Standard work, standardized work instruction & work instruction: What are differences
morteza
Hi all
In IATF 16949, there are some terms which I can not understand and differentiate among them.
can some one explain me what are the following items and what are their differences:
1) standard work (used in clause 8.3.5.2 j))
2) standardized work documents (used in clause 8.5.1.2)
3) standardized work instruction (used in clause 8.5.6.1.1)
4) work instruction (used in clause 8.3.5.2 j))
Thanks all
bigqman
Re: Standard work, standardized work instruction & work instruction: what are differe
I am not experienced with 16949, but do know that standardized work is a specific methodology. Standardized work is not just a work instruction document – it’s created by process participants, based on customer requirements provided by management. Check out this blog on specifics of word usage http://www.leanblog.org/2008/05/standard-vs-standardized/
Kronos147
I would say it depends on what the organization states in their Control of Documented Information procedure. As long as there is a connection between the requirement and your system, it conforms, IMHO.
Stijloor
Re: Standard work, standardized work instruction & work instruction: What are differe
Hi all
Thanks all
This demonstrates that the IATF has not been very consistent with their terminology in IATF 16949:2016.
A work instruction is a document that supports a person performing tasks to be:
Safe
Effective
Efficient
That's all folks!
F
filen
Hi all
Thanks all
1) & 4)
Those documents shall be written in a manner that enables verification.
For example if you perform a layered audit, simple questions with yes/no to verify that the process is followed.
2)
Documents that handle the process in general, for example that you shall use stated safety equipment, follow the set-up instructions, how to measure and so on.
3)
Work instructions is more specified, for example instructions that is needed for a specific part number.
morteza
1) & 4)
2)
3)
Hi filen
I agree with Stijloor that IATF 16949 is not consistent in terminology. I think all should be the same. But what bother me is that in clause 8.3.5.2 (manufacturing process design output) IATF states that one of the process design output is standard work and work instruction. So, this two items should be different things which I can not understand their differences.
friends helps on explaining their differences would be appreciated.
F
filen
All of them gives the user/operator guidance, information and instruction to perform the job.
Makes it easier to see if the process performance is going well, and audits could be easy to prepare.
Standard work (where, why)
It is similar to the standardize work, contains check rules,products approval procedure or any tasks with company’s standard process.
Standardized work (who, what, when)
It further clarifies the standard work. Details which must be followed include takt time, critical path, items critical to quality, operation methods, etc.
Work instruction (how)
is the process that is to be performed, for example an assembly instruction.
For an example, the operator needs instruction to perform a set-up of a job.
And the auditor could check this with one question, is the job performed according to the standardized work for set-up - ok/nok?
(ofc you need to see/know the standard, and can easily check if the steps is followed or not)
Standard work
A standard framework for all manufacturing departments is that they must follow the rule of preparing jobs in advance (SMED)
Standardized work
Department A's list (dep. B could have an other order)
  1. Prepare set-up
    - Pick next job according to the planned job list
    - Place work order, drawings, tools and material to "preparing area"
  2. Perform setup
    - Report start of setup in ERP-system
    - Remove prev. job
    - Change tools
    - Put in front material
    - Start producing
    - Measure
    - Adjust if needed
    - Remove all scrapped parts
    - Report end of setup in ERP-system incl. amount of scrapped parts
Work instruction
Specific instruction for a part, including information about tools to use, in which order to be followed, measurement points...
P Medical device testing lab/service standard Other Medical Device Related Standards 1
V Is it required to recalibrate reference- standard instruments after equipment qualification General Measurement Device and Calibration Topics 0
R Quantity Discrepancy Tolerance Standard(s)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Additional registration requirements for different EU-states on top of standard CE-registration? EU Medical Device Regulations 3
T Is there any DIN EN 10204 equivalent to AISI standard ? ISO 13485:2016 - Medical Device Quality Management Systems 0
S How to determine sample size to test when the acceptance criteria is x >= Standard value? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
A Industry standard for stamped part Various Other Specifications, Standards, and related Requirements 2
B Wrong standard deviation calculation in AIAG SPC manual? Capability, Accuracy and Stability - Processes, Machines, etc. 13
S Is the ISO/SAE 21434 a certifiable standard? IATF 16949 - Automotive Quality Systems Standard 3
keya1tos EU to UK plug adapter correct testing standard CE Marking (Conformité Européene) / CB Scheme 9
H Harmonized Standard for the refrigerated lab device safety CE Marking (Conformité Européene) / CB Scheme 2
N Misc Calibration Standard Inquiry Various Other Specifications, Standards, and related Requirements 5
N QMS standard for a research based Organisation Quality Manager and Management Related Issues 1
I VDA Standard search VDA Standards - Germany's Automotive Standards 1
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Measurement of threaded holes ISO10578 or ASME standard Measurement Uncertainty (MU) 3
C Calibration Procedures and ASTM CALIBRATION standard General Measurement Device and Calibration Topics 7
Sidney Vianna Informational ISO/CD 7101 Health Care Quality Management System Standard Hospitals, Clinics & other Health Care Providers 0
D Technical Standard aggregator company suggestions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
lanley liao Confusion between national standard and API related standard. Oil and Gas Industry Standards and Regulations 8
E Comparison of Respiratory Protective Equipment Standards (China Standard Compare with EU standard of EN149 Occupational Health & Safety Management Standards 2
Ajit Basrur Any ISO standard or guidance documents on barcode and scanning? Other Medical Device Related Standards 1
J External Standard Services Document Control Systems, Procedures, Forms and Templates 12
B IVDR Electrical safety standard EU Medical Device Regulations 0
B ISO13485 Standard Documentation Packages ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO/IEC 15408 - Is this is Certifiable Standard? Other ISO and International Standards and European Regulations 2
C Requirement for Revision of Standard in all Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Lighting Standard for Metal Processing Inspection Manufacturing and Related Processes 4
F USB-IF standard EU Medical Device Regulations 0
F Is USB-IF standard compliant with ISO13485? Medical Device and FDA Regulations and Standards News 3
A Is there a standard on tolerances of substances ? Medical Device and FDA Regulations and Standards News 1
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Should ISO 9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 70
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J SAE J1739 standard IATF 16949 - Automotive Quality Systems Standard 2
Marcel DS LV 123 - BMW, AUDI, Mercedes Standard VDA Standards - Germany's Automotive Standards 1
