Standard Deviation vs. Standard Deviation of the Mean (Standard Error)
tacom
Suppose that we measure density d=m/v
m=mass
V= Volume
If we want to calculate the combined measurement uncertainty of the mass ?m?
There are three uncertainty sources, the repeatabilty, the readability and the contribution due to the uncertainty in the calibration function.
My question is related to repeatability ?s? of the balance.
İf I make ?n?(lets say n=10) measurement to determine repeatability of balance .
When combining uncertainty sources to calculate the combined measurement uncertainty of the mass ?m?
Should I use Standard deviation (S) or Standard deviation of the mean (Standard error)(S/(n)^0,5 as repeatability component
Note: in routine analysis test sample is weighted only once
I need your comments
dgriffith
m=mass
V= Volume
If we want to calculate the combined measurement uncertainty of the mass “m”
My question is related to repeatability “s” of the balance.
İf I make “n”(lets say n=10) measurement to determine repeatability of balance .
When combining uncertainty sources to calculate the combined measurement uncertainty of the mass “m”
I was taught, and use in my uncertainty budgets, that if you are reporting the average(mean) of a sample size x, you also report the std dev of the mean.
There is a school of thought that says you may be underestimating the uncertainty, and should use the std dev of the sample size x instead.
I don't 'know', so I chose the former, and it seams to work for us.
But if you are weighing ten samples once, and not weighing 1 sample ten times, I might use the std dev, not sampling mean.
Steve Prevette
Deming Disciple
m=mass
V= Volume
If you want to know the uncertainty of the weight of a SINGLE mass item, then you stick to individual standard deviation. You only divide by the square root of n if you are truly interested in how good you are estimating the AVERAGE (MEAN) measurement.
tacom
Thanks steve and dgriffith
Although we weigh same object (ethalon for instance) 10 times in order to determine repeatability component of the measurement uncertainty of mass measurement for future use ;in laboratory practice samples or chemicals is weighted only once ; so I must use Standard deviation.
İnstead of Standard error. Am Iright?
TACOM
dgriffith
Yes, if you are estimating the error of weighing an object once.
:mg:
I think I know what you meant, because I know you know that there is no standard deviation if you only have one reading.
What I think we have here, and correct me if I'm wrong, is a single object weighed 10 times and reporting the average (1 event), then use the std. dev.; if that same object will be weighed repeatedly (multiple events on same object), and each weighing is an average of 10 samples, then report the std. dev. of the mean.
tacom
Suppose According to test method I must weigh approximately 10,5 g test sample to make a test. in laboratory practice sample (10,5g) is weighted only once[
Now, I want to calculate the combined uncertainty of 10,5 g. EURACHEM / CITAC Guide CG 4 says mass measurement has three uncertainty sources. The repeatabilty, the readability and the contribution due to the uncertainty in the calibration function.
So I want to find repeatability of 10,5 g. To fulfill this requirement I weigh 10 g (nearest to 10,5g) ethalon or any object( but not test sample ) ?n? times (usually n=10) . As a result I get Standard deviation as ?S? or Standard error ?S/(n)^0,5?. This Standard deviation /error wil be used as a repeatability component of the 10,5 g (or 10.3g; 10.9g ) in the future use as a constant.
That is, when ever I conduct this test and weight approximately 10,5 g sample once and want to calculate combined uncertainty I will use this value as a repeatability component
I think we should use Standard deviation ?S? since the test sample taken is weighed only once
Steve Prevette
Deming Disciple
:mg:
Yes, I take multiple readings of a single test item to see what the estimate of the standard deviation is for the weighing device. I then want to predict what is the standard deviation of the estimate of the weight of the next item I weigh (which I will only weigh once), which won't necessarily have the same weight as the test object. I apply the standard deviation from the test as the estimate of the standard deviation for the weight of this item.
Note - I am making the assumption that the error for the weighing device is constant over the range of weights the weighing device is able to weigh. That may or may not be a good assumption.
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
S Average and standard deviation of Cumulative Data Statistical Analysis Tools, Techniques and SPC 5
V Acceptable maximum RSD (relative standard deviation) for an sample size Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Coury Ferguson MiniTab 17 Question-Standard Deviation Default Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Please Help! what is ARL for the range and standard deviation Statistical Analysis Tools, Techniques and SPC 0
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
V Looking for advice on Pooled Standard Deviation between Minitab and MS Excel Statistical Analysis Tools, Techniques and SPC 1
A How to calculate Mean and standard deviation without sample size in Minitab Using Minitab Software 5
B Historical Standard Deviation or Select Parts for MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
C 95% CI vs Mean +/- sample standard deviation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G MS Excel for LSL, USL in Histogram and Standard Deviation Six Sigma 26
E RSD (Relative Standard Deviation) Calculation for two series of numbers Statistical Analysis Tools, Techniques and SPC 4
M Standard Deviation Estimation Formula - Student Question Statistical Analysis Tools, Techniques and SPC 4
M Using Minitab to Compute & Compare the Mean and Standard Deviation Amount Using Minitab Software 7
Q What is the relationship between Standard Deviation and 6 Sigma? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B "Historical std deviation" (Standard Deviation) in Gage R&R study Using Minitab Software 6
J Repeatability Standard Deviation Formula in MSA 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Change Control Process - Deviation from Standard for Parts Document Control Systems, Procedures, Forms and Templates 1
K Standard Deviation - Doubt and Clarification of my Understanding Statistical Analysis Tools, Techniques and SPC 28
D Mean and Standard Deviation Chart Questions Statistical Analysis Tools, Techniques and SPC 2
V Pooled Standard Deviation - Mintab vs. Excel Using Minitab Software 15
S Formula used in Minitab 16 - "Pooled Standard Deviation" Statistical Analysis Tools, Techniques and SPC 2
S Meaning of n-1 in Standard Deviation Quality Tools, Improvement and Analysis 12
J Process Control/Standard Deviation Question on a One Sided Specification Capability, Accuracy and Stability - Processes, Machines, etc. 6
T Methods for estimating standard deviation Statistical Analysis Tools, Techniques and SPC 6
A Tolerances +/- 1 standard deviation? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A How to Calculate Standard Deviation using Casio fx-95 MS Calculator? Statistical Analysis Tools, Techniques and SPC 4
B Calculating a Standard Deviation with respect to MTBF Reliability Analysis - Predictions, Testing and Standards 1
G Standard Deviation vs. Estimated Sigma Statistical Analysis Tools, Techniques and SPC 9
T Does Excel STDEV calculate in 3 stdev (standard deviation)? Excel .xls Spreadsheet Templates and Tools 12
A Mathematical difference between mean Deviation and Standard Deviation Statistical Analysis Tools, Techniques and SPC 3
I Definition Standard Deviation - Working vs. Thinking Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
C Can the Standard Deviation (SD) value be zero? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
J Finding standard deviation of ranges in Minitab Using Minitab Software 5
C Calculating Savings from Standard Deviation when Mean remains constant and SD changes Statistical Analysis Tools, Techniques and SPC 4
W Can I use the o/p for a Design of Experiments as Standard Deviation of the flow? Design and Development of Products and Processes 4
J Back to Basics Statistics - Standard Deviation small when performing an R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
L Standard Deviation - Process Output is Stable and Normally Distributed Statistical Analysis Tools, Techniques and SPC 6
M Gage R&R (Ranges Method) - Reproducibility standard deviation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Cp & Cpk - How are you calculating the standard deviation? Capability, Accuracy and Stability - Processes, Machines, etc. 3
M Thread plug gauge validation/certification ASME vs Asian JJF standard Manufacturing and Related Processes 0
John Broomfield The Common Assessment Standard (prequalifying construction suppliers to bid) Misc. Quality Assurance and Business Systems Related Topics 0
D Oil and Gas product standard Oil and Gas Industry Standards and Regulations 1
T Operator Acceptance Audit Standard AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Annex of ISO 13485:2016 as harmonized standard (MDR/IVDR) ISO 13485:2016 - Medical Device Quality Management Systems 2
D Is ISO 10993-1:2020 a Harmonized Standard? Other Medical Device Related Standards 3
D Is it required to have the operator initial their work in the IATF 16949:2016 standard? IATF 16949 - Automotive Quality Systems Standard 3
S FCC Part 15, 18 harmonized to a standard? Various Other Specifications, Standards, and related Requirements 5
H Is CLSI H7-A3:2000 standard edition currently valid? Other Medical Device Related Standards 0
