Standard Deviation - Doubt and Clarification of my Understanding
K
KCIPOH
#21
Hello NC,
Agree and I think I get a better idea on the Cp issue up to this point. Will come back to you for reference if any doubt.
Thank You and good day :)
K
KCIPOH
#22
Hello Cove members,
From the Cp and Cpk formula itself, it using 6xsigma and 3xsigma for the formula denominator respectively. Since the sigma signage is referred to Population Standard Deviation, so is it we are calculating the Cp and Cpk using Population Standard Deviation? or is it just an indication where it can be refer to either Population Standard Deviation or Samples Standard Deviation, depends to the case we want to measure?
Please help :confused:
N
NumberCruncher
#23
Hi KCIPOH
You will almost always use the sample standard deviation.
In practice there is not much difference between the two for any reasonable sized sample. If you work out the population standard deviation and the sample standard deviation for a sample of size 50, the numbers are almost the same.
I did this for a set of 50 numbers generated by Excel.
Sample standard deviation = 0.3408
Population standard deviation = 0.3374
So both numbers are about 0.34
If you have taken a sample from your output (30 samples out of 2000 for example) you would use the sample standard deviation.
You would only use the population standard deviation when you have used the entire output of your process as the sample, in this case 2000 items.
NC
#24
KCIPOH - This is a typical point of confusion for capability indexes. Fortunately, this question has been answered many times and at great length in this forum. If you search for "Ppk Cpk standard deviation" or "Long term capability" or other variations you will find many helpful threads on this topic.
A great place to start is this thread wich contains link to other threads:
Ppk & Cpk
My response in the above thread provides a direct answer to your question:
"So that you understand why the answer we give is the correct one we must first understand the concepts of Cpk and Ppk.
The first concept is that Cpk and Ppk formulas were originally designed for ongoing processes and was conceived as an extension of SPC. Properly designed SPC charts are constructed using a series of small samples – or subgroups – taken over time. In general, when properly designed the parts within a subgroup are created under relatively the same conditions: same raw material, same operator, same equipment, same settings, same tool/fixture/equipment condition, same environmental conditions, etc. Each subgroup is taken far enough apart that some and eventually all of these conditions change so that all variation is captured.
Within subgroup variation therefore represents short term variation. Cpk uses the within subgroup standard deviation (the average of all of the subgroup Standard deviations)
The total variation (within subgroup plus subgroup to subgroup) is the long term variation. Ppk uses the standard deviation of all of the individual values.
(It is important to note that often people use the notation of Cpk as a generic term for a process capability index. They will specify Cpk when they really mean Ppk.)
When a product – or process – is new, there is often limited variation in the various inputs. So there is no way to determine the long term performance. Short term capability can be assessed. The units are all to be created using essentially the same conditions: same raw material, same operator, same equipment, same settings, same tool/fixture/equipment condition, same environmental conditions, etc. Only the sample size is much larger than one would take for an ongoing sampling of multiple subgroups. Typically, the sample size would be from 30-100 units. In this case since there aren’t multiple subgroups the standard deviation is just the single standard deviation on the individual values. The same standard deviation formula as for Ppk. So the short capability calculation for new products looks like the Ppk formula…"
#25
NumberCruncher has hit the nail on the head. for real capability studies it doesnt' matter wether or not you use n-1 or n for the standard deviation formula. there is far more variation in the sample data you select for the study than will be introduced by your choice of the 'population' or 'sample' standard deviation...
K
KCIPOH
#26
Hello NC and BevD,
Appreciate very much for your explanation, I get better now, will come back for any further clarification.
Thank You :)
Statistical Steven
Statistician
#27
Bev, maybe I am a purist, but if you KNOW the population standard deviation, then you have no need to take a sample. We sample from the population because we desire to estimate the mean and standard deviation of a population. It is SUCH a minor point, but for some reason it gets my crow.
Sorry for the diversion!:bonk:
#28
Along similar lines, we will often hear people referring to the population standard deviation as an estimate.
#29
yeah - I understand the frustration, on the other hand I run into so much fretting about the little innacuracies that the big thing gets lost. The point I drive home with my students is not about knowing the population standard deviation of course, it is directed at which formula you use to estimate the population standard deviation from a sample. While the n-1 formula is considered the correct one for estimating the total from a sample, for all practical purposes it hardly matters even when used with small sample sizes. my motto is that if additional precision in the answer doesn't change the action taken - why bother? Too often improper sampling (non-random sampling from a non-homogenous process) effects the accuracy so much that the innaccuracy from the precision is lost.
Of course I always use the n-1 formula anyway since the only times I have the total population are trivial examples.
S Average and standard deviation of Cumulative Data Statistical Analysis Tools, Techniques and SPC 5
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Please Help! what is ARL for the range and standard deviation Statistical Analysis Tools, Techniques and SPC 0
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
V Looking for advice on Pooled Standard Deviation between Minitab and MS Excel Statistical Analysis Tools, Techniques and SPC 1
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
T Standard Deviation vs. Standard Deviation of the Mean (Standard Error) Measurement Uncertainty (MU) 7
B Historical Standard Deviation or Select Parts for MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
C 95% CI vs Mean +/- sample standard deviation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G MS Excel for LSL, USL in Histogram and Standard Deviation Six Sigma 26
E RSD (Relative Standard Deviation) Calculation for two series of numbers Statistical Analysis Tools, Techniques and SPC 4
M Standard Deviation Estimation Formula - Student Question Statistical Analysis Tools, Techniques and SPC 4
M Using Minitab to Compute & Compare the Mean and Standard Deviation Amount Using Minitab Software 7
Q What is the relationship between Standard Deviation and 6 Sigma? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B "Historical std deviation" (Standard Deviation) in Gage R&R study Using Minitab Software 6
J Repeatability Standard Deviation Formula in MSA 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Change Control Process - Deviation from Standard for Parts Document Control Systems, Procedures, Forms and Templates 1
D Mean and Standard Deviation Chart Questions Statistical Analysis Tools, Techniques and SPC 2
V Pooled Standard Deviation - Mintab vs. Excel Using Minitab Software 15
S Formula used in Minitab 16 - "Pooled Standard Deviation" Statistical Analysis Tools, Techniques and SPC 2
S Meaning of n-1 in Standard Deviation Quality Tools, Improvement and Analysis 12
J Process Control/Standard Deviation Question on a One Sided Specification Capability, Accuracy and Stability - Processes, Machines, etc. 6
T Methods for estimating standard deviation Statistical Analysis Tools, Techniques and SPC 6
A Tolerances +/- 1 standard deviation? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A How to Calculate Standard Deviation using Casio fx-95 MS Calculator? Statistical Analysis Tools, Techniques and SPC 4
B Calculating a Standard Deviation with respect to MTBF Reliability Analysis - Predictions, Testing and Standards 1
G Standard Deviation vs. Estimated Sigma Statistical Analysis Tools, Techniques and SPC 9
T Does Excel STDEV calculate in 3 stdev (standard deviation)? Excel .xls Spreadsheet Templates and Tools 12
A Mathematical difference between mean Deviation and Standard Deviation Statistical Analysis Tools, Techniques and SPC 3
I Definition Standard Deviation - Working vs. Thinking Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
C Can the Standard Deviation (SD) value be zero? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
J Finding standard deviation of ranges in Minitab Using Minitab Software 5
C Calculating Savings from Standard Deviation when Mean remains constant and SD changes Statistical Analysis Tools, Techniques and SPC 4
W Can I use the o/p for a Design of Experiments as Standard Deviation of the flow? Design and Development of Products and Processes 4
J Back to Basics Statistics - Standard Deviation small when performing an R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
L Standard Deviation - Process Output is Stable and Normally Distributed Statistical Analysis Tools, Techniques and SPC 6
M Gage R&R (Ranges Method) - Reproducibility standard deviation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Cp & Cpk - How are you calculating the standard deviation? Capability, Accuracy and Stability - Processes, Machines, etc. 3
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
