Standard Error vs. Confidence Interval (not confidence level)
tahashamim
Dear All, (I am not sure if there is already a post for this or not, if there is, please guide me as I am at work and can not spend way too much time in searching)
Once again, I am here posting (probably) a very simple question. I have been reading on standard error definition and also of confidence interval and I also came to know that Z value is considered into the formula to calculate confidence intervle.
So the question really is that what is the difference between the two when both gives the margin in plus or minus. So for example if the sample mean is 60 lb and the standard error is +/- 3 lb through a formula. Then later they are saying confidence interval is 60 lb +/- (x lb)... They both are giving a range, what is the difference in both of these range?
Any help in the most non-technical way if possible?
Thanks in advance to all of you who will make an attempt.
Thanks,
Taha.
Tim Folkerts
The two ideas - standard error and confidence interval - are closely connected, as you seem to have learned.
Standard error is a particular calculation -- you take the standard deviation of a set of numbers and divide by the square root of the number of items in the set.
SE = s / n^0.5
Given typical assumption about normal distributions as such, you can conclude that the true mean would be within +/- the standard error 68% of the time.
Confidence intervals are more general -- you can choose any % certainly you want, but multiplying by the appropriate Z value. The most common is 95% confidence intervals. In this case you would use limits of +/- 1.96*SE.
For example, suppose you measured 100 widgets and found that the mean was 10 and the standard deviation was 2. The standard error would be 2 / 100^0.5 = 0.2. The 95% confidence interval would be +/- 1.96 * 0.2 = +/- 0.39
Tim
PS Wikipedia reference-linkStandard_error_(statistics) has a pretty basic discussion of the topic.
E How to use the Standard Error and how to set the error limits? Reliability Analysis - Predictions, Testing and Standards 2
T Standard Deviation vs. Standard Deviation of the Mean (Standard Error) Measurement Uncertainty (MU) 7
S Calculating Standard Error for a percentage (binary question) from a sample survey Statistical Analysis Tools, Techniques and SPC 1
P Medical device testing lab/service standard Other Medical Device Related Standards 1
V Is it required to recalibrate reference- standard instruments after equipment qualification General Measurement Device and Calibration Topics 0
R Quantity Discrepancy Tolerance Standard(s)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Additional registration requirements for different EU-states on top of standard CE-registration? EU Medical Device Regulations 3
T Is there any DIN EN 10204 equivalent to AISI standard ? ISO 13485:2016 - Medical Device Quality Management Systems 0
S How to determine sample size to test when the acceptance criteria is x >= Standard value? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A Industry standard for stamped part Various Other Specifications, Standards, and related Requirements 2
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
S Is the ISO/SAE 21434 a certifiable standard? IATF 16949 - Automotive Quality Systems Standard 3
keya1tos EU to UK plug adapter correct testing standard CE Marking (Conformité Européene) / CB Scheme 9
H Harmonized Standard for the refrigerated lab device safety CE Marking (Conformité Européene) / CB Scheme 2
N Misc Calibration Standard Inquiry Various Other Specifications, Standards, and related Requirements 5
N QMS standard for a research based Organisation Quality Manager and Management Related Issues 1
I VDA Standard search VDA Standards - Germany's Automotive Standards 1
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Measurement of threaded holes ISO10578 or ASME standard Measurement Uncertainty (MU) 3
C Calibration Procedures and ASTM CALIBRATION standard General Measurement Device and Calibration Topics 7
Sidney Vianna Informational ISO/CD 7101 Health Care Quality Management System Standard Hospitals, Clinics & other Health Care Providers 0
D Technical Standard aggregator company suggestions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
lanley liao Confusion between national standard and API related standard. Oil and Gas Industry Standards and Regulations 8
E Comparison of Respiratory Protective Equipment Standards (China Standard Compare with EU standard of EN149 Occupational Health & Safety Management Standards 2
Ajit Basrur Any ISO standard or guidance documents on barcode and scanning? Other Medical Device Related Standards 1
J External Standard Services Document Control Systems, Procedures, Forms and Templates 12
B IVDR Electrical safety standard EU Medical Device Regulations 0
B ISO13485 Standard Documentation Packages ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO/IEC 15408 - Is this is Certifiable Standard? Other ISO and International Standards and European Regulations 2
C Requirement for Revision of Standard in all Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Lighting Standard for Metal Processing Inspection Manufacturing and Related Processes 4
F USB-IF standard EU Medical Device Regulations 0
F Is USB-IF standard compliant with ISO13485? Medical Device and FDA Regulations and Standards News 3
A Is there a standard on tolerances of substances ? Medical Device and FDA Regulations and Standards News 1
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Should ISO 9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 70
