Specifying a MINITAB PC Hardware - What matters?
N
neillsm
Hello! For my first post I have an intriguing question..
I use MINITAB for electrical test data, batch data are in the order of 200k rows and 20 columns - combined datasets are in the order of a few million rows.
I am hampered by very long processing times when performing analysis like prob. plots vs batch for two variables - these can be tens of minutes with MINITAB using all of one processor and a whole bunch of RAM. To speed my work up I am specifing a new desktop, but what actually matters?
More cores? or does MINITAB not use multi-threading heavily? (or at all)
Faster cores? - this seems a no brainer.
More RAM? - As a 32bit application, I can't see this helping.
Faster RAM? - Again a no-brainer.
SSD? - This should help, but does MINITAB use a lot of paging?
My current desktop is an i5-3470 (4 cores, 4 threads) @ 3.2GHz with 4GB DDR2.
What experience do you users have with upgrading, large datasets and MINITAB?
Have you contacted Minitab directly for recommendations?
Also, how is your data collected? Is it this massive because of a high sampling rate? I have analyzed a few such data sets. Each time, I found serious autocorrelation and had to sample every nth point to eliminate the autocorrelation before performing an analysis. This allows reducing the sampling frequency and reducing the size of the data file.
N
neillsm
I have contacted MT - they refer me to the minimum spec requirement - which is no help.
The data are from discrete parts, each ~ 300um square, manufactured on thin disks of silicon, each row is one device. The device count can be >300k per disk.
Sampling these data for analysis is a possibility, but yield issues can be spacial, regularly repeating or random - so the scheme would have to be carefully though about.
For yield reports there will be some reluctance in not using the entire dataset.
N
N Specifying Measurement Standards on an External Calibration PO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Specifying the building of a new Calibration Laboratory General Measurement Device and Calibration Topics 6
B Registrar Specifying Audit Frequency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
ScottK Specifying standards you don't own - non conformance or observation? Nonconformance and Corrective Action 25
P Dimensional Characteristics Rating:Guidelines for specifying Special Characteristics? Statistical Analysis Tools, Techniques and SPC 3
S Need help with analysing a survey on minitab Using Minitab Software 1
M Minitab assistant: 1-Sample % Defective Test Using Minitab Software 1
G Batch printing reports in Minitab Using Minitab Software 3
V Minitab GRR crossed Xbar and r method macro needed Using Minitab Software 7
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M How to change the display of optimization plot in Minitab 18 Using Minitab Software 2
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
J Including Repeats in DoE using Minitab Using Minitab Software 5
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
S Minitab - Factor Analysis: Label on second series of data for Biplot Using Minitab Software 4
J Which Anova dropdown to use for R&R in Minitab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
A Generating samples from a population in Minitab Using Minitab Software 0
Ron Rompen Random data generation in Minitab Statistical Analysis Tools, Techniques and SPC 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
B Informational Expanded Gage R&R Analysis using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
R Rank Deficiency Error Minitab Using Minitab Software 5
H Minitab 15 - Factorial Design - 3 factors: 4x3x2 - How to? Using Minitab Software 4
A Capability Analysis for Packaging Seal Strength with spec. >0.1 Kgf using Minitab Using Minitab Software 6
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
N Regression Model (Minitab 18) - Which values my input parameters should have Using Minitab Software 2
L MINITAB 17 - Changing Data Using Minitab Software 3
R Conjoint Analysis - Minitab 18 Statistical Analysis Tools, Techniques and SPC 2
F How to make an ANOVA of a design with repeats (not replicates) in Minitab? Using Minitab Software 18
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
S Minitab runs at different speeds on identical PCs Using Minitab Software 5
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
S Minitab limit definition from R & R Using Minitab Software 4
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
A Taguchi Minitab - Continuous Data - What should I choose as response variable? Using Minitab Software 3
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
G How to create a mixed OAs in Minitab Using Minitab Software 1
V Looking for advice on Pooled Standard Deviation between Minitab and MS Excel Statistical Analysis Tools, Techniques and SPC 1
N DOE (design of experiments) in Minitab 16 Using Minitab Software 6
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
