Start Compliance to RoHS, SCHV and REACH
abusuffian
Hi, need some suggestion for company improvement.
1. Company Background
a. We are manufacture sintered metal products mostly for automotive sector.
b. Our raw material are metal powder which we used to make small automotive engine products
2. Existing RoHS Practise
a. Depends on customer requirement. If they requested for RoHS compliance lab test, we will send the related products to the lab. Then send them the result. or
b. If they just send form for us to refill related to RoHS compliance, we will check all raw material, chemical, lubricant and anti-rust oil and ensure all of these items don't have RoHS prohibited substances base on their CAS number.
3. My Question
a. Is the item (2)(b) is the correct way to identify any products are comply to RoHS? Is it mandatory to send to lab?
b. Can i use method (2)(b) for SVHC and REACH compliance verification?
c. Is it practical to request to all of our supplier to send their items (metal powder, chemical, oil, pallet, boxes, wrapping plastic) for RoHS compliance lab test? So our company can easily declare all of our products are RoHS complaince because we use RoHS compliance raw material. :confused:
Thank you in advance.
Q
qpled
I would recommend starting with your suppliers - find out how much RoHS2 compliance information/test data they can supply (some are more giving than others I have found!). I believe you will want to specify RoHS2 as well.
JackPack
3a - It is not mandatory to have test reports on the parts in your products. For your finished products your company must provide a Declaration of Conformity (DoC) stating that your products are in compliance to all relevant CE directives, ex RoHS2. Technical files are used to support the DoC. Technical files can be in the form of supplier declaration, and/or material declaration, and/or test reports. Technical files requirements are described by EN50581:2012. Which type of technical files you would like to provide depends on your customers' requirements, as well as the risks you assigned to the raw materials and the suppliers. Do the raw materials have a high chance of containing the restricted substances? Do the suppliers have a good track record? Are they trustworthy? etc.
3b - Hope you understand the way how REACH calculates the substance in the product. The SVHCs are calculated for the whole "finished product", vs RoHS which the restricted substances are calculated for each homogeneous material. If you can do the work yourself then I don't see any problem with method 2b.
3c - I think it will make it easier for you if you have test reports for your raw materials. Most customers (me included) are more satisfied when homogeneous materials are tested by a accredited 3rd party laboratory. I guess the question is are you able to convince all you suppliers to provide test reports, or are they only willing to give supplier declaration (Can be a red flag if they don't want to send their materials for testing)? You guys will have to work out the solution.
Hope this help a little.
abusuffian
Your comment help me ALOT!! Very clear.. I read again and again.. Thank you very much..
However need to read more on you 3b answer.. Need more information for how the calculation done..
Very appreciate..
Badrul
I would suggest that you use IMDS to declare your product substances since most of your product supply for automotive.
Now days most of the OEMs will accept it. You can attached you lab report as well but it is not mandatory.
By using IMDS it is more standardize because SVHC-REACH is already embedded in the system.
G
gstewart
I'd like to pose a similar question.
We supply mechanical parts, made up of smaller components, largely to the automotive industry. As such many of the questionable materials have already been researched.
We have some small customers in the medical/electrical industry who request certificates of compliance to RoHS.
Now I don't want to go to a large number of suppliers asking about it.
If we have a drawing with an un plated mild steel component ( steel grade specified ) and they have internal PPAP approval for ongoing supply, can I therefore assume that it is steel of the correct grade that we are receiving?
I imagine that if it all turned sour, and it was found that we were supplying lead or something in our products ( not sure how this would happen ) then we could be sued. But since our suppliers are not allowed to substitute materials we could in turn sue them.
I don't want it to be a big deal , because it really only concerns a small number of sales.
Badrul
Just to share how I did with my supplier.
In PPAP:pSW we always ensure supplier tick "Yes" in Material Reporting and submitted report by IMDS. Otherwise we'll reject the PSW.
Anyway there are some supplier have to use Lead. For us as long as the Lead is within concentration as stated in ELV Annex II we'll accept it.
G
gstewart
This is a terrific way for "big customer's" to operate. Its called being the guy with the big stick. But the further you get down the supply chain the closer you get to being told where to stick your material reporting.
L Compliance to 21 CFR Part 11 - Where to start?? Qualification and Validation (including 21 CFR Part 11) 20
J ISO 10993 Compliance - Where to start? Class I Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 8
U Examples of Quality Objectives for a Medtech start up ISO 13485:2016 - Medical Device Quality Management Systems 4
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
mike10 QMS Update - Rev. up or start over? Document Control Systems, Procedures, Forms and Templates 3
N China - Start manufacturing before change approval? China Medical Device Regulations 3
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
T CE mark start date for a device EU Medical Device Regulations 7
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W My company is looking to start a materials testing lab that conforms to ISO17025:2017 ISO 17025 related Discussions 3
G Start and main steps of API Q1 Certification Process Various Other Specifications, Standards, and related Requirements 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
H Transferring an ISO 13485 certificate to a new CB - Do I have to start from scratch? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Start-Up Company looking for ISO 13485 Certification Body and Medical Device CE Mark Notified Body Registrars and Notified Bodies 6
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
TheMightyWife Can not start Personal Conversations Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 18
E Is it possible to start an ISO 9001 QMS from scratch (Really) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M AS9100 - Where to start - Small company (10 employees) and I am the Quality Dept. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
M How do you start a calibration/anything company? Career and Occupation Discussions 11
E ISO 9001 certification of the new plant before start of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
B Gap analysis of new start-up company technical documentation CE Marking (Conformité Européene) / CB Scheme 1
qualprod How to start with Lean? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R QMS and ISO - Where to start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
S ISO 17025 - Help in Getting accreditation- Where to start from ISO 17025 related Discussions 12
H Need to Start an R&D Laboratory, what to do? Design and Development of Products and Processes 6
O Start Up Approval Dimension Records IATF 16949 - Automotive Quality Systems Standard 5
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
Moncia Design FMEA - Where to Start FMEA and Control Plans 20
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
M How to Start SPC from the ground up! Statistical Analysis Tools, Techniques and SPC 8
A Start Up of a small AS9100 Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P CA,PA, Continual Improvement - How to start in a Service Company Quality Tools, Improvement and Analysis 1
P Where to start to helping other companies to get ISO IEC 27000? Consultants and Consulting 1
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M APQP and PPAP for Beginners - Where do I start? APQP and PPAP 48
S How to Start SPC in a Shaft Grinding Section Statistical Analysis Tools, Techniques and SPC 1
M Start New Machine Shop OR BUY Business Continuity & Resiliency Planning (BCRP) 9
K Disaster Recovery and Business Continuity Planning - Where to start? Business Continuity & Resiliency Planning (BCRP) 20
Hershal ILAC is preparing to start the possible revision to ISO/IEC 17025 ISO 17025 related Discussions 2
S How do I start "Risk Management" ISO 14971 - Medical Device Risk Management 3
L Where to Start to Completely overhaul a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Which ASQ Certification should I start with? Career and Occupation Discussions 9
M Where to start Maintenance Function Kaizen Lean in Manufacturing and Service Industries 4
J ISO 13485 and ISO9001 Quality Management Implementation Start ISO 13485:2016 - Medical Device Quality Management Systems 6
A ISO 9001 to ISO 17025 where to start ISO 17025 related Discussions 3
J Major Nonconformance on Stage 2 Audit causes to start over Stage 1? IATF 16949 - Automotive Quality Systems Standard 2
M General Guidelines on how to start a Quality Campaign Misc. Quality Assurance and Business Systems Related Topics 2
