Standard for Internal Thread / Tapping Length
whtan02
Hello Everyones,
Need help.
Do we have a standard for internal tapping hole length, for example if the drawing only mention M2.5, then what is spec & tolerance for the thread length?
Thanks for the help.
H
Hodgepodge
Unless the tapped hole is a thru hole, the depth must be specified. If it isn't, then contact the design engineer or customer for clarification.
whtan02
Thanks for your reply, Hodgepodge.
It's a thru hole. But if the taper / chamfer at the starting of the thread is bigger, then it will reduce the thread length, right? So in this case, should we specify a min. thread length requirement? If so, then what & how is the standard here?
Thanks a lots.
Any chamfer(s) or lead in(s) (both sides) should also be dimensioned, to prevent reduction of the overall amount of threading. A minimum full thread may be specified, but that might not be as helpful as specifying the chamfer angle/depth.
whtan02
Any chamfer(s) or lead in(s) (both sides) should also be dimensioned, to prevent reduction of the overall amount of threading. A minimum full thread amy be specified, but that might not be as helpful as specifying the chamfer angle/depth.
Thanks for all the replies thus far.
Anyones can advise on the standard for min. thread engagement length, how do we specify such a spec.?
Thanks again!
H
Hodgepodge
The requirement would be "thru". It is either thru or it isn't. This does not need a specification. The chamfer has a size and is measured separately. If the chamfer was too large, then the chamfer would be out of tolerance, not the thread.
Thanks again!
It would be helpful to know why this is a concern. In addition, it's difficult to know what you mean by " taper/chamfer." If you're referring to an intentional countersink, its diameter, depth and angle should be specified. If you're referring to the natural small chamfer that results sometimes from drill entry, that's a different story.
The length of full functional thread engagement depends on the needs of the application. It's generally understood that a "no go" thread plug will enter the first few threads. I've attached a paragraph on the subject from an old Machinery's Handbook that I photocopied a few years ago when I was having a discussion on the subject with a customer.
Tell us more about your application and concerns.
whtan02
I'm refering to the natural small chamfer that results from drill entry.
The tapping hole is on the casing of the DC motor used for installation on the customer's unit. There are 2 thread holes.
The issue here is we receive one incoming lot with bigger chamfer (also bigger top diameter) from previous lots. Checking with 'Go' & 'No Go' gage result is still Good. Question here is are we good to release this lot to production? Is it enough just by checking thread size by go no-go gage. Immediately what comes to me is the concern on the thread length or the engagement length, as bigger chamfer naturally will reduce the thread length.
As we have the thread length control in the Unified thread (inno. of thread per inch), so shouldn't we have a standard as well for the min. thread length for Metric thread?
Since the product drawing print does not specify control dimension/tolerance on the chamfer size, nor the top diameter size, just M2.5 & pitch 0.45.
Maybe we can judge by tightening torque & loosening torque, but I'm not sure it matters because I think loosening torque will be depending on the amount of the input of tightening torque, regardless to the thread length.
Usually, when tapping a hole for a thread, the drill doesn't leave much, if any chamfer. The tap leaves a natural part chamfer, from the helix lead-in. Since this also can cause a sharp edge, which may become distorted and jam up the mating threaded part (screw, bolt etc), it is usual to chamfer the lead in.
It doesn't do away with the sharp edge completely, but it does provide a lead-in for the mating thread. This will provide for a more precise thread engagement and cross-threading is less likely. (see, I was awake when at engineering school!:lol:)
It's good practice, therefore, to call out a chamfer, even if it is only to "break edge" and not a fully dimensioned call out.
S Implementing a 45001 Health & Safety standard - Internal audit plan wanted Internal Auditing 1
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
S ISO 9001:2015 - Internal Auditing - Audit to the Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Is Internal and external audit of Account Department applicable to any ISO standard Internal Auditing 5
D Internal Audit Checklist for the latest ISO/TS 16949 standard IATF 16949 - Automotive Quality Systems Standard 11
R Leggett and Platt LP9000 Internal Standard Various Other Specifications, Standards, and related Requirements 5
T Should the Internal audit for ISO 9001 cover all elements of the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Copying pages of the standard for internal audit training classes IATF 16949 - Automotive Quality Systems Standard 11
B Checklist Standard for Internal Audit wanted Document Control Systems, Procedures, Forms and Templates 5
R Standard Methods - Internal Calibration Laboratory - What if there is no standard? IATF 16949 - Automotive Quality Systems Standard 2
5 Process based Internal Audits, instead of auditing to the elements of the standard Internal Auditing 21
Raffy ISO22000:2005 Food Safety Management System - Applicable Internal Audit standard? General Auditing Discussions 7
I ISO 13485 Practical Internal Audit Checklist - Standard vs. Process Based Internal Auditing 26
V Planning Internal Process Audits to the new standard - ISO 9001:2000 Process Audits and Layered Process Audits 7
M Internal Audit Checklists - Using the standard itself replace any checklist Internal Auditing 8
G Internal Audit Check List that Parallels the Standard? Internal Auditing 31
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J SAE J1739 standard IATF 16949 - Automotive Quality Systems Standard 2
Marcel DS LV 123 - BMW, AUDI, Mercedes Standard VDA Standards - Germany's Automotive Standards 1
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
Y UL 1998 Standard: software classes Software Quality Assurance 0
G What to do with correction factors overlooked by an accredited standard (6.4.11)? ISO 17025 related Discussions 5
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
O In addition to the standard, what other ISO 13485 sources do people recommend? ISO 13485:2016 - Medical Device Quality Management Systems 5
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
M Informational RoHS Standard - EN 63000:2018 to replace EN 50581:2012 Medical Device and FDA Regulations and Standards News 11
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
P Cenelec updated standard information CE Marking (Conformité Européene) / CB Scheme 1
