Specification and Tolerance in Stability Control Chart
P
Priss80
What specification and tolerance should key in control chart for stability study if i use production part to conduct the study? If i use master block, what specification and tolerance should be key?
:thanks:
Steve Prevette
Deming Disciple
My assumption is you are trying to figure out the stability of produced product. So for the control chart itself, you are going to measure the parameter of interest on sequentially produced items. Then you make the control chart and see if the control chart is stable. For declaration of stability, you don't need the specification or tolerance. Now, once you understand the production data (and if it is stable or not) you can then compare that to the specification and tolerance to see if the process is producing parts in a predictable manner that will meet the specification and tolerance routinely.
P
Priss80
I am talking about the MSA stability, measure the equipment stability. What specification and tolerance to use if I take production part to conduct? What if I use master block to conduct?
Steve Prevette
Deming Disciple
Sorry, but you are beyond my knowledge in this. I suspect you will need to provide details as to what you are trying to measure the stability of, or what you mean by a "master block" to get an answer.
P
Priss80
I take a molded part from produce in production and measure a dimension let say length5 times repeatedly and record the results in X bar R control chart. The MSA stability study will be repeated every bi-weekly until I collect total of 10 subgroups. This time I should calculate the control limit, now I need to know the specification of the part, I will put the spec of the length 2.5+/-0.5mm in the chart in order to calculate the control limit. Some people I discover they use master block to study the stability of the measurement system. They put the block lenh dimension lets say 2.0+/-0.002mm in order to calculate the control limit. Please help me to understand which method is correct? Why the method is applied?
P
Priss80
I take a molded part from produce in production and measure a dimension let say length5 times repeatedly and record the results in X bar R control chart. The MSA stability study will be repeated every bi-weekly until I collect total of 10 subgroups. This time I should calculate the control limit, now I need to know the specification of the part, I will put the spec of the length 2.5+/-0.5mm in the chart in order to calculate the control limit. Some people I discover they use master block to study the stability of the measurement system. They put the block lenh dimension lets say 2.0+/-0.002mm in order to calculate the control limit. The master block is a standard block some in square or round shape that need calibration.Please help me to understand which method is correct? Why the method is applied?
P
Priss80
Refer back to my previous post, I also want to know the specification and tolerance put in the control chart to calcualte the control limit is correct? :thanks:
Steve Prevette
Deming Disciple
That is incorrect. The control limits on a control chart are calculated SOLELY from the data. Specification and Tolerance are not used in calculating the control limits. The UCL is the average of the data plus three standard deviations of the data, the LCL is the average of the data minus three standard deviations of the data.
Expanding on what Steve said:
a measurement system stability study doesn't use the specifications (or tolerances) in anyway. The study is to assess the measurement system, not the conformance of the parts.
The control limits assess the stability of the measurement system. The limits are calculated using standard Xbar, R (or Xbar, S) formulas. do not use the standard deviation of all of the individual values...
There is some utility in plotting the individual values against the spec limits to understand the amount of measurement instability vs the specification. but you must determine the instabtility using the control chart method....
I can post an example if you want...
M Molded Component Color Tolerance Specification Manufacturing and Related Processes 6
A Multiple Threaded Fastener Tolerance Specification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Pressure Gages - Equipment Tolerance vs. Product Specification Calibration and Metrology Software and Hardware 2
M Measurement Capability vs. Specification Tolerance Measurement Uncertainty (MU) 13
Y Gage R&R - Calculating by Specification Tolerance vs. Study Variation - Differences Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Precision/Tolerance Ratio for 1-sided Specification - How to Compute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Full Scale Tolerance - How to apply full-scale accuracy specification to a gage? General Measurement Device and Calibration Topics 4
E Determining Weighing / Counting Scale Tolerance - No manufacturer specification General Measurement Device and Calibration Topics 24
M Gage R&R with a unilateral specification tolerance - What about the other limit? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
K Radius with specification only Max limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G What does performance specification include? US Food and Drug Administration (FDA) 1
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
Q User Requirement Specification for HR (Human Resource Management System) Manufacturing and Related Processes 1
S Managing specification changes on standard parts purchased through trading companies Document Control Systems, Procedures, Forms and Templates 2
D Performance specification as a Risk Control Measure, EN 14971 ISO 14971 - Medical Device Risk Management 7
D Subcontracting specification developer duties US Food and Drug Administration (FDA) 5
shimonv IEC 60601-1 Essential Performance - Is the signal accuracy specification an essential requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S How to find technical specification for facilities maintainance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
S When does a Distributor become a Specification Developer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
Lisa Christo Specification developer Other Medical Device Related Standards 0
B IATF 16949:2016 – Technical Specification (eBook edition) IATF 16949 - Automotive Quality Systems Standard 1
R Contract Manufacturer/OEM Supplier - We are a specification developer for a kitted product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
E Compliance to standards (ISO 80369) but the ID is out of specification Other ISO and International Standards and European Regulations 0
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
I EO sterilization out of specification and correction Other Medical Device Regulations World-Wide 1
C Specification Developer or Consultant? Definitions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Medical Device Manufacturer vs. Specification Developer Other US Medical Device Regulations 1
R Specification on flare testing extruded aluminum - Where to find Design and Development of Products and Processes 1
supadrai Establishment registered as specification developer and foreign exporter only 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M McDonnell Douglas Specification Control Drawings Various Other Specifications, Standards, and related Requirements 4
J Is there a specification that provides directions on Drawing Revision Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Dates on Labels acceptable to the USA - GS1 General Specification 3.4.4 Other US Medical Device Regulations 3
S GR&R using 10 Parts with different Specification Limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
shimonv Soldering Station Accuracy out of specification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Accounting for Variability on High Side of Specification Reliability Analysis - Predictions, Testing and Standards 1
P Specification Subscription Services - Eg: Things like MSDS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Deformation specification not defined in print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
R Looking for calibration specification for Fluke 7250 pressure controller General Measurement Device and Calibration Topics 5
A Uncertainty Measurement - What this accuracy specification "1% + 10^5": means? General Measurement Device and Calibration Topics 2
