Special Processes - Technical reason concerning torque - Anaerobic compounds
I would like to have a technical reason concerning torque and a separate process application of Anaerobic compounds are a special process?
can you clarify your question?
I think you are asking why torque might be considered a special process, but I'm not sure of the context of the question regarding anaerobic compounds...
torque is considered a special process because it cannot be adequately ensured by merely inspecting it.
I am asking two questions. 1. Is torqueing considered a special process? 2. Is applying an anaerobic compound, e.g. Loctite, considered a special process?
Sidney Vianna
Post Responsibly
Without context and relevant information, it is not possible to provide a meaningful answer. If you can't (or don't want to) provide details, you will not get an adequate answer.
John Broomfield
Torquing is a special process unless you use something like this to indicate the bolt’s tension:
Direct tension indicator - Wikipedia
Excluding oxygen from the joint with an anti-vibration compound like Loctite would also be a special process unless you’ve devised a way of confirming the seal is airtight and vibration proof. Being as Loctite is generally well accepted you’d need only demonstrate that it is applied strictly in accordance with Loctite’s storage and application specifications.
Sidney Vianna
Post Responsibly
Why? Last week I took my car for tire rotation and balancing. Looking at the receipt, I noticed that there was an instruction to torque the bolts to 90 ft.lbs. With a calibrated torque meter, anyone can easily check if the bolts were torqued to that spec, plus/minus a tolerance.
Why is torquing a special process if it can be EASILY verified afterwards?
Sorry - Torque can be a special process. Breakaway torque is not the same as applied torque and the act of trying to measure the break away torque can change the interfaces, so trying to re-torque and achieving the same hold is difficult to assess as well. So there is no easy way to verify the applied torque after it has been applied. True we can use a calibrated and validated torque wrench (which of course is the point of viewing torque as a special process when the holding force is critical) to help ensure the applied torque. Adding to the complexity of this situation is ability of the material to hold the torque under stress (mechanical or thermal). You can achieve an applied torque then have the fastener loosen up over time. All of this adds up to many companies where the torque is a critical function and we treat it as a special process.
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Special Processes for SERVICES AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
J ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt? ISO 13485:2016 - Medical Device Quality Management Systems 5
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
J NADCAP - Supplier Special Processes Certifications Manufacturing and Related Processes 1
N Special Vs Non-Special Processes Misc. Quality Assurance and Business Systems Related Topics 15
M AS9110C Clause 8.5.1.2 Validation and Control of Special Processes for Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Metal Radiographic and Ultrasonic Testing - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
W AS9100D Clause 8.5.1.2 Validation and Control of Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
P Records for outsourced special processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Q In a Print Shop the Products are Special Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
L AS9100 7.5.2 Special Processes - Clean Room Apply? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Q Meeting the Requirement of Clause 7.5.2 on Validating Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Approved Supplier Control Requirements for Outsourced Special Processes Supplier Quality Assurance and other Supplier Issues 4
Q Can 7.5.2 be excluded if you Outsources Special Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
M Nadcap for Special Processes required for EDM AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M What are Special Processes in Financial Institutions? Service Industry Specific Topics 4
M List of Special Processes in Quality Manual Quality Management System (QMS) Manuals 14
S Are there any Special Processes in Service Industry? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Validation of Special Processes - Are Casting and Forging Special Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
L Outsourcing Special Processes such as Plating, Painting, NDT as related to AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
N Validation of Special Processes - N/A of ISO 13485 Clause 7.5.2 ISO 13485:2016 - Medical Device Quality Management Systems 12
N Control of Special Processes - Welding & Soldering - The Great Debate - 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
B Question about ISO 9001 Clause 7.5.2 and Special Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Outsourcing Special Processes - Clause 7.5.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Special Processes - Qualification and approval prior to use. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Validation Of Outsourced Special Processes under AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
V Validation & which processes are called special processes & why not all the processes Manufacturing and Related Processes 9
F Outsourced special processes - How to control outsourced special processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Special processes & Critical processes - What are the differences? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Is there a "list" of what are termed Special Processes that have to be validated? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 49
A Process audit - Is it necessary to audit the special processes like plating? Process Audits and Layered Process Audits 2
E Supplier audit checklists for special processes - Plating Process audit Checklist Process Audits and Layered Process Audits 2
F Process Validation of 'Special Processes' - How do I? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Definition Special Processes - Can anyone give me a definition of what a Special Process is? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 50
P Special Processes Audit - Seeking review and comments General Auditing Discussions 7
K Special Requirements for Special Processes - HT 2005 (TS16949:2002) IATF 16949 - Automotive Quality Systems Standard 1
D HT2005 - AIAG Document - Ford heat treaters - Special Processes Various Other Specifications, Standards, and related Requirements 4
C What are Special Processes and What are Design Outputs? Design and Development of Products and Processes 3
R NADCAP (Consensus Approach to Special Processes) Information (Aerospace) Various Other Specifications, Standards, and related Requirements 1
T Grandfathering certified operators of special processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C 7.5.2 Validation of processes - Special Processes - Transportation Service Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
R Validation of Processes for Injection Moulding - Special Process? Clause 7.5.2 IATF 16949 - Automotive Quality Systems Standard 9
A What are Special Processes QS-9000 - American Automotive Manufacturers Standard 2
M Special Processes QS-9000 - American Automotive Manufacturers Standard 4
A QS-9000 Requirements for Special Processes QS-9000 - American Automotive Manufacturers Standard 7
CarolX Supplier Audit checklist for special processes Supplier Quality Assurance and other Supplier Issues 3
J Is there such a thing as a 'Special Processes' in ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Definition Special Processes - Can someone help us with a definition of Special Processes? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 13
