Stab Pin Size For Check Gage
GunLake
I'm trying to figure out what size Stab Pins should be for a check fixture because i believe they're doing it wrong here(newish job). I was looking at a gage today and the stab pins were very tight on the master part. So i wanted to investigate and found the pin they're using is .298 in size. The hole size is .310 +/- .005 with Position at 0.025(M).
The way i calculate it would be
.310 - .005 = .305
Then
.305 - .025 = .28
Is this correct?
I know its not a major difference but still could fail a good part.
Thanks,
Proud Liberal
  • Is this for a single hole or a pattern of holes?
  • Are any of the datum marked MMC?
  • Are the datums being located RFS in the fixture?
Curious minds want to know.
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
G Supplier Checking With Gauge Pin Problem Solving, Root Cause Fault and Failure Analysis 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
Z Two Payment Identification Number (PIN) for the same order in DFUF website 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M AS9100 Rev D and Pin Gages General Measurement Device and Calibration Topics 7
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J PCI PIN compliance and Gap analysis IEC 27001 - Information Security Management Systems (ISMS) 0
Q How can you justify using a more accurate Pin Gage class? General Measurement Device and Calibration Topics 16
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Ron Rompen Question on 'Class of Fit' - Gage Pin Clearance Manufacturing and Related Processes 2
C Black Oxide Gage Pin Calibration Requirements General Measurement Device and Calibration Topics 4
B Can we calibrate a standard pin with a gauge? General Measurement Device and Calibration Topics 2
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
W Hach 5 Pin Connector Pinout Diagram needed General Measurement Device and Calibration Topics 3
C Rolling the correct M8 1.25 Pin Thread Manufacturing and Related Processes 2
W Setting up a Zmike for Pin Gage Calibration General Measurement Device and Calibration Topics 3
C ZZ Pin Gage Tolerances and Calibration General Measurement Device and Calibration Topics 2
S Pin Gage Calibration - Pins seem to be "growing" General Measurement Device and Calibration Topics 9
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 14
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
O Clavicle Pin Classification Number: UMDNS Code Other Medical Device and Orthopedic Related Topics 1
O ISO Standards For Intramedullary Pin Design History File Other Medical Device Related Standards 2
S GR&R for Dowel Pin Holes Using Deltronics Pins Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D What is the difference between Pin and Plug Gages General Measurement Device and Calibration Topics 13
A ID Calipers Accuracy and Pin Gages Manufacturing and Related Processes 13
D Calibration of Pin Gages using a Calibrated Caliper that measures to 4 decimal places General Measurement Device and Calibration Topics 15
N Calibration of Setup Fixtures & Pin Gages General Measurement Device and Calibration Topics 5
P How to manage loose Pin Gages without Identification on the machining floor Calibration Frequency (Interval) 19
D Nonadjustable M&TE - 10 year calibration interval? Pin Gages Calibration Frequency (Interval) 11
M Gage pin calibration - Actual calibration readings required on the calibration cert General Measurement Device and Calibration Topics 3
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
B Pin Gage Calibration Procedure - ISO 17025:2005 accreditation requirements? ISO 17025 related Discussions 8
G Slip fit - Size on size dilemma for pin and plug gages Manufacturing and Related Processes 4
V Calibration of Pin Gauges General Measurement Device and Calibration Topics 2
H E Coat (Electrocoat) Pin Hole Paint Defects - Help needed Nonconformance and Corrective Action 3
A Pin Gage - Gage R&R Studies - One Pin or Entire Set? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C Pin Gauge Calibration using a Micrometer - Accuracy & Calibration Level Question General Measurement Device and Calibration Topics 10
L Are you Qualifying your own Gageblocks and Pin Sets? General Measurement Device and Calibration Topics 16
J Using Pin Gages as a Measurement Tool for Ppk/Cpk studies Capability, Accuracy and Stability - Processes, Machines, etc. 11
C Internal Diameter Measurement and Pin Gage Calibration General Measurement Device and Calibration Topics 6
J Calibration of Pin Gages - AS9100 Calibration Requirements General Measurement Device and Calibration Topics 23
B A reference or formula for the largest pin which will fit in a hole General Measurement Device and Calibration Topics 6
ScottK Dimension on the high limit with a plus gauge pin - YOU MAKE THE CALL! Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
G API REG Pin and Box Threading - Minimum Gages Needed - Thread, Plug and Ring gauges? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Gage pin clearance on close tolerance - Hole size is ?.8746 ? .0001 General Measurement Device and Calibration Topics 9
Q Pin Gage Classifications - Use and tolerancing of Class XXX pin gages General Measurement Device and Calibration Topics 7
A Calibrating pin gages - Can we write a procedure "Calibrate before use"? Examples? General Measurement Device and Calibration Topics 14
O In-House Laboratory Scope - Calipers, Pin Gages and Digital Indicators General Measurement Device and Calibration Topics 4
L Gage Pin Gauge R&R - Our calibration guy said he doesn't know how to do one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
