope - CQI-11 & CQI-12 - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
C Laboratory Testing as a "Special Process" - element 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Stijloor New Special Process Guidelines are now available from AIAG IATF 16949 - Automotive Quality Systems Standard 18
S Welding - Is welding always a special process per ISO9001:2000 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
S Special Process definition - Clause 7.4.1 part d AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N How to identify Special Cause(s) in a process? IATF 16949 - Automotive Quality Systems Standard 30
S I need help about Dyeing process - Is dying process a special process? IATF 16949 - Automotive Quality Systems Standard 9
