Specific ISO requirement to fill in all spaces on a move tag?
Marc
#11
any auditor worth his/her salt is going to have a flag go up when they see one that isn't completed
As a clarification - It is true that many forms/tags, for example most job travelers that actually follow the job competely through the process, may have data entered at different steps by different people, so at a given operation (for example) the form/tag will not be completely filled out. But typically forms/tags such as job travelers are 'custom' printed. In such cases it comes back to the each employee knowing what portions of the form/tag it is their responsibility to fill out (and they know how they know what they are responsible to fill in as well as when).
Eredhel
Quality Manager
#12
If those are just too good a price to pass up then turn them over and see if the other side is blank. If so make a procedure that says to write on the blank side the customer name, work order #, quantity, and part number and rev. But you could probably get some blank tags too. I like having custom ones with the required fields but I also know that's not always an option.
Marc
#13
The company would do just as well buying completely blank tags. I bet they're even cheaper (no printing).
JoshuaFroud
#15
At the end of the day, as others have said there is no ISO specific requirement to fill in all boxes. As an auditor however I would question why the boxes were being left blank. My concern with blank boxes is you do not know if they have been forgotten or intentionally left blank. If your procedure states "Only fill in details on the XXX XXX XXX and XXX lines" then all is well. If the procedure states "complete all boxes" then there may be a non-conformance, albeit a very minor one.
it all comes down to what your internal procedures say. If you have a procedure that says fill out the boxes then you fill out the boxes, if you do not, don't.
Personally, I have a good documentation practice procedure that states no box must be left blank and must either be struck through or marked N/A. This is predominantly due to using a generic test sheet for several different items and the tests not conducted must be marked N/A.
#16
Why? Why do so many auditors start off looking at the negatives? Talking about "what procedures require" is keeping Quality Management in the 20th century. Today's auditors should be asking about what's effective - of management. Anything else delays and confounds the lower levels of the organization and keeps the QMS as a simple compliance issue. Effective auditors ask and seek information about what's the effect on not completing the tag...
JoshuaFroud
#17
I would question it, the explanation that is given above in the thread would be plenty enough information and I certainly would not raise this instance as anything apart from potentially to recommend using blank tags as someone else suggested.
I would not consider looking for negatives, just asking to understand the process. I completely agree there is no point in doing work for work's sake and N/A'ing the fields on this card, in the situation above, adds no value due to the nature of how they are being used.
There are however certain situations in where leaving a box blank may not be suitable or acceptable. It is all situationally dependent which is why I would ask the question.
The reason for mentioning what the procedures require is, if a procedure says you should be doing it, you should be doing it. Regardless if that procedure is asking something unreasonable or nonsensical, in that situation the problem is the procedure and it should be updated in line with current practice.
UncleFester
#18
Let's consider under what clause the auditor could write the non-conformance - and then establish a defence against it.
There are possibilities for a N/C under "7.5.2 When creating and updating documented information, the organization shall ensure appropriate:
a) identification and description (e.g. a title, date, author, or reference number);".
So, is the identification and description on the tag appropriate?
Another possibility is under "8.1e) determining, maintaining and retaining documented information to the extent necessary:
1) to have confidence that the processes have been carried out as planned;
2) to demonstrate the conformity of products and services to their requirements."
So, does the information on the tag demonstrate that the process has been carried out as planned and does it demonstrate conformity of the product?
Also consider 8.5.2 "The organization shall use suitable means to identify outputs when it is necessary to ensure the conformity of products and services."
Is the tag 'suitable means'?
And "8.6 The organization shall retain documented information on the release of products and services. The documented information shall include:
a) evidence of conformity with the acceptance criteria;
b) traceability to the person(s) authorizing the release."
So long as the tag demonstrates this, you're fine.
Just examples of where the auditor could raise N/Cs, but challenge any auditor who comments about empty boxes.
#19
Are there? If so, what's the down side? Since the OP stated off with explaining the CB audit will write an NC, are you talking about this from the CB audit perspective? It concerns me that any auditor applying spurious criteria to a situation, looking to justify why it was "worth" digging into this...
Sidney Vianna New Chrysler Specific Requirement Document for TS 16949 and ISO 14001 Customer and Company Specific Requirements 3
M Specific Requirement for Calibration - ISO 17025 Clause 5.6.2 Interpretations ISO 17025 related Discussions 15
B Specific requirement for Internal Auditor training in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Sidney Vianna Sector Specific Standards based on ISO 9001 as a baseline requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
D Is ISO 13485 Location Specific? ISO 13485:2016 - Medical Device Quality Management Systems 1
Sidney Vianna Sector specific Information Security ISO Management System Standards IEC 27001 - Information Security Management Systems (ISMS) 1
M Are there specific rules regarding ISO 13485 and R&D? ISO 13485:2016 - Medical Device Quality Management Systems 4
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
T Customer Specific Documents and Records - ISO 9001 Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C ISO 13485 - Client Specific Validation and CE Marking CE Marking (Conformité Européene) / CB Scheme 3
N Can a specific division of an ISO 9001 company be exempted? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Combining Sector Specific Quality Standards - TS 16949, AS9100 and ISO 9001 Other ISO and International Standards and European Regulations 3
T Required ISO 17025 Traceability - The specific ID/SS number of the test weight ISO 17025 related Discussions 6
F ISO/TS 16949 for a specific program - Aftermarket Parts IATF 16949 - Automotive Quality Systems Standard 18
eternal_atlas Identification of ISO 9001 Clause to a specific Non-Conformity General Auditing Discussions 7
Howard Atkins New Ford Motor Company Customer Specific for ISO/TS 16949 Posted on 02/06/2008 Customer and Company Specific Requirements 1
Sidney Vianna Advice from ISO/TC 176 for Sector specific standards Other ISO and International Standards and European Regulations 0
S How to align our global ISO 9001 procedures to each specific project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
V ISO 13485 - 8.2.1, 8.4, 8.5, and 8.5.2/3 - Specific Procedures Needed? ISO 13485:2016 - Medical Device Quality Management Systems 6
H Ford Customer-Specific Requirements for use with ISO/TS16949:2002 Customer and Company Specific Requirements 0
A ISO/TS 16949 European Customer Specific Requirements Customer and Company Specific Requirements 4
M GM specific requirements ISO/TS 16949 link Customer and Company Specific Requirements 4
Marc GM's ISO/TS 16949 Customer-Specific Requirements Customer and Company Specific Requirements 0
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
Marc Requested new UK specific forum - 20200930 UK Medical Device Regulations 0
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D Naming of SOP doc's - Specific to Calibrations ISO 13485:2016 - Medical Device Quality Management Systems 2
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
K OEM specific requirements - PPAP was rejected by STA Customer and Company Specific Requirements 5
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Specific Values of Quality Objectives Benchmarking 7
M Specific Absorption Rate (SAR) Testing - What Standard to Use? Other ISO and International Standards and European Regulations 1
DuncanGibbons Are there any aerospace specific requirements for material resource planning? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Informational Several US FDA draft guidances, including some specific device guidances for the Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 0
P GM TWO (Temporary Work Order) - Is there a specific GM format for the TWO# to be sent with the material? IATF 16949 - Automotive Quality Systems Standard 1
D Customer and Company Specific Requirements for notification of Customers of a change in Management or Key Personnel Customer and Company Specific Requirements 3
A EU MDR Annex I section 11.3 - Medical Devices labelled as having a specific microbial state EU Medical Device Regulations 7
S Is a specific day required in an expiration date? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M Routine testing of medical electrical systems - What specific electrical safety tests should be performed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Specific processes - Construction management field Service Industry Specific Topics 2
L IATF 16949 8.3.3.2 FCA (Fiat Chrysler) Specific Requirements - Examples of AQR and MPFMEA Service Industry Specific Topics 1
J Marketing and promotional materials - EU and MDR Specific EU Medical Device Regulations 12
