I'm currently contracting a company and have run across a situation that I'm unfamiliar with. So, I turn to you all for help.
We are sampling for weight of a product and using a “weight per 10” (wt/10) value for inspection. It’s unclear why this practice was first started, but that’s not the issue right now.
I’ve currently been given reams of test data in a “weight per 1” (or each). I need to compare the statistics on the wt/1 samples as part of my evaluation of the test samples. To do this however, I need to convert the existing wt/10 specification to a wt/1 specification. Obviously, I can’t just divide by 10 as the probability distribution of the 10 units will come into play when getting the average which would be read as the 10 unit group. I believe this can be solved using the central limit theorem, but when I was looking at it I’m not directly seeing how to apply it into a simple equation for conversion.
For discussion purposes, let’s say the wt/10 specification is:
Min: 190
Nom: 195
Max:200
Making the theoretical target for each unit being 19.5. What would be the spec range for the individual parts?
Any help would be most appreciated.
Min: 190
Nom: 195
Max:200
